Old 06-11-2006, 10:01 PM   #1
thswrx
Member#: 102377
2006 WRX TR
Impreza WRX 06 TR VF-22 pro-tuned by Jorge
i was pro-tuned by Jorge on saturday and here are a couple of pics along the way...
at first i couldnt go over 3000 rpms.. a little tuning and this is the first one..
a little better...
and better..
and better...
but then i found out that my short ram intake was smaller than my stock was and my air intake was maxed out ... good times .. but here are the print outs after 25 pulls later.. yeah you could cook marshmellows on my engine..
mods list:
Perrin up/down pipe
Apexi N1 exahst
VF-22 P&P
P.E. 800cc injectors
Perrin FMIC
Walbro 255 fuel pump
Cobb AP pro-tuned
had injen short ram, changed to stock during tune
Greddy boost controller profec B spec II
Turbo XS RFL (going APS 50/50 ASAP!)
when i get my cobb short ram intake and my aps 50/50 put on i will stick her back on the dyno and post my numbers.
thswrx is offline   Reply With Quote
Old 06-11-2006, 10:05 PM   #2
turbo tecnica
Member#: 74470
2013 Accord Sport
72 LS1 Vette
Nice numbers! Looks like about 310-315wtq... very nice. Spool time doesn't look too bad either... looks like full torque around 3600-3700rpms or so. Congrats
turbo tecnica is offline   Reply With Quote
Old 06-11-2006, 10:06 PM   #3
JM530
Member#: 69212
'11 A3 Quattro K04
DSG Lava Grey
Nice! And IMHO that dyno reads a little low!
JM530 is offline   Reply With Quote
Old 06-11-2006, 10:51 PM   #4
SilverSurfer04STi
Member#: 71542
2013 WRB BRZ
Totally agree with that assessment. It's one of the lower reading dynojets I've seen results from.
SilverSurfer04STi is offline   Reply With Quote
Old 06-11-2006, 11:34 PM   #5
Zrex11
Member#: 94881
1989 Hoopty Stylez
Road Slipper
thats because its a dyno dynamics!
Zrex11 is offline   Reply With Quote
Old 06-11-2006, 11:45 PM   #6
VWGrk1
Member#: 57882
2004 WRX
Your dyno brings tears to my eyes.....nice to see my prior snail making some nice numbers on your ride!
Congrats!
VWGrk1 is offline   Reply With Quote
Old 06-11-2006, 11:50 PM   #7
MrH00nel2
Member#: 80474
2002 Z06
1200whp
sweetness
MrH00nel2 is offline   Reply With Quote
Old 06-12-2006, 03:13 AM   #8
Sypher
Member#: 106366
2006 WRX
very nice numbers but did they recomend you get injectors and a fuel pump I would asume with that turbo you wouldnt need it.
Sypher is offline   Reply With Quote
Old 06-12-2006, 04:50 AM   #9
wrxpaul
Member#: 83600
03 wrx wagon
pix of your car?
nice numbers man
wrxpaul is offline   Reply With Quote
Old 06-12-2006, 07:24 AM   #10
testes1010
Member#: 47145
2012 Gas Saver
the '06 injectors flow more than the pinks. As for the Fuel pump not sure....but I'd swap it out to be on the safe side if its the same as the 2.0L WRX one.
damnitJorge, you were in STL & I didn't know it....
testes1010 is offline   Reply With Quote
Old 06-12-2006, 08:37 AM   #11
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Nice numbers and fantastic torque!
Did you clip this 22 for use on the 2.5? Don’t you have concerns of overrunning the efficiency of the turbo compressor with the increased load of the 2.5?
Also, just an observation here, but shouldn’t your AFR be more linear? Looks like it takes a huge dip on the rich side during ramp-up load sites until you reach full load where it then leans back out. You’d think with a premium tune this would be a much more linear transition…
Great numbers all around!
xcntrk75 is offline   Reply With Quote
Old 06-12-2006, 01:24 PM   #12
SilverSurfer04STi
Member#: 71542
2013 WRB BRZ
My bad. Didn't read the top of the dynochart. I assumed it was the dynojet at P&L b/c he was tuned by Jorge. Yeah, the only dynodynamics I know of in the Lou is Ron's at Axis. That one reads hella low. I've been tuned on the P&L dynojet, Ron's dynodynamics, and also on the TopSpeed dynojet... Ron's is the lowest reading by far.
Next is the P&L dyno. The P&L dynojet reads lower than most of the other dynojets I've seen charts from or been tuned on. Hence my earlier comments when I thought he was tuned at P&L...
Old 06-12-2006, 01:28 PM   #13
happasaiyan
Member#: 37731
this one IS on ron's.
happasaiyan is offline   Reply With Quote
Old 06-12-2006, 01:30 PM   #14
SilverSurfer04STi
Member#: 71542
2013 WRB BRZ
Right. I finally figured that out before my last post. Thanks.
Old 06-12-2006, 01:33 PM   #15
scooby24
Member#: 56414
2004 Forester XT 5MT
very impressive. I would be very curious to know what it is capable of in the 1/4 after having that kind of power.
scooby24 is offline   Reply With Quote
Old 06-12-2006, 03:18 PM   #16
Sypher
Member#: 106366
2006 WRX
naw dude check out his mod list hes got 800cc injectors... I know the 06's are 560's Im just asking why he went with bigger injectors.
Old 06-12-2006, 03:30 PM   #17
ScoobyDooo
Member#: 98891
2006 WRX TR 392 WTQ
20G w/FMIC
I dunno what kind of tune your gettin but to me it sounds pretty shady...I have a 2006 WRX TR...ive been protuned at Agile Automotive in MD, and my mods were a Catless TBE...One step cooler plugs...and a Prodirve Boost Selonid, with the AP protune and i put down 255 WHP and 315 WTQ on the TD04...im not braggin here i just would assume alot more an a VF 22 with your mods but maybe im wrong...although they are nice numbers!!!
chris
ScoobyDooo is offline   Reply With Quote
Old 06-12-2006, 03:51 PM   #18
happasaiyan
Member#: 37731
chris
did you not read that it is one of the lowest reading dynos?
also, a vf22 is not much bigger than a vf39...so in comparison, i think its doing pretty well with 290whp...considering with similar mods and a vf39, most STis only get ~320whp max on a high reading dyno.
Old 06-12-2006, 04:39 PM   #19
SilverSurfer04STi
Member#: 71542
2013 WRB BRZ
Exactly correct. ^^^^
chris
I didn't really expound in my earlier post on how low the Axis dyno reads.
Stock STis put down like 205-210. It is the lowest reading dyno I've ever heard of. Including the low reading Gruppe-S dyno that everybody thinks is the worst heartbreaker around.
If you do the math he is making like 415 at the crank. Pretty good for a VF22. On a dynojet he would be putting down around 335whp. By the same math he would be making around 450 lb/ft at the crank and would be making somewhere around 360wtq on a typical dynojet. I hope that puts the numbers in perspective a little for you. 290whp and 315wtq on that dyno is actually pretty impressive considering how little he has modified his car. Even if my math is a tad high (and I don't think it is) he is making very good power for a VF22.
Old 06-12-2006, 05:29 PM   #20
ScoobyDooo
Member#: 98891
2006 WRX TR 392 WTQ
20G w/FMIC
I was just trying to make a comparison...and I did READ I know he said that Dyno read low...what I was trying to get at was how low...some people are nice enought to explain the situation rather than just yell at people for not reading, when the information that someone is looking for is not even there...i would like to thank SilverSurfer04STI for explain rather than yelling at fellow members....plus I've seen VF39s with similar mods put up numbers close to that something in my opinion is not adding up...im not trying to be a dick, i would just like to understand were your coming from...when you figure those numbers.
chris
Old 06-12-2006, 07:06 PM   #21
SilverSurfer04STi
Member#: 71542
2013 WRB BRZ
No problem at all. I don't mind explaining really. I have always been amazed how LOW Ron's dyno reads.
A while back when I was tuned on that dyno we discussed it and besides him explaining the "it's just a dyno and dynos are for tuning, only pay attention to hp gained from baseline" which I alread understood, I had a good chuckle when he concluded the conversation with, "Yeah, you know, I kinda like having a really low reading dyno. You can tell people you only make like 285 hp at the wheels and then you can see the look of shock on their face when you walk them pretty hard...".
Old 06-12-2006, 07:50 PM   #22
devil doc
Member#: 107279
06 vf39 wrx
black
what was the baseline before the tuning , i just want to know what the car dynoed with the td04 , nice set up!
devil doc is offline   Reply With Quote
Old 06-12-2006, 08:13 PM   #23
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Why not run 17psi to redline? You certainly have the injectors for it.
jblaine is offline   Reply With Quote
Old 06-12-2006, 08:44 PM   #24
shemoves
Member#: 80663
2005 STi
+1. My STi sees 270 whp on 91 and 300whp on 100 ocatne using a dyno dynamics. He says to figure out crank power, to multiply by 1.38, (which sounds high) but puts me @ 415 crank hp, while @ 300 dynodynamics whp. So, I'd say your numbers look good.
shemoves is offline   Reply With Quote
Old 06-12-2006, 09:32 PM   #25
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
chris
A vf22 is not going make much more power if any then a vf39. His numbers seem about right for a low reading dyno so i dont know why you think something "is not adding up". Look at the a/f chart seems like a good tune to me.
06 WRX TR VF-43 -- Agile Tuned -- 311 HP / 354 TQ brain juice Proven Power Bragging 22 10-28-2008 09:36 AM
06 wrx with VF43 tuned by Jorge DarthWRX06 Proven Power Bragging 27 08-20-2008 08:39 AM
06 STOCK WRX TR Tuned by Jorge - 230hp/293tq P&L Motorsports Inc. Proven Power Bragging 56 03-14-2007 10:25 AM
STI SR40 just got pro tuned by jorge jnorth85 Proven Power Bragging 70 04-06-2006 03:28 PM
Might be a drive for some of you but...Pro-tuner+utec meeting +tuning by Jorge mpower22 Mid West Subaru Owners Club Forum -- MWSOC 2 06-06-2005 08:19 PM
