Old 06-10-2006, 08:16 PM   #1
JPIQ
Member#: 30277
2002 WRX Japan Specs
Platinum Silver Sedan
Default Valve Purge Direction
I need to know the Direction to Connect the VALVE PURGE
Or part #42084G on www.subaruparts.com
Also, it has an arrow that says to E/G!
Therefore, I am not sure to connect that end to the INTAKE?
JPIQ is offline   Reply With Quote
Old 08-27-2007, 08:33 PM   #2
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
did anyone ever respond to this? I have the same problem.
cdigerlando is offline   Reply With Quote
Old 08-27-2007, 09:14 PM   #3
JPIQ
Member#: 30277
http://www.subaruparts.com/diag/?mod...category=050-1
LOL, I had the same Problem and Had to figure it out by trial and error.
However, you do not need to go through what I went through.
Connection to E/G (Exhaust Gas) is away from the Intake and thus to the Exhaust.
Now, if you intall it the other way around your car will go crazy.
Let me know, if that was helpfull, cause I just went to my car to confirm this info.
Old 08-28-2007, 06:27 AM   #4
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
So arrow away from intake. Cool. Thanks. Too bad no one helped you. All they would have had to do is look at the darn car. Next time add me to your pm list. If I'm online I'll get right back with you.
Take Care
Old 08-28-2007, 10:02 AM   #5
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
Default Proper Valve location
I just went to the dealer and checked one of the other WRXs there. The arrow points to the intake. So it is the other way around. Who knows if the car I checked was correct but you might want to check this again. You could have a bad valve too. Perhaps a couple of other folks could check theirs for us. Can't believe there are not responses.
Old 12-09-2007, 03:08 AM   #6
gohrsepwr
Member#: 118777
2006 STI
aw
theres no exhause gas line here. im guessing it means evaporated gas? these lines go to the gas tank via vapor line on the fuel rail. I found this thread searching to see if anyone has eliminated this concoction and just routed the fuel vaper line directly to the turbo inlet, i want to eliminate, the purge valve and purge valve soloenoid. does anyone know if there is a negative affect? i have a hydra stand alone so there shouldnt be any cel's. pic;
gohrsepwr is offline   Reply With Quote
Old 12-09-2007, 03:30 AM   #7
Broxma
Member#: 158006
2003 WRX IdleWagon
1992 GVR4 379/1000
I have removed the entire system. I also removed all of the charcoal canister items under the rear bumper.
Total weight of everything was actually about 11lbs not including the line under the intake manifold that I cannot remove or the line running from the charcoal canister to the engine bay.
There is a slight smell of gas at the rear of the car now, but even leaving the car in a closed garage for two days, I still have to stick my head actually underneath the rear bumper to smell it.
I have not noticed any depreciable change in fuel consumption. Considering that studies have repeatedly shown that realistically, people could improve their fuel economy by 30% by driving in a calm fashion and in a good mood, I don't think the .125 mile a gallon difference of removing the fuel vapor return system will have any effect.
/Brox
Broxma is offline   Reply With Quote
Old 12-09-2007, 04:22 AM   #8
gohrsepwr
Member#: 118777
2006 STI
aw
hmmm, didnt think of removing the canister also thats a good idea, will look into that also. with all my mods im not worried about fuel economy at all, just looking for good ets at the track and drivability on the street. i am wondering what is the purpose of sucking air from the gas tank? i feel confident that i can do this without any problems now, thanks for the reply!
Old 09-14-2009, 05:06 PM   #9
rocketsled
Member#: 35223
2002 WRX Wagon
WR Blue
Bump. Still waiting for definitive answer to the original question. ANYONE with a stock untouched wrx please check this out.
rocketsled is offline   Reply With Quote
Old 09-15-2009, 02:01 AM   #10
audsyn
Member#: 26112
2002 WRX Wagon
I can confirm that on my 02, the "to E/G" arrow points towards the evap line, away from the inlet.
PS. what does this valve do? I understand the evap system, and the purge solenoid valve, but no other car I've seen has this separate purge valve parallel to the purge solenoid valve, and the manual doesn't address it. The only thing I can think of is that it opens under boost, venting the canister to the inlet. It's like an extra vent...but why is it necessary?
audsyn is offline   Reply With Quote
Old 09-27-2009, 12:30 PM   #11
Haelan
Member#: 151045
2013 Subaru STI
CBP
Ran across this the other day...the arrow points towards the inlet. That is what the 2002 service manual dictates.
Haelan is offline   Reply With Quote
Old 09-28-2009, 03:54 PM   #12
audsyn
Member#: 26112
2002 WRX Wagon
Well, look at that... I had looked previously and missed it, but in the section on the intake manifold (which is in the Fuel section of the manual, not the Intake section ), there's a diagram which shows the arrow on the purge valve pointed to the intake.
Naturally, on my car, it's pointed the other way, and to the best of my knowledge it came that way from the factory. Ditto for previous posters on this thread.
So maybe it's not directional...but then why is there an arrow...I wish I knew what the purpose of this damn valve is.
Old 10-28-2009, 02:14 AM   #13
under0athh51189
Member#: 193959
2001 Lexus IS300
05 Wrx AW 18x9.5 WFC#295
do you mean this is the part number? 42084F
http://www.subaruparts.com/cart/?pn=42084FA110
need to know if this is it so i can order.
under0athh51189 is offline   Reply With Quote
Old 10-28-2009, 03:29 AM   #14
audsyn
Member#: 26112
2002 WRX Wagon
I think it's 42084FE010.
Old 10-28-2009, 09:26 AM   #15
Haelan
Member#: 151045
2013 Subaru STI
CBP
Yup, that's the right number.
Old 11-15-2009, 02:28 PM   #16
GHK
Member#: 103886
2005 WRX
which way the arrow point? up or down?? can anyone please go you your car and confirm this. i took mine out during turbo inlet install and don't know the correct position of this valve.
GHK is offline   Reply With Quote
Old 11-15-2009, 02:44 PM   #17
Haelan
Member#: 151045
2013 Subaru STI
CBP
The arrow points to the hose that connects to the turbo inlet. It's what my vehicle shows....it's what the service manual shows...
Old 11-15-2009, 02:57 PM   #18
GHK
Member#: 103886
2005 WRX
Nice!! thanks
Old 09-11-2010, 07:52 PM   #19
Daluv
Member#: 159325
anyone know what are the effect of a defective Valve-purge or how to reoubleshoot the device?
thanx
Mart
Daluv is offline   Reply With Quote
Old 11-27-2010, 05:48 PM   #20
subysportSTI
Member#: 207923
2006 STI paperweight
thanx
Mart
+1 for this question, is there any negative effects of capping this sucker off? Seems like just about everyone whos removed their intake mani has broken the damn thing lol. I think im going to jb weld the nips back on this thing and call it a day
subysportSTI is offline   Reply With Quote
Old 11-27-2010, 11:44 PM   #21
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Just to confirm, arrow points toward "LEFT"....
Old 01-03-2011, 12:12 AM   #22
accordbluesky
Member#: 264094
my valve broken nipple broken! Anyone knows how much for new and where to order from internet?
accordbluesky is offline   Reply With Quote
Old 03-29-2012, 04:36 PM   #23
ddaddyo
Member#: 226894
2006 WRX STI
CGM
Reviving an old thread. I was getting P0301 misfires on cylinder #1 and the PFFFF, PFFFE codes. Well, I think this thing was installed backwards because I pulled it off, cleaned it, and put it back on. The car runs great now and I haven't thrown a code in 2 days. If no more codes, I'm gonna share this on some other forums and threads where people have been pulling their hair out over not being able to diagnose the dreaded P0301 misfires.
ddaddyo is offline   Reply With Quote
Old 04-09-2012, 04:04 PM   #24
aeonflux99
Member#: 54832
2006 WRX
Same issue, I changed it so the arrow points towards the intake. The misfires in cylinder #1 are gone, so no more p0301, but my car makes a strange noise (and loud) at idle coming from this valve. It's almost as if the air pressure is forcing it open. Anyone know anything more about this? I'm tempted to just block these lines off completely with end caps.
aeonflux99 is offline   Reply With Quote
Old 04-09-2012, 07:18 PM   #25
audsyn
Member#: 26112
2002 WRX Wagon
I know if you pressurize the intake (testing for air leaks) without disconnecting this valve, it will make a kind of farting fluttering sound, like when you let air out of a balloon. Is it that sort of noise?
I am in need of a valve purge solenoid for a 2.0l skivic69 Private 'Wanted' Classifieds 2 03-28-2010 06:07 PM
Greddy Blow off valve w/ direct bolt on adapter blckmagnum Private 'For Sale' Classifieds 1 02-16-2006 10:24 PM
Purge Control Valve Imprezd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-13-2002 04:56 PM
Fuel vapor cointrol and purge valve alfriedesq Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-19-2002 10:06 PM
Carbon purge canister check valve Steve E Normally Aspirated Powertrain 2 10-16-2000 08:44 AM
