Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 06-12-2006, 03:48 AM   #1
bugeyes
Member#: 64494
2001 V7 sti
Question A/F tuning on the vacuum side....
Found heaps of detailed info on boost mixtures but I need more info on vacuum manifold pressure mixtures.
I have searched this topic and it seems many comments are just to run 14.7-1. You guys that have standalone ECU's what mapping are you using for the vacuum side of the fuel map. I suppose you could-
Simply map the entire vacuum map to 14.7-1 as many of the search posts make mention of.
OR
Run a zero manifold pressure of say 13.2-1 tapering off to a maximum lean mixture of 15.5-1. With a general cuise mixture close to 14.7-1
bugeyes is offline   Reply With Quote
Old 06-13-2006, 02:24 AM   #2
rac
Member#: 48594
1997 us2.5L ver3 sti
white
I'm not saying this is right for you but this is what i run with my Autronic sm4 on my ej257/ver3 sti.
rac is offline   Reply With Quote
Old 06-13-2006, 07:09 AM   #3
bugeyes
Member#: 64494
2001 V7 sti
Could you please translate the load column into vacuum level. It appears the pic you posted also includes boost a/f mapping.
Old 06-13-2006, 10:44 AM   #4
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Here's what I do, for no real good reason other than theoretical fuel conservation:
14.5:1 to 14.7:1 = Idle vacuum and lower, all RPM ranges.
14.7:1 = High vacuum at lower than 3000RPM (very likely the car is decelerating to a stop)
18.0:1 = High vacuum at higher than 3000RPM
Really though, it's pretty pointless if you ask me. How often are you in vacuum higher than idle vacuum? Shifting, engine braking. Woop dee doo.
Tune it for 14.7:1-ish and be done.
jblaine is offline   Reply With Quote
Old 06-14-2006, 09:32 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
a thought and the way my car is tuned (which is probbaly wrong)
open loop i target 12.1 (best lean torque) then and let the closed loop pull it up to 14.7
Old 06-14-2006, 09:53 PM   #6
bugeyes
Member#: 64494
2001 V7 sti
Well after reading the replies I think this is what I will do. Configure the map to 14.7-1 across the vaccum band. Then bring my fuel cut vacuum level up as far as possible so when I hit high vacuum levels it shuts off the injectors. Finally set my closed loop control to about 15-1 (maybe even higher 15.5-1?), so on continuous throttle position such as cruise it tends to lean off slightly.
This should give me a clean, fuel efficient burn (totally the opposite from the boost side)
On boost the map tapers off gradually from zero to give max power under boost conditions.
Wanted: WRX Side Strakes/ Flares that go on the factory side skirts mrtrex Private 'Wanted' Classifieds 6 12-14-2007 03:19 PM
Are the TD05H and TD06H the same on the Intake side? Irishman Newbies & FAQs 3 06-07-2006 06:44 PM
They get all of the good cars on the other side of the pond chrisarella General Community 16 06-02-2006 02:47 PM
Why isn't the throttle plate on the intake side of the turbo? Dale_K Newbies & FAQs 3 03-15-2005 03:02 PM
What mattress will stay stable on one side if somebody jumps on the other side? Cjchaps Off-Topic 12 01-21-2004 06:00 PM
