Old 10-14-2001, 10:12 PM   #1
aussiebrydon
Member#: 10391
2008 Acura MDX
Sliver
Default TECII kit, almost done, 550cc injectors??
My 550cc injectors don't fit. Anyone have a baseline for a TECII w/ stock injectors? I would love to have my car driving, otherwise it's $210 for a plane ticket back home.
Brydon
MY00 2.5RS, Auto, ASR Stage II turbo kit, Vishnu Performance TECII
aussiebrydon is offline   Reply With Quote
Old 10-14-2001, 10:15 PM   #2
Member#: 67
1999 Outlasting
the competition.
DAMN!!!
i have a perfect map for the ASR kit BUT my car is at Shivs with my laptop sorry
[email protected]
Old 10-14-2001, 11:39 PM   #3
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
Define "won't fit". The injectors Shiv uses are known not to seat completely in MY00+ cars, but you can just seal around them with silicone and they are fine.
Ben
bsquare is offline   Reply With Quote
Old 10-14-2001, 11:48 PM   #4
kaos200
Member#: 2692
Ben
I believe he has <99 injectors. Which are shaped differently due to lacking injector air assist, which the >2000 are equipped with.
kaos200 is offline   Reply With Quote
Old 10-15-2001, 02:23 AM   #5
bsquare
Member#: 1911
2000 Impreza 2.5RS
Yes, we are talking about the same thing. You can use silicone to hold them in.
Ben
Old 10-15-2001, 03:50 AM   #6
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
Silicone?? I must have gotten lucky then. My Injectors (MY00) fit fine. We (RyanC and I) had some difficulties getting them to fit but after a phone call to Shiv to confirm that there shouldn't be an issue, they bolted right on with a little bit of persuasion. The injectors were also installed on RyanC's car without any silicone.
Fitz
Fitz is offline   Reply With Quote
Old 10-15-2001, 04:05 AM   #7
bsquare
Member#: 1911
2000 Impreza 2.5RS
Weird, Shiv told me they would not fit properly without silicone on my MY00 (I haven't installed them yet).
Ben
Old 10-15-2001, 08:17 AM   #8
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
That's interesting. For my peace of mind, what kind of silicone are you talking about here? The kind used to lube the o-rings or the kind say, used to seal a bathtub?? I lubed the o-rings using "o-ring lube" that I had picked up somewhere. It's oil based. But I didn't have to physically seal them with anything.
Fitz
Old 10-15-2001, 09:48 AM   #9
RS'ted
Member#: 3234
The 550cc injectors will "fit" fine in a '00. The included o-rings just may not seal perfectly to the manifold, causing a slight air leak. They don't seem to get squeezed quite enough when installed to grip the injector tightly. The oem injectors are longer in the '00's, with a step to a smaller diameter. This smaller diameter section reaches further into the manifold than the '99 style. Otherwise, everything is the same. This problem is not an obvious thing, only becoming apparent to me after installing the larger fuel rails and trying to nail down a perfect and consistent idle. I just put a small bead of silicone (black, automotive type) around the largest diameter of the injector that makes metal to metal contact with the manifold. NOT on the o-rings . If I ever get really ambitious, I may try to find a tighter fitting o-ring, but it has never since been an issue. I've also heard that there are a few variations of the '00 manifolds, although both of mine are the same. Maybe that explains why some have not had any issues. Hope this helps clear things up.
Ken M
RS'ted is offline   Reply With Quote
Old 10-15-2001, 09:52 AM   #10
RyanC
Member#: 2634
1988 5000 CS Quattro
Tornado Red
Talking
Just to clarify, Fitz, that wasn't 'o-ring' lube...
RyanC is offline   Reply With Quote
Old 10-15-2001, 05:19 PM   #11
aussiebrydon
Member#: 10391
2008 Acura MDX
Sliver
Shiv says that it's all good, just use a little silicone. New question, anyone know where I can find a PROM upgrade for my TECII? The WinTek software doesn't want to work for me until I upgrade that to version 2
Old 10-15-2001, 05:31 PM   #12
bsquare
Member#: 1911
2000 Impreza 2.5RS
You have to send the TEC-II to Electromotive for the upgrade. I'm just going to keep using WinTEC 1.x for a while since I don't feel like dealing with the downtime.
Ben
Old 10-15-2001, 05:35 PM   #13
RyanC
Member#: 2634
Tornado Red
No you don't; Shiv can send you a new Eprom for about $150 or so, or you can download the 1.1.6 software if they still have it on their web site and use that in the interim.
Old 10-15-2001, 05:39 PM   #14
bsquare
Member#: 1911
2000 Impreza 2.5RS
Sorry, their site said you had to return the TEC for the upgrade. If I can just order a new PROM, that is great.
Ben
Old 10-15-2001, 05:45 PM   #15
aussiebrydon
Member#: 10391
2008 Acura MDX
Sliver
almost done.. injector tips please! b0nd18t Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 06-21-2008 11:31 AM
Kool Brake kit almost done. RaceComp Engineering Brakes, Steering & Suspension 328 07-19-2006 04:22 PM
Mid Term Project Almost Done...almost 4830DeuceWRX Off-Topic 2 02-22-2005 11:32 AM
440cc or 550cc Injectors for ludespeed stage 2 kit cpu77 Normally Aspirated with bolt-on Forced Induction Powertrain 5 09-27-2002 11:45 AM
