Old 06-08-2006, 03:11 PM   #1
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Default EJ22t cylinder wall/sleeve thickness...
how thick is the stock EJ22t wall thickness?...does anyone know?...
I've searched and had no look with the key words that I had tried...
anyhow, gathering info for a buy and build...
thanks, Micah
Old 06-08-2006, 04:46 PM   #2
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
There is a ej22 manual here somewhere, maybe you could dig it up there.
http://www.main.experiencetherave.co..._manual_scans/
TyranosaurusWRX is offline   Reply With Quote
Old 06-08-2006, 04:52 PM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Did you see my reply in conversions???
Old 06-09-2006, 03:37 PM   #4
Homemade WRX
Member#: 33782
96 bastard child
yes I did...and I tried replying as my internet took a dump...thanks for the link
Old 06-09-2006, 03:51 PM   #5
Peeblesmx445
Member#: 92202
I will measure mine tonight
Peeblesmx445 is offline   Reply With Quote
Old 06-09-2006, 03:53 PM   #6
Homemade WRX
Member#: 33782
96 bastard child
please do...as the thread I just read didn't give a measurement but talked about what overbores were too big and would cause overheating etc...
Old 06-09-2006, 03:58 PM   #7
Peeblesmx445
Member#: 92202
oops, I just re-read you post for "stock" measurments...my ej22 sleeves are not stock, sorry
Old 06-09-2006, 07:58 PM   #8
Homemade WRX
Member#: 33782
96 bastard child
well your thicknesses will work too...
Old 06-29-2007, 11:38 PM   #9
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
did you ever figure it out ?
anyone have a chart with all the EJ engine cylinder wall thickness ?
IllNastyImpreza is offline   Reply With Quote
Old 06-30-2007, 02:59 AM   #10
subie4me
Member#: 89218
I can tell you from personal experience that you can bore it to 99.5, and drop in a 2.5 phase 1 crank. I run 23 psi all the time. It's on 111 leaded, in a sandrail, but on boost almost all the time. Mine ran for three seasons before I had to sleeve it due to some fuel shortage issues.
subie4me is offline   Reply With Quote
Old 06-30-2007, 03:40 AM   #11
Kosmic
Member#: 99140
GD Racing chassis
Slowly in construction
I just messured 0.355" donno if I took it at the right location.
Kosmic is offline   Reply With Quote
Old 06-30-2007, 07:34 AM   #12
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
I wonder if only the deck is different between the ej22t and ej22...
is the cylinder walls thickness the same ?
Old 06-30-2007, 12:08 PM   #13
Homemade WRX
Member#: 33782
96 bastard child
I never found an answer and have passes on purchasing several EJ22t's....
My next shortblock will most likely be one...
Old 06-30-2007, 12:16 PM   #14
p1prodrive
Member#: 149827
2000 600 bhp p1
sonic blue
i have a ej22 cdb sat on my kitchen table, what do you want measured ?
p1prodrive is offline   Reply With Quote
Old 06-30-2007, 05:24 PM   #15
MJU1983
Member#: 14364
2003 WRX, '06 Armada
05 Vette & 05 STi (sold)
They are pretty thick.....here are a couple pics I took several years ago as a comparison:
2.2 L-
2.5 L STi-
MJU1983 is offline   Reply With Quote
Old 06-30-2007, 11:55 PM   #16
Kosmic
Member#: 99140
GD Racing chassis
Wrong location obviously.
Old 07-01-2007, 12:51 AM   #17
Homemade WRX
Member#: 33782
96 bastard child
not really...the EJ18 is 9mm = 0.354"
Old 07-01-2007, 12:43 PM   #18
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
so its prolly a tad smaller than that...
Old 07-01-2007, 05:36 PM   #19
Kosmic
Member#: 99140
GD Racing chassis
That is where I took my thickness measurement. EJ22T wall thickness 0.355"
Old 07-01-2007, 06:01 PM   #20
SaabTuner
Member#: 67608
Sucks that with 9mm~ish wall thickness, and 113mm bore spacing, Subaru still went with siamese'd cylinders. It'd be nice to have a little coolant flow between them for det. resistance.
SaabTuner is offline   Reply With Quote
Old 07-01-2007, 08:16 PM   #21
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
another reason I went with my phase 2 cobb block...(fully closed deck...but still retains most of the ej25 coolant passages ...but I sleeved it anyway
Old 07-03-2007, 10:58 PM   #22
cellobro
RIP 3/18/1965 to 1/10/2008
Member#: 91500
hmmm sr-30+640cc=?
I has teh Endless BBK.
in my faves...
cellobro is offline   Reply With Quote
Old 07-03-2007, 11:04 PM   #23
Homemade WRX
Member#: 33782
96 bastard child
yeah, but it does get a pretty good job of getting the passage in the crack to cool the wall.
I'm glad they did make it siamese leaving more room for bore...especially as we have such little stroke.
Old 07-03-2007, 11:31 PM   #24
cellobro
Member#: 91500
hmmm sr-30+640cc=?
favorited...
Old 07-04-2007, 07:37 AM   #25
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
I once cut up an early EJ20 open deck block and sleeve thickness was 2.5 mm.
Marnix is offline   Reply With Quote
Blown head gaskets, warped heads and a piston melted to the cylinder wall Borjaq Warranty Issues & SOA Problems 13 05-22-2010 10:16 PM
ej22t bore or sleeve? tonzo Built Motor Discussion 9 05-31-2006 11:56 AM
Piston to cylinder wall clearance? biknman Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 129 03-19-2006 11:53 AM
Cracked Cylinder Wall, Help With Swap Options! superjdk Newbies & FAQs 1 09-08-2005 01:05 PM
Question About Cylinder Walls. BlackoutWRX General Community 9 06-02-2005 05:16 AM
