Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Complete Car Part-Out
Old 06-07-2006, 11:53 PM   #1
Aspen_2.5RS
Member Sales Rating: (473)
Member#: 3310
Default FS: Huge Part out of 02 Salvaged WRX! parts galore.
Edit: 12/29/07 Read this first post before even thinking about pm'ing me.
STOCK PARTS PARTS PARTS AND MORE PARTS!!!!!
This is a part out of an 02 psm wrx salvaged sedan. Please check below to make sure the part isn't sold below before you ask about it.
2002 Subaru WRX
Silver exterior/black interior
Mileage: 21,175
You can pm me, post here, or email me for parts. As far as costs, expect about 50% of what parts cost new for most stuff + shipping (sometimes less), unless Subaru wanted a ridiculous amount for something new, then we'll figure something out. Preference or dibs on parts will be given to locals (or if you can pick it up).
I've put together a list to give you an idea of what parts you can expect to be bad. Here is a list of what I know that is either:
Damaged or Unusable
-driver sideskirt tabs are broken
-driver side front control arm is broken/bent
-steering rack/tie rod end on driver front is bent
-driver side rear lateral link is bent
-passenger front & rear doors are scratched and lightly dented
-all plastic cam gears are unavailable
-passenger side head is chewed up due to broken valve
-piston #3 in the block is chewed up on the face
-timing belt covers are all broken
-a/c tensioner pulley is cracked
-radiator/condenser/fans are all unusable
-headlights are busted
-foglights are busted
-front bumper/hood/grill/fenders are all messed up
-washer overflow container is busted
-windshield washer fluid reservoir is dented/unusable
-oil fill on valve cover is broken
-clutch slave cylinder/bracket is broken
-glovebox handle has broken off
-front sway is bent
-both driver and passenger front airbags have been deployed
-muffler is beat up some
-passenger front seatbelt does not retract
-xmember is bent
-oil pan is dented in a few places
-2 coilpacks have cracks on the boots (battery leaked on them)
-a/c compressor took a hit and doesn't turn freely all the way around
-driver rear door has some light scratches on it, but otherwise is good
-headliner was damaged while pulling it out (oops)
-front 02 sensor
Available parts (if you don't see it in any of the lists, ask):
-door panels (cards)
-cluster bezel (cluster surround)
-camshaft sensor
-spare tire/rim
-stock crank pulley
-misc. heatshields
-cruise control unit
-95L fans (from last swapped car)
-miscellaneous trim pieces
-dash
-power mirror controls
-speakers/tweaters
-rear floormats
-trunk/gas tank release parts
-windshield wiper motor
-power lock and window motors
-cowl cover in front of windshield
-door glass (all door glass available minus passenger front, driver front glass, driver rear glass, passenger rear glass)
-oil fill cap
-coolant temp sensor (1 used)
-psm fuel door
-gas cap
-fuel rails
-2 center consoles (pick up only)
-2 rear deck covers (pick up only)
-switches
-cams
-2 sets of wrx carpet (pick up only)
-passenger side head has a broken valve and the head is chewed up), short block is good other than #3 piston which took a hit from the valves (I think a rehone and new piston would fix it up - or bore it out and put some forged pistons in), etc. etc etc. etc. If you don't see it on the sold/pending list, ask me and I might have it.
SOLD or PENDING SALE PARTS
-trim around center vents, center vents, and 2 silver vent trim rings - SOLD -DrinkaV8
-boost solenoid, bracketry, cover, twists for cover, & covers for wipers - SOLD- Pacobeagle
-transmission - SOLD - Dao
-turbo, uppipe, intercooler, bypass valve w/ hoses, injectors, fuel pump, rear sway, end links, & mounting brackets - SOLD -Drew
-inlet tube - SOLD - ein86
-shift boot - SOLD - Stegall
-one tgv (driver front) - SOLD - brianj
-hood scoop with hardware - SOLD - IronmonkeyL255
-fuel controller - SOLD- Jeff25RSti
-Big ass plastic piece directly in front of driver's knees/under steering wheel - SOLD - Biggly
-tube that goes to the stock airbox (the flat open piece that starts above the grill and then goes to the fender) -SOLD- Biggly
- rear tow eyelet - SOLD - Biggly
-Cup holder (silver) - SOLD - Biggly
-Trunk floor/carpet (basically most of the trunk interior that isn't metal) - SOLD - Biggly
-radio trim, coolant reservoir on engine, & glovebox - SOLD- strohausii
-jack, spare hold down, and pouch with tools - SOLD - ohhello
-autodimming mirror with harness - SOLD - andivic
-rear seatbelt on the driver side - SOLD - Ritky
-2 coilpacks (the other 2 are probably bad b/c the boots are cracked) - SOLD - farulz
-plastic that holds and surrounds the shift boot - SOLD - Joshua
-fog light button - SOLD - Joshua
-bulk wiring harness/front harness - SOLD - ituner
-pedal assembly (clutch/brake/accel) - SOLD - suberdave
-axle back - SOLD - Carnot
-washer fluid cap - SOLD - Travis
-wiper stalk - SOLD - lektro808
-power steering pump - SOLD - Wes
-front seats with brackets/bolts - SOLD - Dowroa
-high pressure a/c cap - SOLD - William
-driver side mirror and bolt covers for seats - SOLD - STi-JDM
-gauge cluster - SOLD - timmyp
-intake manifold (top portion) - SOLD- Shane
-power steering reservoir - SOLD - Calvin
-carpet clip for driver side - SOLD - Kax
-rear passenger tgv sensor - SOLD - dingobite
-clock/pod - SOLD - Ryan
-passenger front power window switch - SOLD - Tate
-rear calipers w/ pads - SOLD - RJ
-rear 02 sensor - SOLD - Robert
-maf, power steering lines, throttle cable - SOLD - Shu
-front calipers - SOLD - sanchez
-rear rubber fender liners - SOLD - 7ast129
-dead pedal clips and 2 blanks from the center console - SOLD - Matt
-interior door handles with trim - SOLD - Brent
-passenger side mirror with trim piece/rubber triangle - SOLD - Joseph
-trim piece in front of driver rear tire - SOLD - Shane
-a/c line from firewall to compressor - SOLD - John
-ecu - SOLD - Jamie
-passenger side front seatbelt male end tab - SOLD - Rob
-sideskirts - SOLD - Jeremy
-rear differential - SOLD - Sam
-driver front seatbelt - SOLD - Stuart
-ashtray - SOLD - Ryan
-passenger side front window, weatherstripping for front window (and rear), black trim piece between the passenger side windows, black plastic insert under the gas cap, rear driver side interior door panel, rear subframe - SOLD - Jeremy
-hvac controls - SOLD - Capt Crunch
-rear seat - SOLD - Andrew
-passenger side front control arm, passenger side rear lateral links, passenger side rear trailing arm - SOLD - Richard
-front axle assembly - SOLD - Matt
-rear wrx hub/knuckle assemblies - SOLD - Abel
-passenger front hub/knuckle assembly - SOLD - Richard
-2 pink door card clips and the clips that hold the plastic trim piece in by the driver's right foot - SOLD - Bryce
-stock airbox, hose from airbox to inlet pipe, silencer, and hardware - SOLD - Justin
-oil line that runs from the top of the turbo to the head - SOLD - Jose
-right rear window switch with trim - SOLD - David
-uppipe support brackets - SOLD - John
-Idle air control sensor - SOLD - Joshua
-driver side front floormat holder clip - SOLD - Kenneth
-crankshaft sensor - SOLD - Michael
-hose from inlet pipe to block breather and hose from pass. side valve cover to intercooler tube on pass. side - SOLD - Jose
-wiring to charcoal canister (black box at rear of car) - SOLD - Phillip
-sensor that bolts to the intake manifold, has 2 vaccum lines running to it - SOLD - Steven
-intercooler brackets w/ bolts - SOLD - Kent
-engine harness - SOLD - Troy
-BBS wheels with tires - SOLD- Zack
-master cylinder and brake booster - SOLD- Juan
-driver side a-pillar trim - SOLD- Dustin
-rear passenger door sill plate and both top sections of the c-pillar trim -SOLD- Greg
-steering wheel rim -SOLD- Bryan
-6 disc changer -SOLD- Scott
-Passenger front window, ABS unit with bracket, sun visors, dome light, and map lights -SOLD- Marcin
-passenger side window switch -SOLD- Steven
-clutch, pressure plate, & t.o. bearing -SOLD- Alex
-passenger rear door and wiper transmission assembly -SOLD- Sean
-upper steering column trim -SOLD- Anthony
-driver side front window switch trim -SOLD- Benjamin
-3rd brake light -SOLD- Ken
-wingless trunk-SOLD- Shawn
-timing belt tensioner and 2 idler wheels/bearings -SOLD- Ron
-center console lid and hardware -SOLD - Michael
-combination switch for headlights/turn signals -SOLD - Michael
-rear diff protector w/ hardware -SOLD - Richard
-stock downpipe (w/o after cat section) -SOLD - Matthew
- waterpump w/ neck and shift knob -SOLD - Scott
-cam caps for both heads w/bolts -SOLD - Jeremy
-middle sunvisor -SOLD - Alan
-driver side head w/o cams -SOLD - Ron
-tgv manifold runners -SOLD - Josh
-throttle body-SOLD -Aba
-3rd catalytic converter -SOLD- Carl
-hvac underdash boxes (heater core/blower etc.)-SOLD- Stephan
-driver side front and rear door horizontal black trim -SOLD- Luis
-driver side front door and window-SOLD- Crisco
-taillights -SOLD- Justin
-exhaust manifolds & crossover pipe -SOLD- Shyloh
-front floor mats - SOLD- Dan
-window trim (goes over windows) pass & driver and driver side vertical trim piece between the windows -SOLD- crisco
-top steering column plastic-SOLD- James
-flywheel w/bolts-SOLD-Peter
-hazard switch -SOLD- Bill
-windshield washer motor-SOLD-Andy
-rear axles -SOLD- Ivan
-alternator -SOLD- Matt
-TPS -SOLD- Johnny
-ebrake cables, rear brake shoes, all springs/spacers/adjusters (hardware) for back brakes -SOLD- David
-valve covers -SOLD- Matt
-driver rear door -SOLD- Chuck
Thanks,
Cam
More pics below:
Last edited by Aspen_2.5RS; 06-09-2008 at 10:01 PM. Reason: updated parts list 6/9/08
Aspen_2.5RS is offline   Reply With Quote
Old 06-08-2006, 12:01 AM   #2
ohHello
Member Sales Rating: (2)
Member#: 80217
2002 wrx
blaze yellow
Do you have the piece that holds down the spare tire, i think its like a hook or somehting, and also the stock jack? PM me if you got them, thanks -mike
ohHello is offline   Reply With Quote
Old 06-08-2006, 12:06 AM   #3
Aspen_2.5RS
Member#: 3310
Got them, sending you a pm.
Cam
More pics of parts (updated):
Some of the trim parts left over (but not all)
clutch fluid reservoir/mastercylinder SOLD etc...
cruise control unit, proportioning valve, etc..
Last edited by Aspen_2.5RS; 12-29-2007 at 01:21 AM. Reason: Added pics to show some of what is left
Old 06-08-2006, 12:17 AM   #4
sk84fun21
Member Sales Rating: (38)
Member#: 113300
WRB, LOUD
what about the screw that holds the jack in place?
sk84fun21 is offline   Reply With Quote
Old 06-08-2006, 12:22 AM   #5
deadred
Member Sales Rating: (7)
Member#: 87772
02 wrx
was the master cylinder damaged?
deadred is offline   Reply With Quote
Old 06-08-2006, 12:25 AM   #6
Aspen_2.5RS
Member#: 3310
sk8fun21, I have the screw that holds the jack in place (if there is one, thought the jack held itself in). Shoot me a pm.
deadred, the master cylinder is good to go. Shoot me a pm. I assume you want the brake booster as well.
Cam
Last edited by Aspen_2.5RS; 01-11-2007 at 11:58 PM. Reason: almost everything was sold in the pics
Old 06-08-2006, 12:27 AM   #7
Pacobeagle
Member#: 8775
2010 "Zed" 1000
Orange/White
Yup, i'm here. Where do I send $$. Oh, how much for these items? One more thing....possibly interested in the tranny. What condition is it in? Can you shift through the gears?
Pacobeagle is offline   Reply With Quote
Old 06-08-2006, 12:35 AM   #8
Aspen_2.5RS
Member#: 3310
Pacobeagle1, please send me a pm with exactly what you need.
Anyway, just send me a very detailed list so I know exactly what to send and we'll come up with a price.
Trans is sold pending payment tomorrow night.
Cam
More pics:
ej205 short block
ej205 shortblock - damaged piston
only the shortblock remains
Old 06-08-2006, 01:10 AM   #9
recce02
Member Sales Rating: (21)
Member#: 13815
02 GCRally prepped
277TQ 281HP 19PSI
Wondering how much for the passanger air bag cover. I know it is blown just looking to fill the void in mine as i have a rally computer hooked up and just a gaping hole in my dash.
Peace out
Marvin
Gravel Crew Rally Team USA
recce02 is offline   Reply With Quote
Old 06-08-2006, 01:16 AM   #10
Aspen_2.5RS
Member#: 3310
recce02, probably like $15 shipped since you're in CA. Let me know.
Cam
More pics:
passenger rear door sold without glass
driver rear door (has 2 very light scratches that you have to look for)
valvecover and cams
Old 06-08-2006, 01:39 AM   #11
DrBiggly
Member Sales Rating: (6)
Member#: 11482
02 WRX
Acute Stickeritis
Cam,
For interior pieces I'd like:
1) Armrest extension bit
2) Left rear door panel
3) Big ass plastic piece directly in front of driver's knees/under steering wheel
4) Cup holder (is that already taken? Is it in silver I think?)
5) Trunk floor/carpet (basically most of the trunk interior that isn't metal)
6) Are the rear lateral links damaged?
Thanks man! (Send a PM with all the info)
-Biggly
DrBiggly is offline   Reply With Quote
Old 06-08-2006, 01:59 AM   #12
Aspen_2.5RS
Member#: 3310
Pm'd you.
Cam
More pics:
rear axles/undercarriage parts
miscellaneous clips/bolts/power lock and window motors inside the doors
Bulk harness is SOLD, but other parts in the pic are available
Old 06-08-2006, 02:27 AM   #13
Left coast STi
Member#: 71049
'05 WRX STi AVO500
AW on gold GC05f's
pm'd you..
Left coast STi is offline   Reply With Quote
Old 06-08-2006, 02:27 AM   #14
nguyen925
Member#: 117033
lol i saw this on ebay, gl with the sale.
nguyen925 is offline   Reply With Quote
Old 06-08-2006, 03:24 AM   #15
calmnothing
Member Sales Rating: (14)
Member#: 75053
If the seats aren't sold I'd be interested in them.
calmnothing is offline   Reply With Quote
Old 06-08-2006, 03:48 AM   #16
sk84fun21
Member#: 113300
WRB, LOUD
also how much for the box cover taht sits right behind the intake box? my wrx is missing it? also the screw that holds the pop out cupholder in? if you have the carbonfiber trim inside how bout the housing that hold the pop-out cup holder (i need the small piece next to the cupholder to cut soo i can mount a TT there)? finally one of the squares next to the fog light/cruise control switch? thanks
Old 06-08-2006, 07:26 AM   #17
Junglist
Member Sales Rating: (15)
Member#: 110035
2002 Built Hybrid
MBP
PM sent
Junglist is offline   Reply With Quote
Old 06-08-2006, 07:34 AM   #18
Aspen_2.5RS
Member#: 3310
Left coast sti, checking and will reply.
nguyen925, yeah, I wish someone had bought it as a whole.
calmnothing, If spoonfedb18a1 falls through, I'll let you know.
sk84fun21 - the box cover that covers the solenoid is pending to Pacobeagle right now. The screw that holds the pop out cupholder is pending to Biggly since it will go with the cupholder. This car doesn't have the carbon fiber trim. I do have an extra square that goes next to the cruise/fogs.
Junglist, checking and will reply.
Everyone please be patient with me as there are only so many things I will be able to take off and ship each day. I'm only one person, not a business. Thanks.
dang it's too early for this ish...
Cam
Old 06-08-2006, 08:02 AM   #19
anthonyrb98
Member Sales Rating: (185)
Member#: 48307
02 bugeye
hbspeed tuned 18g sleeper
can i have the stock fuse box cover if it is still in good condition? also, the trunk board that covers the spare tire well and the carpet liner on top of it as well? pm me please! thanks! what's the condition of the passenger side rear door?
anthonyrb98 is offline   Reply With Quote
Old 06-08-2006, 08:02 AM   #20
anthonyrb98
Member#: 48307
02 bugeye
^ stock fuse box cover in the engine bay
Old 06-08-2006, 08:08 AM   #21
Aspen_2.5RS
Member#: 3310
I think that fuse box cover may have been lost in action. The carpet liner is pending sale to Biggly.
The passenger rear door doesn't have any dents in it. It does have one ding I think. It also has some scratches. See here for more detailed pics of the body: http://s16.photobucket.com/albums/b2...al&media=image
Cam
Old 06-08-2006, 09:08 AM   #22
anthonyrb98
Member#: 48307
02 bugeye
i'll take the trunk board then...
Old 06-08-2006, 10:54 AM   #23
Aspen_2.5RS
Member#: 3310
Actually Biggly is taking that as well I think. I'm sorry about that.
Cam
Old 06-08-2006, 11:51 AM   #24
unloco187
Member Sales Rating: (10)
Member#: 98467
2002 wrx
pm sent
unloco187 is offline   Reply With Quote
Old 06-08-2006, 12:35 PM   #25
ucbsti
Member Sales Rating: (5)
Member#: 88105
2005 STi
CGM, 2006 GG IX
Interested in
-OEM Jack
-Plastic steering column cover (top portion)
Shipped price to 95134
ucbsti is offline   Reply With Quote
02 salvage wrx part out bugeye1 Complete Car Part-Out 74 01-10-2007 10:25 AM
possible parting out of 02 wrx tommy2hotty Private 'For Sale' Classifieds 38 02-06-2004 11:18 AM
