Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Interior/Dressup/Audio & Security
Closed Thread
Old 06-07-2006, 04:53 PM   #1
Turn in Concepts
Vendor Sales Rating: (159)
Member#: 93646
Many Track Records
Let us help you go fast!
Default Two lightly used PSI3 standard units for sale (US only)
Guys -
We have two lightly used Psi3 standard VFD DIN units available for sale. One is out of my car, and the other is out of Tony's. We each had these in our personal cars for about two months until we got the new graphical units in to play with. Please note these are NOT the graphical units, but the older style standard display.
Both are for the DIN mount setup. The first one has a blue display, black face, and blue buttons. The second has a green display, carbon fiber face, and black buttons. Included with each is the the OBDII cable, but do NOT come with any external sensors (those stayed on the cars). If you need the external sensors you will have to pick them up.
Price is set at $450 each. If you are interested in one of these PM us. We will not hold them for anybody, and it's first come, first served.
Here's a pic to give you an idea:
To give you an idea of what they do, here's the description from our site:
The Psi3 ECU monitor is a device designed to monitor the sensors and operation of the vehicle engine management system, and assist the driver with performance information and useful diagnostic information when a fault occurs.
The monitor reads its information directly from the vehcle ECU via a bi-directional serial communications link via the OBD-II connector and updates the display data approximately five times every second. The user is able to customize the data points displayed based upon personal preferences. The data is displayed on a 2x24 character vacuum fluorescent display, and is controlled by four buttons. The unit does not interfere with the operaiton of the vehicle in any way (except ECU reset function).
Here are some of the data points that are monitored by the Psi3 unit.
* Boost Pressure (BAR or PSI)
* Intake air temp (C or F) This is NOT charge temp
* Coolant temp (C or F)
* Engine speed (RPM)
* Battery volts
* Throttle Position % (some cars have limited range EG 5-85%)
* Road speed (KPH or MPH)
* Ignition advance (deg. BTDC)
* Air flow (Grams/sec)
* Lambda Ratio
* Knock correction degrees
* Injector duration (milliseconds)
* Exhuast gas temp (WRX only, stock EGT probe only)
* Time of day
* Oil temp (requires external sensor kit)
* Oil pressure (requires external sensor kit)
Additionally the monitor will display:
* Peak boost
* Peak coolant temp
* Peak RPM
* Peak road speed
In additon to monitoring all that data you also get all sorts of other cool features such as user definable alarms for the following:
* Low battery voltage
* High battery voltage
* Overboost condition
* High coolant temp
* High oil temp
* Low oil pressure
On top of all that you can set the unit up to for a shift light, automatic water/methanol spray control (many folks use this for automatic I/C spray), displaying CEL codes, and resetting the ECU. Shift light and spray control require external relays and parts.
Turn in Concepts is offline
Old 06-09-2006, 04:18 PM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Both units are still available.
Old 06-11-2006, 06:30 PM   #3
1-3-2-4
Member Sales Rating: (18)
Member#: 100762
2012 WRX Hatch
14 FZ09, 03 VFR, 09 WR250
Do you guys have any pictures of how exactly they mount in the DIN opening? Its probably a non-issue, I'm just curious. Does it just bolt in like the factory DIN shelf?
EDIT: Do you have a picture of the green display w/ the carbon face?
1-3-2-4 is offline
Old 06-12-2006, 04:58 PM   #4
Turn in Concepts
Member#: 93646
Many Track Records
Actually, the enclosure for the DIN is THE Subaru DIN pocket so it will fit and bolt up exactly like the one you have in there currently.
I know Tony has a pic of the CF one floating around. I'll see if I can find it.
Old 06-12-2006, 05:00 PM   #5
Turn in Concepts
Member#: 93646
Many Track Records
Here's a quick camera phone pic Tony took a while back.
Old 06-12-2006, 10:08 PM   #6
1-3-2-4
Member#: 100762
2012 WRX Hatch
Thanks for the pic. One more question though...is it possible to autodim this at night or is it only one brightness level all the time?
1-3-2-4 is offline
Old 06-27-2006, 11:05 AM   #7
Turn in Concepts
Member#: 93646
Many Track Records
No autodim - while you can set the brightness level you must do it though the menu. In my opinion they are not bad at night even on full brightness.
Old 06-27-2006, 11:06 AM   #8
Turn in Concepts
Member#: 93646
Many Track Records
Oh, and we still have these.
Old 06-27-2006, 11:14 AM   #9
BlackSnake
Member Sales Rating: (7)
Member#: 42850
WTB 04-07 STI
Roller/Blown Engine
Does it work with the AP?
BlackSnake is offline
Old 06-27-2006, 11:44 AM   #10
Turn in Concepts
Member#: 93646
Many Track Records
yes it does - both Tony and I use the AP in our own rides. Now, keep in mind that this plugs into the obdII port so if you drive around with your AP plugged in you won't be able to do that. Besides this will do what the AP can in regards to reading boost, reading codes, and resetting the ECU so the only time you really need to unhook it is to reflash.
Old 07-10-2006, 05:13 PM   #11
Turn in Concepts
Member#: 93646
Many Track Records
Still got 'em.
Closed Thread
perrin big maf- lightly used perrin standard size maf filter sti charles Engine/Power/Exhaust 8 09-01-2008 09:20 AM
TWO USED IHI VF-30's for sale - $250 each bmw50021 Engine/Power/Exhaust 5 04-14-2007 05:02 AM
For Sale (SLC only) "slightly" used Greddy front lip (gc8) ibis Rocky Mountains Impreza Club Forum -- RMIC 4 05-02-2003 08:19 AM
FS : Two lightly used Kumho Ecsta V700s, 225/50R16, $100 Impala SS AutoXer Bay Area Impreza Club Forum -- BAIC 1 12-05-2002 04:39 PM
US/fr bumper AMBER turning lights for SALE, (Vancouver Only) estovir Vancouver Impreza Club Forum -- VIC 0 03-29-2000 12:53 AM
