Old 06-07-2006, 07:56 PM   #1
eatus ravenous
Member#: 26068
Default info on turbo spool characteristics
I would like firsthand info between the following thanks
VF34, when spool starts, when max boost is achieved , what is max safe psi
VF22 ..................................same ...........................................
TD0516g ................................same.............. ................................
TD05 super16g deadbolt ..................same .....................................
and is there any benifit to running an external waste gate with this small of a turbo thanks in advance
eatus ravenous is offline   Reply With Quote
Old 06-07-2006, 09:36 PM   #2
kcook
Member#: 78074
2005 STi
yeah , u hold the same amount of boost in 3rd,4th,5th , theres no 12 psi , 14 psi , 17 psi ... its all the same. you will also get no overboosting or spiking
kcook is offline   Reply With Quote
Old 06-07-2006, 09:46 PM   #3
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
It depends on your tuner I'm sorry to say as there's no perfect answer. I was going to tackle this question with all turbos at one time, but somewhat gave up. Reason being with Tuner A you can get a VF22 at full boost at 3500 RPM and with Tuner B it will be 2800 RPM. It can be due to a customer's wishes and/or the tuner's skill so there is really no fixed RPM and you also have to consider supporting mods that add to the googplex of variables.
Question on turbo spool wrxrex Newbies & FAQs 24 08-03-2007 03:44 PM
Info on turbos for the average joe...? wrx-oni Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-12-2002 04:38 AM
any info on turbo xs upipe djrocker666 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-25-2002 11:14 PM
where is a place that sells/has info on turbos for the RS? Matey Normally Aspirated with bolt-on Forced Induction Powertrain 8 07-05-2001 04:55 PM
Info on turbo lag IMPRZAMNSTR Normally Aspirated Powertrain 0 03-02-2001 11:02 AM
