Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 03-28-2001, 05:49 AM   #1
White Knight
Member#: 2864
'05 Legacy GT Wagon
Limited Red
Angry Head light & fog light problem
This morning on my way to work I noticed that the light on my foglight button was not working, and also the foglighs. I know the fuss is still good. Plus these are factory fogs. Now with the Head light problem. The passenger light is dim. So I took it out to see the problem, and both the high, and low beam filament were on.(but the bulb was vary dim) The drivers side head light works fine. So I switched bulbs, and got the same thing. Expect that the passengers side did not work on high beams. So if anyone could help, I will be going out to my car at lunch to try to fix this before tonight.
thanks all
White Knight is offline   Reply With Quote
Old 03-28-2001, 07:04 AM   #2
euroauto
Member#: 249
05 FXT psm
12 R350
Post
Check the body grounds in the lamp area.
euroauto is offline   Reply With Quote
Old 03-28-2001, 04:29 PM   #3
rrubel
Member#: 4643
2008 Legacy Outback
Atlantic Blue Pearl
Post
I just fixed this exact problem. Did you check all the fuses? In the underhood fusebox, there's a pair of fuses on the right (next to the relays for the headlamps) that control the right- and left-side beams. One of the fuses had blown, and this was keeping the fog lights from working and also making the high-beam indicator glow faintly. It turned out that the blown fuse was caused by a short in the wiring harness on the left bulb where the socket had frayed and two wires touched. I run high-wattage bulbs and at one point had melted the original harness so this was probably my cause.
rrubel is offline   Reply With Quote
Old 03-29-2001, 06:01 AM   #4
White Knight
Member#: 2864
'05 Legacy GT Wagon
Limited Red
Talking
Thank all who replied to my post. Yes (rrubel) you had it right, my fuse had blown. So now I'm a happy man again.
Thanks again for all the help!
Old 03-29-2001, 06:27 PM   #5
rrubel
Member#: 4643
2008 Legacy Outback
Atlantic Blue Pearl
Post
You're quite welcome! Now hopefully it won't blow again... which would mean a short.
FS/NNJ: 04/05 WRX/RS Head lights, CGM Fog light bezel Kaze Exterior/Styling 17 08-11-2006 12:11 PM
HELP! WTB:99 Legacy GT head lights & Fogs pimphand Legacy Forum 3 02-11-2005 11:11 PM
FS: WRX: swaybars, Samco, Head & Fog Light, etc: On my way from El Paso to Toronto! Sir_Xenon Private 'For Sale' Classifieds 23 12-02-2004 05:07 PM
WTB: BD/BG fog light & fog insert Gator GT Private 'Wanted' Classifieds 11 11-09-2004 12:27 PM
Fog Lights & Parking Light Switch RXTC Electrical & Lighting 0 06-13-2004 12:34 AM
