Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 06-07-2006, 11:28 AM   #1
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Default Anyone running GM boost solenoid with Hydra?
Comments? Experiences?
jblaine is offline   Reply With Quote
Old 06-08-2006, 12:03 PM   #2
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Anything particular you would like to know. I've tuned a few with UTECs and I'm pretty sure I've done at least one with a Hydra. You get more control out of the higher flow solenoids available so you can ramp the boost a little faster without so much spiking.
Element Tuning is offline   Reply With Quote
Old 06-08-2006, 12:58 PM   #3
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Nope, nothing in particular. Just looking for any gotchas or map-specific tips.
Old 06-08-2006, 03:59 PM   #4
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Well, hopefully Phil will be swinging out my way in the near future and I plan to have a GM solenoid on for when he tunes my car. If that works out I will make sure to relay any info that comes out of it.
offset
offset is offline   Reply With Quote
Old 06-11-2006, 03:07 AM   #5
bboy
Member#: 56468
04 Improved STI
Dirty White
I ran a GM solenoid with the Hydra's boost control for about 1000 miles before going to an e-Boost. It works fine. Hydra was pulsing the solenoid directly off of the factory wire (ground). Anything else you want to know?
Old 06-14-2006, 01:15 PM   #6
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Well, I installed it last night.
LOUD solenoid.
Additionally, I barely had to change any boost settings, which is very surprising to me. I reduced PWM map 4 a tiiiiiny bit and that was all.
Old 06-14-2006, 02:02 PM   #7
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
LOUD solenoid.
So have you had time to to do some logging with it yet? Do you find it easier to hit and hold your boost targets now, etc.?
offset
Old 06-14-2006, 02:06 PM   #8
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
I did a little datalogging last night. Using the same settings as pre-GM, I hit ~14.7psi at damn near the same spot as before. I intend to slowly try to improve that, but consider me initially unimpressed.
Old 06-14-2006, 03:09 PM   #9
Element Tuning
Member#: 54918
673 WHP Element
jblaine,
Your current boost system was tuned pretty well so it's going to be hard to see major improvements. Try increasing the "integral" to see if you can net an improvenent in spoolup without the spiking. If you start to spike right off the bat it's unlikely the GM solenoid will be an improvement. You can also increase the higher load sites of PWM Map 4 (70% to 100%) also for faster ramp up. Don't forget to monitor is it holds boost a little better as it has a slightly better flow rate.
Thanks,
Phil
www.elementtuning.com
Old 06-16-2006, 11:10 AM   #10
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Hmm.
Need a little help.
Please see page 4: http://forums.nasioc.com/forums/showthread.php?t=870619
Basically the solenoid is active at idle. Boost start is set to 1900RPM as it always has been. What am I doing wrong?
Old 06-16-2006, 11:11 AM   #11
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Old 06-18-2006, 11:30 PM   #12
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Anybody? Hoping someone has experienced this with the Hydra + GM solenoid and has an easy answer.
Doesn't make any sense to me. Wired either way, I get the same results.
Old 06-19-2006, 10:22 AM   #13
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Fixed.
You MUST set the 0% cell in PWM Map 4 to 0 in order to get the solenoid to be off at idle.
Which begs the question: How many people are riding around with Hydras and stock solenoids that are wearing out like mad because they're quiet but being energized.
Old 06-19-2006, 10:22 AM   #14
Element Tuning
Member#: 54918
673 WHP Element
Try setting the boost control map (PWM Map 4) to 0 in the 0% load cell.
Thanks,
Phil
Old 06-19-2006, 10:53 AM   #15
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Laugh. Simultaneous posting?
Old 10-02-2006, 04:36 AM   #16
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
any updates Jblaine?
I still have my GM solenoid from my link + i planned on using...I really dont want to go buy another boost controller
my setup
GT35R
built motor
P&P heads
stock header
custom catless uppipe
anyone who knows anything, please pipe in to help me out
thanks
alex
Old 10-02-2006, 08:46 AM   #17
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
No updates. Mine's working fine.
Old 10-03-2006, 08:22 AM   #18
Master-P
Member#: 119743
04 STI
jblaine - is this a worthwhile modification? Thanks!
Master-P is offline   Reply With Quote
Old 10-03-2006, 08:32 AM   #19
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Well, others swear by it.
I did mine because it was cheap and my OEM boost control solenoid had 55,000 miles on it.
It bought me very very little.
Old 10-03-2006, 08:39 AM   #20
Master-P
Member#: 119743
04 STI
Right now I am currently working through trying to just get control of my boost. I am awaiting a new wastegate actuator, as I apparently have a 19psi one. I currently have the pressure port on the compressor housing plumbed directly to port on the actuator, which should net the lowest possible boost setting. I hold 21-22psi, but would like to knock it down a bit (once I get the new actuator).
I realize there will be negligible power gains (if any), but do you feel you have better control of your boost?
Thanks for any insight.
Old 10-06-2006, 04:32 PM   #21
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Couldn't really say. I threw it on as a cheap "why not" mod given that my stock BCS had 45,000 miles of salt and hell exposure. The mechanism is more optimal to me than the stock one.
I don't really have problems controlling my boost at all. I'm running 18-20-18psi as a general boost curve.
Old 10-11-2006, 04:48 AM   #22
THE-95-STi
Member#: 113734
2oo3 Vdub 1.8T
Subaruless(MAIC4LIFE)
I'm using the Turbosmart Eboost2, its a boost guage/controller, and for the price I got it at I completely happy with it, you can control waste gate sensitvity, 6 boost settings
THE-95-STi is offline   Reply With Quote
Running gm boost solenoid and perrrin y-pipe on V1 vf39 map lotarg AccessPort 1 01-03-2010 09:35 PM
New gm boost solenoid with pigtail CTKNY Engine/Power/Exhaust 1 12-04-2008 01:46 PM
anyone have GM boost control solenoid? watercooled Texas Impreza Club Forum -- TXIC 8 12-28-2007 03:47 PM
Anyone install/tune GM Boost Solenoid? fluxcapacitor Southern California Impreza Club Forum -- SCIC 4 12-10-2007 01:50 AM
What do I need to adjust on my EM to run the GM Boost Solenoid mrtrex Engine Management & Tuning 6 11-14-2005 12:00 PM
