Old 06-12-2006, 03:12 AM   #1
NewShockerGuy
Member#: 40736
2005 WRX STI
Arrow How to make brake pedal really stiff?
Installed s/s brake lines and used ATE super blue fluid... I honestly can't tell any difference at all from the stock rubber lines that were on my sti...
What can I do to make it STIFF... I want the feeling of how it is when the car is OFF, and you push the brake pedal down and it's SUPER hard...
Would the cusco brake cylinder bracket designed for the USDM wrx/sti help at all... any way to add springs to the brake..etc?
I just can't stand the slop/slush of the brake pedal... I want that feeling back when I first bought the car and it felt like I was pushing a brick down for the brake pedal...
Thanks,
-Nigel
NewShockerGuy is offline   Reply With Quote
Old 06-12-2006, 03:23 AM   #2
Seranin
Member#: 54409
2006 Forester
bleed the lines? I assume you did that when you did the fluid and brake lines, but new fluid and ss lines made a big noticeable difference to my car's brake pedal feel. Though at the moment it's feeling pretty squishy, but I think I'm due for new pads, fluid & bleeding...
Seranin is offline   Reply With Quote
Old 06-12-2006, 08:46 AM   #3
RaceComp Engineering
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Bleed them again..........
Are your pads still new?..how many mile on them?.....IF you changed lines, and fluid but your pads are at 50%, your pedal could still suck,..yes thats possible. Remember the stock pads are crap. New pads and rotors that DONT have a wear lip in them, will feel good. As for getting the "when the car is off" feel,....LOL. forget it, or remove the brake booster and or get racing pedals. It will never feel that way, not to mention most people dont know how to modulate the brakes well enough without a brake booster and be fast or prevent lock up,.......................... Not unless you are a WKA champion and or Star Mazda regular and you live with no brake booster on a daily basis.
Keep those things in mind.
Myles
RaceComp Engineering is offline   Reply With Quote
Old 06-12-2006, 11:35 AM   #4
corey_dyck
Member#: 98427
2006 STI
If you really want it to feel like when the car is off, disconnect (and plug!) the vaccum line going into the brake booster. Do this at your own risk as Myles suggests.
I've driven a car like this, the brakes still work but it takes a surprising amount of effort to brake. Don't let other people drive your car without warning them, they'll run into the first thing that gets in front of them.
corey_dyck is offline   Reply With Quote
Old 06-12-2006, 11:56 AM   #5
Dizmal
Member#: 103474
my other ride
has tits
Bleed the brakes. Prolly a few air bubbles in there.
Dizmal is offline   Reply With Quote
Old 06-12-2006, 04:07 PM   #6
Pete Holt
Member#: 12
2013 G37S 6spd sedan
Moonlight White
I am surprised that you did not notice any difference by upgrading from rubber to steel braided brake lines. I noticed a large difference. The Cusco brace probably made the biggest difference in brake pedal feel. I did not realize that the master cylinder was flexing that much on the firewall before I put that brace on.
Pete Holt is offline   Reply With Quote
Old 06-12-2006, 04:49 PM   #7
Capt Crunch
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
My old stoptechs had a rock hard pedal feel that I've never felt on any other brake system. Your 05 hubs should resist the pad knockback too.
Capt Crunch is offline   Reply With Quote
Old 06-12-2006, 05:39 PM   #8
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
I agree with the "bleed again" bit, along with checking wear on the pads. New pads always have better pedal feedback than old pads.
The STi brake system typically has great feel; I can understand if you were on an older WRX but for a new STi, I can't see why not. Did you make sure to bleed each side of the caliper individually?
-Biggly
DrBiggly is offline   Reply With Quote
Old 06-12-2006, 05:47 PM   #9
Lethargic1
Member#: 20998
I felt a somewhat "noticeable" difference when I installed my SS brake lines.
Lethargic1 is offline   Reply With Quote
Old 06-12-2006, 06:36 PM   #10
NewShockerGuy
Member#: 40736
2005 WRX STI
Arrow
Hm...
We did bleed the brakes when installing the lines, actually we made sure there were no air bubbles, since we completley changed the fluid...
The STOCK pads have 23,000+ miles on them... when some of the guys looked at the pads they said there were about 50% left on them...
I don't know it could be my mind.. but I really can't feel a difference..
To make sure there were no leaks I was pushing the brake pedal down when the car was OFF so it gave that SUPER SUPER hard brake pedal feeling... and then when I turned the car on it didn't feel like that obiviously.. so I might be comparing it to that...?
-Nigel
Old 06-12-2006, 06:57 PM   #11
John2.5RS
Member#: 1140
2000 S201 #78, '95 L
'13 F150 Ecoboost
That's what they feel like when the vaccum brake booster has no vaccum. Not the best idea for a daily driver IMO.
John2.5RS is offline   Reply With Quote
Old 06-12-2006, 07:09 PM   #12
firebox40dash5
Member#: 107361
Now, with 100% less
trunk space!
Yeah, I don't think disconnecting the booster is a great idea- vehicles without power assist brakes have smaller bore MCs to make up for the lack of a booster. Methinks if you were to wreck, and the insurance co. found that one out, they'd frown upon that idea...
firebox40dash5 is offline   Reply With Quote
Old 06-13-2006, 01:10 AM   #13
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
3 things come to mind.
1. 50% pad will make it feel just "OK".
2. Expectation was prob too high.
3. if you had the stock HARD pads on for 23k, then there is prob a nice LIP in that stock rotor, so you are prob about 50% on allowable rotor thickness too.
All of which will contribute to pedal feel .
mw
Old 09-08-2006, 09:45 PM   #14
Aleksey
Member#: 23445
2007 STI
In addition to what was said above I think you could just get used to the feel. What car did you drive before the STI? Another good test would be to go and testdrive a new STI and compare the pedal stiffness
Aleksey is offline   Reply With Quote
Old 09-08-2006, 10:38 PM   #15
TCE
Member#: 100868
Change both front and rear calipers to a smaller bore part adjusting each about the same % would do it.
Shorten the longer end of the pedal and put in a foot well false floor would do it.
Fit a 1.125 mc would do it.
TCE is offline   Reply With Quote
Old 09-13-2006, 02:45 AM   #16
NewShockerGuy
Member#: 40736
2005 WRX STI
Arrow
I had a WRX before... but when I first got my sti the braking was AWESOME, nice and stiff.. like pushing a brick down.. .now, not so much...
TCE:
I don't know what you said..lol :-(
-Nigel
Old 09-13-2006, 11:04 PM   #17
cliff257
Member#: 105655
04 STi
07 spec B
remove the vacuum line from the brake booster hehe.
cliff257 is offline   Reply With Quote
Old 09-14-2006, 02:32 AM   #18
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
single stage booster would also help get rid of the initial slop.
Old 09-14-2006, 01:33 PM   #19
Car vs. Driver
Member#: 81620
2004 350Z
406WHP/350WTQ
I have the perrin master cylendar brace and it made a dramatic difference in pedal feel. It felt more solid and consistent and eleminated almost all of the squishyness.
I will say, once your fluid gets hot and lines start expanding (non-braided) that the brace won't help. It just eleminates the movement of the firewall when you hit the pedal.
Definately worth the money to get one.
Car vs. Driver is offline   Reply With Quote
Old 09-15-2006, 04:06 AM   #20
NewShockerGuy
Member#: 40736
2005 WRX STI
Arrow
Is this the one that is DIRECTLY plug and play with our cars... I think it's either this or the Cusco which is a pain in the butt to install..
-Nigel
Old 09-15-2006, 08:09 AM   #21
chrisek
Member#: 65093
Chapter/Region: HIIC
2006 STI
BA Black
Also, where can the Cusco brace be purchased? Can't find it through Google. . . .
chrisek is offline   Reply With Quote
Old 09-15-2006, 08:09 AM   #22
Car vs. Driver
Member#: 81620
2004 350Z
406WHP/350WTQ
Took me 30 minutes to install mine, no problems. Either one you install, you'll have to trim the bracket that holds a few hoses. Literally, a pair of tin snips will do the job
I prefer the Perrin brace ... call GTWORX.com, they can get them for you no problem
Old 09-15-2006, 08:29 AM   #23
chankiu
Member#: 88662
2002 WRX Sedan
Platinum Silver
I got the Perrin Brace also.
it wasn't easy to install.. some of those bolts are kinda to reach..
like the one inside the wheel well.
but the feel is much better
chankiu is offline   Reply With Quote
Old 09-15-2006, 12:18 PM   #24
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Originally Posted by NewShockerGuy View Post
Hm...
How did you completely change the fluid? If you drained out all the old fluid, then put in new fluid, you've almost certainly got air in the master cylinder. That would account for the squishy pedal. If you kept the MC topped off as you drained/pumped out the old fluid then that shouldn't be the problem.
Pat
Old 09-15-2006, 11:14 PM   #25
NewShockerGuy
Member#: 40736
2005 WRX STI
Arrow
Pat
We used one of those pumps that you attach and it forces out the air bubbles and the old fluid by putting all the new fluid in... then when you start seeing your blue fluid (ATE SUPER BLUE) you stop. We did this on ALL the bleeder screws.
-Nigel
How to install new pedals? LiDrummer Newbies & FAQs 4 10-03-2007 07:48 PM
How to make the brakes more "catchy"? Aleksey Brakes, Steering & Suspension 21 09-09-2006 01:38 PM
How to install new pedals on a 2006 STI Jag32 Interior & Exterior Modification 4 06-30-2006 01:24 PM
how to remove gas pedal? brianc Interior & Exterior Modification 1 03-17-2004 10:43 AM
