Old 10-13-2001, 10:37 PM   #1
seowitz
Member#: 9072
95 Legacy L
puke
Question Where is the Back-up Light Switch???
Does anyone know where the back-up light switch is on a 97 Legacy OB? My back-up lights don't work any more, checked the bulbs and fuses, so that was going to be my next check but I don't know where it is.....
Anyone?
seowitz is offline   Reply With Quote
Old 10-13-2001, 11:24 PM   #2
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
On auto tranies, most of the time, it's on the side of the trany, loke a sensor. On stick shifts, if it is not in the shifter gate, like a micro switch, it is also in the trans side.
A dealer should show you with their Micro-Fische (sp?) machine!
Good Luck!
Leo
Leonardo is offline   Reply With Quote
Old 10-14-2001, 10:44 AM   #3
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
There is a switch on the tranny to check but it's under the car. Best to pick up a Haynes and it will give you some info on how to check it. I have mine in front of me it's for Legacy 1990 - 1998. The ISBN number is 1 56392 326 2 The Haynes number is 89100. I have a 97 OB Legacy LImited and use it all the time. It actually helps me with the RS sometimes too. Lots of similar parts and Torque specs
Peaty
Just checked on Amazon.com: < 14 bucks
http://www.amazon.com/exec/obidos/AS...764806-8840832
Peaty is offline   Reply With Quote
Old 10-14-2001, 01:12 PM   #4
seowitz
Member#: 9072
95 Legacy L
puke
oh, forgot to tell you that I have a 5-speed MY 97 Legacy Outback.
Old 10-16-2001, 06:35 PM   #5
seowitz
Member#: 9072
95 Legacy L
puke
Default help???
Anyone know where it is on this car???
Old 10-16-2001, 06:50 PM   #6
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
The Haynes says:
the back up light switch is located on the left side of the transfer case, the Neutral start switch is also lacated here right behind the back up light switch.
To check the switch put the trans axle into reverse and verify that there is continuity (0 or low resistance) tehn put the transaxle in another gear and verify that there's no continuity)
replacement : Simply unscrew the old switch install the new (make sure the washer is installed and tighten to 16 - 19 ft lbs.
There is a pic here but it's pretty bad, looks like large nut with 2 wires coming out of it. It says to trace back to the connector and do the checking there iwith a meter
Hope this helps
Peaty
Old 10-16-2001, 10:27 PM   #7
Jon [in CT]
Member#: 2992
02 WRX Sedan
Here's the pic from the Haynes manual that Peaty mentioned:
Jon [in CT] is offline   Reply With Quote
Old 10-16-2001, 10:33 PM   #8
seowitz
Member#: 9072
95 Legacy L
puke
Talking
sweet!!!
thanks!!!
Old 10-16-2001, 11:29 PM   #9
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Wow nice job on the scan that looks better than the book...
Old 10-16-2001, 11:30 PM   #10
seowitz
Member#: 9072
95 Legacy L
puke
damn, pics on the book that bad?
Old 10-16-2001, 11:37 PM   #11
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
no not all but this one does that's for sure
Old 10-16-2001, 11:44 PM   #12
seowitz
Member#: 9072
95 Legacy L
puke
Default part number
do you have a part number by chance for the switch?
Old 10-16-2001, 11:50 PM   #13
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
I have a quick reference guide and the part isn't in there. Best to call Sugar (Lisa) from the vendors section. I'm sure she can help.
Peaty
Old 10-16-2001, 11:52 PM   #14
seowitz
Member#: 9072
95 Legacy L
puke
sure...thanks again!
NY: Neutral Position and Back-up Light switches PolarisSnT Drivetrain 3 01-26-2010 06:57 AM
Where is the Interior Light Switch? BMWWRX Electrical & Lighting 1 08-26-2005 12:50 PM
Can I wire my FF1000's up to the useless parking lights switch? MT_WRX Electrical & Lighting 14 11-02-2004 01:43 PM
Where is the Speed Signal wire on the ECU harness and Parking Brake switch sssp Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-12-2004 08:51 PM
Back-up Light Switch svx_commuter Service & Maintenance 1 08-25-2003 10:04 PM
