Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 06-11-2006, 08:10 PM   #1
THE-95-STi
Member#: 113734
2oo3 Vdub 1.8T
Subaruless(MAIC4LIFE)
Default Getting Hydra Base Maps? ?
So I will be getting a Hydra, how do I go about getting a base map for my set up?
got a short ram, TBE, FMIC, Boost controller
THE-95-STi is offline   Reply With Quote
Old 06-11-2006, 08:15 PM   #2
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
As long as you are buying your Hydra EMS from Element Tuning, from an Element Tuning Hydra dealer, or even if it's a used Element Hydra EMS we will support it. I think I know who you are. You need the correct harness first and then we'll get you a base map Each map is individually encrypted to a specific Hydra EMS so you need to get maps directly from Element Tuning. All we need is your serial number and we should be able to get you the correct map for your Hydra.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 06-11-2006, 11:24 PM   #3
THE-95-STi
Member#: 113734
2oo3 Vdub 1.8T
Phil your just to good, you got me, I'm JUST SO EXCITED TO GET THE HYDRA & MY CAR RUNNING NORMAL(been almost a month now) I sent the Harness back to Andrew, he's swapping it out for me, next day air back to me so I should have it on Tuesday afternoon otherwise I'm never using Fed ex again! Lemme know what we can work out, I only live 45mins from Gaithersburg
Old 06-12-2006, 10:18 AM   #5
Element Tuning
Member#: 54918
673 WHP Element
Great, I'm glad they can just modify the harness for you instead of having to purchase a whole new one. I'm sure I'll see you soon.
Thanks,
Phil
Can't get a base map on my car? Voltage? kakarotoni AccessPort 2 06-20-2008 01:43 AM
base map for gt35R with 1000 cc top feed injectors running a Hydra Blue06STI Other Engine Management 1 09-15-2007 01:59 PM
I need hydra base map subabusa Other Engine Management 1 08-17-2006 12:08 PM
Hydra Base Map 2001 2.5RS Impreza Superveget Other Engine Management 17 03-07-2006 12:30 AM
Hydra Base Maps??? dan avoN7 Other Engine Management 3 01-04-2006 10:28 AM
