Old 10-14-2001, 03:47 PM   #1
MrBean85
Member#: 4452
92 Legacy L sedan
Winestone
Default Finally got it home
On Friday afternoon, my dad picked the 95 Legacy up from the dealer. Man is that a nice car. The engine has an oil leak somewhere, the FWD fuse is blown, and the dealer couldn't find tan carpet for the hatch, so its black. Other than that it runs really good, shifts, and looks good for an almost 7 year old car.
MrBean85 is offline   Reply With Quote
Old 10-14-2001, 07:25 PM   #2
Steve 2.5
Member#: 1452
2002 Legacy GT Sedan
Thumbs up
Congratulations! Legacys are good cars.
I just found that out myself.
-Steve
Steve 2.5 is offline   Reply With Quote
Old 10-14-2001, 09:53 PM   #3
rrubel
Member#: 4643
2008 Legacy Outback
Atlantic Blue Pearl
Default Re: Finally got it home
Is this an AWD Legacy? If so, then there should not be a fuse in the FWD socket under the hood. You only put one there (of any rating) if you are using your donut spare or for some other reason need to disable the AWD.
Regarding the engine oil leak, check (in this order): front crank seal, cam seals, valve cover gaskets.
[RICHR]
rrubel is offline   Reply With Quote
Old 10-15-2001, 02:32 PM   #4
MrBean85
Member#: 4452
92 Legacy L sedan
Winestone
Apparently there is a fuse in the fuse holder, (yes it is AWD). I will check it out later for torque binding. I hope that is not the case, but for a $2600, it can't be perfect.
Thanks for the info on the oil leak.
Old 10-15-2001, 03:02 PM   #5
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Default hmmm
So you bought a 95 for $2600 and youre trying to sell either a 90 or 91 Legacy for $2800. I suppose that would be sweet for you. Youre not trying to take advantage of your fellow i-clubbers are you?
subysouth is offline   Reply With Quote
Old 10-15-2001, 08:48 PM   #6
MrBean85
Member#: 4452
92 Legacy L sedan
Winestone
Default torque bind: Final Answer
Well, the AWD is now enabled. There is some "torque bind", when turning. No big deal, at least not at the moment. Dad is going to call around and get some estimates for fixing this problem. Thanks for all help on this subject.
Me taking advantage of fellow i-clubbers? Never! Just moving as we need to. Besides, our driveway is starting to look like a used car lot!
Old 10-16-2001, 08:22 PM   #7
BJamerican
Member#: 5595
2005 Legacy 2.5GT
Satin White Pearl
What exactly is torque bind? Is it that shuddering feeling you get when making sharp turns at slow speeds? What causes torque bind? My car has suddenly started shuddering when turning and manuvering in parking lots. Thanks.
BJamerican is offline   Reply With Quote
Old 10-16-2001, 09:56 PM   #8
MrBean85
Member#: 4452
92 Legacy L sedan
Winestone
From what I gather(correct me if I'm wrong), torque bind is when some seals or something to that effect, go wrong in the rear of the tranny. The symptoms are a shuddering when turning sharply and accelerating at the same time. I think?
Old 10-17-2001, 10:24 PM   #9
rrubel
Member#: 4643
2008 Legacy Outback
Atlantic Blue Pearl
Simply put, binding is when the front and rear are not allowed to freely rotate at different speeds, which is required when turning.
Causes of binding are plentiful (mostly affecting auto transmissions). Here are a few...
1. mismatched/mis-sized or improperly inflated tires.
2. Malfunctioning duty solenoid C, which doesn't let the AWD disengage fully when needed.
3. A groove worn in the output shaft housing which catches the output shaft or lets it slip slightly off-center.
4. A contaminant in the transmission fluid that prevents the clutch plates from sliding freely when the solenoid is disengaged.
I've experienced 1, 3, and 4 between both our automatic cars.
[RICHR]
Just got it home. Z33Knight Newbies & FAQs 50 12-15-2009 02:52 PM
Finally! Finally! got it! 06 wrx dodiox General Community 32 09-25-2005 02:09 AM
I finally got it installed ashtaron14 Vancouver Impreza Club Forum -- VIC 2 05-13-2001 09:22 PM
Finally Got It! gringo North West Impreza Club Forum -- NWIC 0 02-26-2001 04:28 PM
