Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 06-11-2006, 11:16 PM   #1
El Gato
Member#: 110648
Chapter/Region: PRSIC
2005 Hydramist 35R82
93oct 479whp 456tq
Default HYDRA v2.17-Crash when selecting settings
Well, just the other day my 2.17 Hydra for 2005 STI was working fine. Then suddenly on one day when I selected the settings window in the software the program would close itself. After several intalls uninstalls reboots etc. I remembered that the day before I had just installed AOL 9.0 SE in my laptop. I uninstalled it and it started to work OK again. Seems like the install of some software in Windows XP (I have the Pro version) changes something in the configuration that causes this. Hydra EMS is working on a new version to prevent this but the meanwhile, if it worked and now it does not, track your software installations. Uninstalling one of them may solve the problem. And if you have AOL 9.0SE on your laptop, version 2.17 might not work. Version 2.14 did work though with AOL installed though.
El Gato is offline   Reply With Quote
Old 06-12-2006, 09:20 AM   #2
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Thanks for the info. We had a few with this problem a couple months ago or more and couldn't track down the cause. What version of 2.17 are you using?
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 06-12-2006, 11:02 PM   #3
El Gato
Member#: 110648
93oct 479whp 456tq
v2.17r1
Old 06-25-2006, 12:01 AM   #4
dunk
Member#: 15359
I had this exact same problem (not sure if I'm the case Phil's referencing) Had to format and reinstall the OS on my laptop. It went away. Spent about a week trying to nail it down with no luck.
Duncan
dunk is offline   Reply With Quote
Old 06-25-2006, 12:47 AM   #5
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
AOL is, and has always been, the worst piece of (totally unnecessary) software. Yes, more than Windows even. (sorry for the rant).
offset
offset is offline   Reply With Quote
Old 06-25-2006, 02:17 AM   #6
El Gato
Member#: 110648
93oct 479whp 456tq
When it stops working, track back your software installs. My problem it seems was AOL. Other programs might cause it too.
Old 06-25-2006, 09:19 AM   #7
dunk
Member#: 15359
I did not have AOL on the computer. Interesting.
Duncan
Old 06-26-2006, 04:13 PM   #8
Element Tuning
Member#: 54918
673 WHP Element
"We have updated software for 2.1 and 2.5 boxes to fix the program with crashing on settings. This will be available for download in the software download section of our website." - Hydra EMS
You can download versions of 2.17 or 2.5 if you are having this problem here:
http://www.hydraems.com/Nemesis%20Software.htm
Do not use either software version without having the appropriate "flash." So if your Hydra originally came with 2.17 software you may use the latest 2.17 version and if your unit was equipped with a 2.5 flash, you may use the latest 2.5 software.
If you aren't having this issue with your laptop then don't waste your time
Thanks,
Phil
Old 07-04-2006, 03:18 AM   #9
Sparcomx
Member#: 1791
had same problem formatted my laptop and it worked..
--George.
Sparcomx is offline   Reply With Quote
Ok something is seriously wrong with my Hydra 2.17 spoolinsti05 Other Engine Management 6 06-02-2008 12:10 PM
does everyone know that if you hit ctrl+arrows when selecting text.. alacrity024 Off-Topic 15 02-21-2006 04:00 AM
Hydra v2.0 extruded case HW available? syoung0298 Other Engine Management 3 07-03-2005 08:37 PM
What are some good questions to ask when selecting a paint shop? MF-DIF Interior & Exterior Modification 6 11-03-2004 08:36 PM
What to look for when selecting engine management? N/A01RS Engine Management & Tuning 6 12-09-2002 08:15 PM
