Old 10-16-2006, 11:10 PM   #251
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I agree with MeanEditor, but I also think I know what Migo meant. For 1 lap there's no reason the N20 car wouldn't be faster. For a 20min session, though? Admittedly, I don't have much concept of how long a bottle of N20 will last, but I would think if you're getting on the giggle gas over and over again lap after lap that it wouldn't last very long, particularly if it's triggered off RPM or TPS.
And taking this a bit further off topic , be advised, MeanEditor, that the overwhelming majority of open track clubs won't allow N20.
Pat
Old 10-17-2006, 12:35 AM   #252
MeanEditor
Member#: 123139
1993 Turbo L Wagon
RED
That is why we have our own private testing ground.
...and at Subiefest we set the rules...
MeanEditor is offline   Reply With Quote
Old 10-17-2006, 07:12 AM   #253
X4 SRT
Member#: 40636
2001 2.5 RS Coupe
If a nitrous car can hit X amount of horsepower and a turbo/supercharged car can hit the same level, and a NA car can hit about 50whp less, the nitrous car would still come in last place if you were to take all four cars around Laguna Seca for 1 lap.
Not completely true. If you were to pit an STi against a Lotus elise on Laguna Seca I would bet on the less powerful elise to take the win. Horsepower is not everything when it comes to racing on the track.
How so? n02 can be activated in a number of ways. Like at WOT, so you can use it up the back straight and the front staight or maybe the spurt from turn 3-4 and then between 5-6 to the kink leading up to the back straight...
Basically you can use it like an on/off switch or you can trigger it based on a set of parameters like TPS, RPM etc. It's not just for drag racing. Although it will be interesting to see how it behaves in a road course setting which is where we will use it.
Yeah nitrous can be activated in a number of ways, but I just don't see how it's going to be very useful on a track. Sure you can use it on the straights, but is that really going to help you that much? Probably not. That and the fact that if you're WOT on those straights, that bottle of nitrous is not going to last you no more than a couple of laps at the very most.
The nice thing about a turbo compared to nitrous when considering these types of racing conditions, is the fact that power and boost is built up gradually. With the nitrous, it's going to be a full on hit at WOT, and is going to put a lot more stress on your drivetrain than a turbo ever would.
Now, I'm not against putting a nitrous set up on a RS. In fact I'm all for it. However I feel, as many others probably do, that if you were to put nitrous on the ZtH car, then that would defeat the whole purpose, and you would have totaly de-railed from the original goal of the ZtH RS. The goal was to beat an STi in drag, track, stoping etc. with a fully built N/A RS. Nitrous is a form of forced induction. Therefore if you had to use nitrous to do it, then you didn't do it on a fully built all motor RS.
Your build as is, is farily impressive. I don't think you got near the power you thought you would,or we hoped you would, but it's still a great improvement over stock. You're now at that point where you have a great base to jump from. It's time to be innovative, and to push the limits. If zzyzx can build a 300chp all motor subaru, then I'm sure you can get fairly close to the same power output. You just have to get beyond the dd friendly cams and head work, and start getting agressive. It's time to do some R&D and see what these motors can really do. IMO I don't see why it's not possible to have one of these motors crank out 100-110hp per litre, and still be driveable on the street.
Hopefully you guys get back on track, and put more into building a great N/A car. Save the nitrous for when you want to make 300+whp.
X4 SRT is offline   Reply With Quote
Old 10-18-2006, 04:03 AM   #254
MeanEditor
Member#: 123139
1993 Turbo L Wagon
RED
Default not forced induction
first off, N02 is NOT forced induction. It is a power adder true, but FI it is not. Forced induction uses an impeller to force more air into the combustion chamber. nitrous is shooting oxygen, essentially, into the engine in an inert form, then when it combines with fuel it basically breaks down so that we have all this 02 in the combustion chamber and BLAMO, more power.
Nitrous is essentially fuel, in a way. Yes, I suppose you are shooting more air into the car via a nozzle, but only in a round about way is that FORCING air in.
The car is still NA, PERIOD.
Secondly, I think the ZZyxz car has proven that our build is just mild.
Anyone notice how much the headwork on that car goes for retail? Over $4,000... for just the heads. That is more than our entire engine and then some. So while we are rolling with a 3500 engine, that other car probably has maybe twice to 2.5 times into the engine what we have. Also, it's a racecar that is not daily driven.
Also as pointed out above, put a 120hp elise vs the STi on the track and buh-by STi. The ZtH car has an amazing chassis/tire package now so it will out-handle an STi no prob.
Also, we aren't racing at Laguna, we are racing at Pacific with LONG straights... I think a little power adder will come in handy.
Old 10-30-2006, 09:09 PM   #255
bsikora
Member#: 125573
2006 2.5i
ProTune by Sean S.
great write up! it helped me out alot thanks!!!
bsikora is offline   Reply With Quote
Old 11-23-2006, 07:53 AM   #256
X4 SRT
Member#: 40636
2001 2.5 RS Coupe
Bump for this thread. Check out this link I found from Cobb from back in the day.
http://forums.nasioc.com/forums/show...bb+header+dyno
Old 04-11-2007, 04:36 AM   #257
SubiFTW
Member#: 138728
MY06 2.5i Impreza
Fantastic write-up. Props to the original writer and all contributers.
SubiFTW is offline   Reply With Quote
Old 04-25-2007, 02:20 AM   #258
silentt
Member#: 119995
2004 Outback XT
Peachy
great write-up, some good responses when sorting through the bull****.
silentt is offline   Reply With Quote
Old 04-25-2007, 07:13 AM   #259
Rally_wgn
Member#: 62629
1996 OBS in Green
2.5 N/A w/ full exhaust
Thanks, its good to see ppl still read this.
Rally_wgn is offline   Reply With Quote
Old 11-26-2007, 03:16 PM   #260
grethi
Member#: 146290
Originally Posted by Rally_wgn View Post
THE SMALL STUFF
PULLEYS AND LIGHTWEIGHT FLYWHEELS
There are other “power” mods that are popular that if anything improve the feel of the car. The lightweight pulley is generally considered a useful mod. It reduces the drag of rotational weight on the crankshaft “releasing” about 3-5hp worth of energy to the wheels. The biggest benefit being better throttle response and faster revving.
Mr Josh sells a pulley for about $75.
Lightweight Flywheels provide the same type of gain as the pulley. It is generally recommended that you don’t do both the flywheel and the pulley as it may cause the car to idle poorly. Some owner report no problems but the recommendation is from knowledgeable sources.
GROUNDING KITS
Paranoid Fabrications sells a nice kit onfor between $35 and $50 depending on the level of wire and fabrication desired. He can be found on www.rs25.com .
THROTTLE BODY SPACER
While not a new concept in N/A performance enhancement, suppliers for this part for the EJ25 seem to be just one. Area1320 sells a EJ25 TB spacer and has dynos on their site showing around 4hp gain.
Noob questions:
I don't suppose anyone can post current contact info for any of these companies/guys?
Does it make a significant difference between a lightweight pulley and a lightweight pulley set?
grethi is offline   Reply With Quote
Old 11-26-2007, 03:42 PM   #261
Major Johnson
Member#: 120705
2007 FXT Sports
World Rally Blue
PF
http://www.camotoy.com/products/index.php
Area1320
http://www.area1320.com/products.html
However, your best bet is to log on to RS25 to contact them. All of their products and services can be had over there as well.
Major Johnson is offline   Reply With Quote
Old 11-26-2007, 03:48 PM   #262
stoney98
Member#: 65888
2010 FXT
PF is on this site, but in Suspension most of the time. You can find him, by company name there.
stoney98 is offline   Reply With Quote
Old 11-26-2007, 03:50 PM   #263
cmiovino
Member#: 134005
2004 WRX Premium
The PF grounding kits are good
I hear the fender braces and stuff are good too.
Old 11-26-2007, 04:30 PM   #264
lh0628
Member#: 138256
2004 FXT
+1 for PF's grounding kit.
lh0628 is offline   Reply With Quote
Old 12-04-2007, 03:38 AM   #265
yellowsnow50
Member#: 162407
1996 Impreza LX
thanks for compiling this list! will definitely look into what you've said, maybe even get one of those upgrades in the near future? very much helpful!
yellowsnow50 is offline   Reply With Quote
Old 12-05-2007, 01:04 AM   #266
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
After reading through the 11 pages of good, and bad information I can honestly say it has made me stray from the snail power.
~Josh~
Old 12-05-2007, 01:26 AM   #267
1337Impreza
Member#: 151432
1998 2.5 RS
Arcadia Green Machine
Great Read! Me thinks it deserves a Sticky
1337Impreza is offline   Reply With Quote
Old 12-06-2007, 10:13 PM   #268
bullworm562
Member#: 166091
1998 Outback Limited
Green
thanks, I have been looking for something like this, makes me feel more confident
bullworm562 is offline   Reply With Quote
Old 01-31-2008, 03:02 PM   #269
KevinG
Member#: 146091
14 Mazda 3
Red
this should be a sticky
KevinG is offline   Reply With Quote
Old 01-31-2008, 09:27 PM   #270
GrundleJuice
Member#: 165749
+1 for this being a sticky!
Great for new n/a modders looking for reference to see what they can/should do to get the results they want for the $ they can spend. PLUS i bookmarked it for a reference in case i need to find something i read on here but cant remember later on.
Old 02-01-2008, 08:31 AM   #271
KevinG
Member#: 146091
14 Mazda 3
Red
my roommate has a 99rs and has decided to go with the 2.2 heads... hopefully it is a good decsion... should he get it PnP with some cams or just stick with the stock 2.2L head's design?
Old 02-01-2008, 05:02 PM   #272
KevinG
Member#: 146091
14 Mazda 3
Red
There is also the Frankenstein motor. This is a 2.5L block with 2.2L heads which bumps compression up to the 11.2:1 area. I haven’t seen any dynos but the math makes sense
i looked in this thread, and did not see any more... is there any more info on this idea other then post #2?
Old 03-18-2008, 05:50 AM   #273
GIT-R-DONE
Member#: 128547
Nothing new?
GIT-R-DONE is offline   Reply With Quote
Old 03-18-2008, 10:09 AM   #274
subikid
Member#: 114122
1990 miata(RIP 05rs)
red
search frankenmotor on here. It's here in the N/A tuning thread and has been updated in the last 2 months. I would go find it but I'm busy.
Kevin
subikid is offline   Reply With Quote
Old 03-19-2008, 03:55 PM   #275
Back Road Runner
Member#: 60082
2004 Forester STI
Common upgrades don't change. I'm not exactly sure what "new" thing you would be expecting. All of this is pretty generic stuff and there really isn't any magic fix.
Build-up plans, please critique bongchild Normally Aspirated Powertrain 11 09-27-2005 03:25 PM
OT: Please Critique my resume DrDRum Off-Topic 25 07-20-2005 04:48 PM
Please critique this computer... GarySheehan Off-Topic 67 09-13-2004 06:40 PM
OT please critique my resume suprsubepower Off-Topic 17 03-23-2004 04:15 PM
IT/Developers please critique my resume maaw Off-Topic 9 08-22-2003 03:16 PM
