Old 06-10-2006, 08:40 AM   #1
AVOjapan
Vendor
Member#: 71938
2004 BL Legacy GT
Regal Blue
Default AVO bb twinscroll update
Testing update 2006:06:10
We have successfully fitted and tested the bolt-on (for JDM) AVO BB twinscroll turbocharger on a JDM Impreza STI fitted with a built 2.5-liter short block, Cosworth heads, full 3" exhaust system and Autronic. Basically all necessary components for power generation have been fitted or updated. By 3500rpm it is producing 1bar of boost, and reaches peak torque at 4000rpm. This setup is producing 404whp at 1.4 bar of boost on the dyno, and 55kg/m of torque. This translates to roughly 492hp at the crank and 391ft/lbs of torque.
This dyno reads a bit low because of two factors, excessive heat/exhaust build-up in the room, and not enough load on the dyno. On the road, we reached 1.45 bar of boost in second gear, and 1.6 bar of boost in the higher gears. That's good for a touch more ponies...
We still have a ways to go towards dialing the turbo and autronic settings in completely, but it is looking quite promising so far.
Cheers,
Paul Hansen
http://www.avoturbo.com/forum/viewtopic.php?t=7 <- watch for updates here
AVOjapan is offline   Reply With Quote
Old 06-10-2006, 11:45 AM   #2
keaniegenie
Member#: 94494
2005 Element 92x
Sounds like GT30R type power with faster spool.
Super interested!
keaniegenie is offline   Reply With Quote
Old 06-10-2006, 12:27 PM   #3
SilverSurfer04STi
Member#: 71542
2013 WRB BRZ
Sounds VERY promising.
The dyno numbers sound a tad low, but you offered valid explanations as to why they appear slightly low. Also, less power goes further if the power band is fat and that one sounds nice and fat.
Looking forward to more info on this new product. In particular, what are the other turbo specs besides it being BB and twin scroll (hopefully you will release general turbo info to the public)? That pic in the posted link looks delicious.
SilverSurfer04STi is offline   Reply With Quote
Old 06-10-2006, 12:55 PM   #4
keaniegenie
Member#: 94494
2005 Element 92x
Those numbers almost make me want to get one! Knowing AVO, it's probably pretty expensive though.
Is this kit rotated?
Old 06-10-2006, 01:56 PM   #5
ShaggyGT
Member#: 19221
2005 Legacy GT (STi)
UR35R/Rotated Intake Mani
http://www.avosubaru.com/photos/twin...avo_ts_002.jpg
Uhhh... No, it is NOT a rotated kit. That turbo will only work with the JDM Version 8 STi twinscroll manifold or an aftermarket twinscroll manifold for the JDM Version 8 STi. Stock turbo is either a VF36 or VF37. The only upgrade there used to be wasthe Zerosports Twinscroll turbo upgrade or Power Enterprise's PE1825.
-Matt
ShaggyGT is offline   Reply With Quote
Old 06-10-2006, 03:51 PM   #6
SilverSurfer04STi
Member#: 71542
2013 WRB BRZ
Nice to have another twin scroll option now though. That makes:
AVO Twin scroll BB (JDM config)
PE1825 (JDM config)
VF36 or VF37 (JDM config)
GT32 w/42 or 51 lb/min comp wheel (GPMoto or Crawford setup - though not sure Crawford has a true twin scroll uppipe available yet)
I think there is also a twin scroll of the GT40, but I'm not including that since it is too big for most folk's purposes.
Old 06-10-2006, 06:58 PM   #7
AVOjapan
Vendor
Member#: 71938
2004 BL Legacy GT
Regal Blue
Yes, sorry I didn't clarify - due to our move into Japan, one of our priorities was to develop bolt-on bb turbocharger upgrades for the JDM Impreza STI's, and that necessitated a twinscroll. It's been rather hard, as the twinscrolls are much more difficult to build than the standard turbochargers. We've overcome all the difficulties, though, and now we are into final testing - longevity has been going on for a while on a shop engine, for instance.
I'll try to keep you guys updated here as much as possible, while our forum will have the latest information posted as well (sometimes in Japanese, tho...). Understandably, it's not quite a bolt-on solution for the American cars, but once we have the turbocharger available on the market, we'll also provide full conversion kits along with the turbo information.
Oh, and the run mentioned initially was on pump gas, though Japanese high-octane, so take the figures as a "street" tune, something we believe will stay together for more than a few years.
Cheers,
Paul Hansen
www.avoturboworld.com | www.sevenphotos.com
Old 06-10-2006, 07:41 PM   #8
SilverSurfer04STi
Member#: 71542
2013 WRB BRZ
Duly noted about the fuel and thanks for clarifying that. That was another question I was waiting for info on, but I didn't want to bombard you with bunches of questions. So, is regular japanese pump gas fuel equivalent (approximately) to 98 octane in USA?
I'm very excited about this kit. I finally have my car sorted in the manner that satisifies me (with a bolt on 20G turbo) so I won't be switching things on this car anytime soon. However, if your kit would have been readily available at the time I was looking for turbos, I would have jumped all over it. That said, if I buy a second subaru, there is a very, very high probability I will be purchasing a twin scroll setup like this.
Old 06-10-2006, 07:45 PM   #9
Phil Jr.
Member#: 62221
any price estimate for the US market?
Phil Jr. is offline   Reply With Quote
Old 06-10-2006, 07:54 PM   #10
AVOjapan
Vendor
Member#: 71938
2004 BL Legacy GT
Regal Blue
SS04, I believe that our high-octane is more equivelant to 94 in the states - better than the 93, but not *that* much better. I wish it was...
Phil, not at this moment. We are still working outt the final pricing.
Cheers,
Paul Hansen
Old 06-10-2006, 10:01 PM   #11
keaniegenie
Member#: 94494
2005 Element 92x
Cheers,
Paul Hansen
For this turbo to hit full boost by 4k and have those hp numbers, it must spool wicked fast.
Any dyno charts?
Old 06-11-2006, 06:49 AM   #12
Kotir
Member#: 17300
1993 Widebody Wagon
748whp e98
Excited for sure.
If funds allow me I'll be all over this when it comes out.
I dunno if I can go back to the normal Subaru sound now I'm addicted to Twinscroll...
When does it spool on a JDM 2.0?
-Tim
Kotir is offline   Reply With Quote
Old 06-11-2006, 10:52 PM   #13
AVOjapan
Vendor
Member#: 71938
2004 BL Legacy GT
Regal Blue
Added in a datalog from a 5th gear run on the expressway here:
Cheers,
Paul Hansen
Old 06-12-2006, 01:14 AM   #14
fragment
Member#: 8050
2004 FXTi - Stage 2
Goooooooolld
Shoot, I just decided that I was going to sell my VF36 setup and go rotated GT30. As soon as I make up my mind, new options get thrown into the mix.
Interested in what you'd see on a Ver8 EJ207. Maybe I could be a test subject?
fragment is offline   Reply With Quote
Old 06-12-2006, 01:55 AM   #15
sumfoo1
Member#: 82146
2005 Legacy GT
kg-meters?
is that like newton-meters/ 9.81?
i've never seen that used as a torque measurement
sumfoo1 is offline   Reply With Quote
Old 06-12-2006, 02:03 AM   #16
AVOjapan
Vendor
Member#: 71938
2004 BL Legacy GT
Regal Blue
It's unique to Japan. It's slowly moving over to nm instead, but it'll take time.
Cheers,
Paul Hansen
Old 06-12-2006, 09:36 AM   #17
s203.22b
Member#: 113970
2005 STi WRB
2001 2.5RS AW
PE1825 (JDM config)
there's also the twin scroll GT30R and GT35R made by ATP Turbo.
s203.22b is offline   Reply With Quote
Old 06-12-2006, 12:32 PM   #18
SilverSurfer04STi
Member#: 71542
2013 WRB BRZ
Just checked those out. Are those fairly new? Was not aware of that until you mentioned it.
Old 06-12-2006, 12:57 PM   #19
s203.22b
Member#: 113970
2005 STi WRB
2001 2.5RS AW
i only found out about them a couple of weeks ago. they updated their website in april, so i think they're new. the turbine housing has the same A/R ratio (0.78) as the GT32 without internal wastegate, so they may have found a way to adapt that housing for use with the GT30R and GT35R compressor sides.
Old 06-12-2006, 03:06 PM   #20
teh sash
Member#: 79329
looks great, looking forward for more info...
teh sash is offline   Reply With Quote
Old 06-12-2006, 06:09 PM   #21
SilverSurfer04STi
Member#: 71542
2013 WRB BRZ
Me too. Figures all this twin scroll stuff starts hoppin right when I'm considering my engine "done"...
Old 06-12-2006, 10:23 PM   #22
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Neatttt!
Looking forward to the updates
-paK +41
Pakin is offline   Reply With Quote
Old 06-12-2006, 11:45 PM   #23
AVOjapan
Vendor
Member#: 71938
2004 BL Legacy GT
Regal Blue
Testing update 2006:06:13
Moving backwards through time.... (I better edit the first post...)
More onroad testing notes. We'll need to provide a new datalog some time today, I think. Basically, we are now reaching 1bar of boost at 3000rpm. An HKS boost controller was being used, and it turns out that it's a newer model with older model instructions. We called about some inconsistancies, and they immediately told us they'd send a fax with the *correct* instructions, which were nearly 100% different from the older instruction book. Whee.
But the good news is as above.
Cheers,
Paul Hansen
Old 06-13-2006, 12:56 AM   #24
teh sash
Member#: 79329
I may of missed this but is this on race gas or pump? if pump what octane?
Old 06-13-2006, 01:02 AM   #25
AVOjapan
Vendor
Member#: 71938
2004 BL Legacy GT
Regal Blue
Japanese pump gas, high-octane. About 94 equivelant.
Cheers,
Paul Hansen
FS: (MA) AVO VF37 VF36 Bellmouth for AVO or Custom Twinscroll Downpipe atc5 Engine/Power/Exhaust 43 05-12-2010 03:26 PM
fs:c/f roof spoiler, amr big maf CAI, pnp'd avo 450 dual bb turbo.ALWAYS UPDATED Blackout713 Engine/Power/Exhaust 49 03-22-2010 10:32 AM
fs:socal -c/f roof spoiler, amr big maf CAI, pnp avo 450 dual bb turbo.ALWAYS UPDATED Blackout713 SCIC Private Classifieds 42 03-22-2010 10:28 AM
