Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 10-14-2001, 03:02 AM   #1
impRSa01
Member#: 4411
2001 Impreza 2.5 RS
Default Hoodscoop_seeled_intercooler
Would it make sense to have aluminum walls welded to all four sides of the intercooler. Then, on the top of the walls, use some sort of weather stripping to get it to seel as good as possible to the hoodscoop. That way all you get is cold air from outside. I never heard of this being done.
I know some of you are going to say it will pressurize the crankcase or something like that. Obviously it is not going to be seeled the best, but it will probably get about 80+% outside air. Redline Engineering in Florida said they would see what they could do. Also, do you think I should get the GT25 or a T3 specked out to flow like the t3/t4, but better spoolup. Keep in mind, I only am going to run 8psi max in the future, and 5psi for now.
Any other suggestions, let me know. Kevin
impRSa01 is offline   Reply With Quote
Old 10-14-2001, 03:10 AM   #2
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
See the stock duct under the hood scoop in the WRX.
Ben
bsquare is offline   Reply With Quote
Old 10-14-2001, 03:36 AM   #3
zaidallas
Member#: 4106
I did this on my old turbo setup. I couldn't use the stock WRX shield since it didn't match up right with my IC so I had to rely on a home depot style rig-up . when I tesed it with the haltec , it showed a decrease of about 7 degrees at 60 mph . It didn't look too good from inside the engine bay but you couldn't see it from the outside. it did the job for a while but for in-city driving ,
a TMIC is just hard to keep cool.
zaidoun
zaidallas is offline   Reply With Quote
Old 10-14-2001, 03:48 AM   #4
Andrew
Member#: 1170
2005 STi
T28 shoudl be plenty for 5-8psi with quick spool up.
Andrew is offline   Reply With Quote
Old 10-14-2001, 04:29 AM   #5
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
zaidun: the 7 degrees, is that F or Celsious?
Chad
93 1.8T
subachad is offline   Reply With Quote
Old 10-14-2001, 05:13 AM   #6
bsquare
Member#: 1911
2000 Impreza 2.5RS
He's in Texas, it's Fahrenheit (not Celsius...as in Anders Celsius, the Swedish astronomer who invented that temperature scale...not to be confused with Celsious, which I guess would be having the property of being Celsy, whatever that means...).
Ben
Old 10-14-2001, 05:29 AM   #7
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
makes sense to me. That's how it's done on the rex, will be better off using a heavy rubber condom(excuse teh term) like the rex has around the edge of the scoop.
jeremy
