Old 06-19-2006, 05:33 PM   #226
4wheelmotion
Member#: 2044
1999 2.5 rs-T
rally blue/ '96 jetta vr6
**sigh**
..sooooo beautiful!
4wheelmotion is offline   Reply With Quote
Old 06-19-2006, 05:37 PM   #227
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
A M A Z I N G ! ! ! !
Old 06-19-2006, 06:23 PM   #228
bouse1
Member#: 8106
2001 Impreza RSTi
WOW!
No subaru will ever come close to this.
Game Over.
bouse1 is offline   Reply With Quote
Old 06-19-2006, 07:23 PM   #229
Chris & Rosy B
Member#: 99500
2004 WR1
Ice Blue
Gobstopper Specs
Body
WRC steel arches WRC front and rear bumpers
WRC carbon rear spoiler
FIA T45 multi point welded in roll cage
STi alloy bonnet with RCMS heat extraction vents and gas struts
Heated front screen
WRC non heated lightweight rear screen
Engine
2.0Litre closed deck subaru block
RCMS extreme arrow rods
RCMS 75mm steel crankshaft
RCMS omega flat top pistons (coated) compression ratio 9.5:1
V4 STi cylinder heads with WRC/RCMS O-ring head gaskets and gas rings
One piece Nimonic exhaust valves
One piece stainless inlet valves
RCMS uprated valve springs
Plasma nitrided titanium spring caps
WRC main and big end bearings
WRC R-Profile high wrap cam belt system
RCMS modified oil pump to suit R-Profile belt
WRC S10 inlet manifold
RCMS eight injector kit
RCMS 72mm throttle body
RCMS 5.5 litre alloy sump
WRC short runner exhaust manifold
Garret GT 35-40 turbo with speed sensor
K&N air filter with RCMS 100mm inlet trumpet
RCMS high flow intercooler with twin tube core
70mm stainless steel intercooler pipe work
Electronics
M800 Motec ECU with traction control,nitrous control,anti-lag
paddle shift control,and full engine management control and data login
Motec dash with data login
Defi gauges for turbo,oil,fuel pressure
Interior
FIA carbon kevlar recaro seats
FIA sabelt 6-point harness
Transmission
R180 STi rear axle 3.9:1 cwp and plated modena LSD differential
GKN rally drive shafts front and rear
Torque line carbon fibre propshaft
Six speed subaru gearbox casing modified for sequential housing
Six speed modena gear kit
Subaru 3.9:1 front cwp
RCMS sequential system
RCMS paddle shift system
Plated centre diff with 1:1 uprated output modena gears
Plated front modena differential
Fuel System
FIA spec 26 litre rubber/kevlar bag tank in aluminium cover
Twin bosch fuel pumps (200 litre per pump)
-8 Goodrich fuel feed pipe
-6 Goodrich fuel return pipe
-6 fuel cooler with cooling fan on return
RCMS 8 injector distribution block
2x SX fuel regulators running at 4 bar static pressure
Suspension
WRC spec exe-tc fully ajustable dampers
High and low speed bump + rebound ajustment
STi Rose jointed rear lateral links
STi Rose jointed rear trailing links
Exe-tc bottom rose jointed upright bushes
STi alloy front arms (polished)
STi quick-steer steering rack
WRC roller bearing single piece steering column
Momo suede steering wheel
Nitrous
NX full wet system
121bs carbon bottle with heater jacket
High flow shark nozzle
Motec auto control or driver manual system
Ajustable from +35bhp to +400bhp
Clutch
RCMS spec triple plate alloy cover OS GIKEN clutch and flywheel
RCMS hydraulic light pressure system
Quick release dry brake fluid connection
Brakes
AP 355mm six pot front (track and road use)
AP 304mm four pot front (drag strip use)
AP 290mm four pot rear with floating discs
RCMS hydraulic carbon handbrake
-3 stainless steel goodrich pipe work and fittings
Wheels
Road/Track use 19x8 forged alloy 1 piece rims
Drag strip use 15x8 spun alloy 3 piece rims
Power=850 bhp
Weight=1120 kgs
First event:TOTB july 30th 2006
First show:Max Power Live 29th july 2006
Intended use:street/track/hill climbs/drag strip/time attack
There you go,that is the spec list for the Gobstopper,typed by Chris.
Hope this answers any questions you may have had,biggest spec list I have seen,its 00:20 and I"m off to bed.
Chris & Rosy B is offline   Reply With Quote
Old 06-19-2006, 07:27 PM   #230
soji
Member#: 87178
2003 Japanese Spec
Impreza STi
DAM, I'll Say!
soji is offline   Reply With Quote
Old 06-19-2006, 07:29 PM   #231
azn2nr
Member#: 35276
must have new shift system and 8 injector kit. oh and lower it please
azn2nr is offline   Reply With Quote
Old 06-19-2006, 08:03 PM   #232
spooln407
Member#: 97054
MY05 WRX
throw some 22" DuBZ FTW!!! hahaha
that car is so awesome. perfect as is...
spooln407 is offline   Reply With Quote
Old 06-20-2006, 02:05 AM   #233
Chris & Rosy B
Member#: 99500
2004 WR1
Ice Blue
Originally Posted by AlbaScoob
jebus...
that would be worth stopping by to see next month when I'm home!
Give RCM a call and pop in to get some pics for yourselve.
Old 06-20-2006, 08:54 AM   #234
AgeWrx
Member#: 112368
2000 WRX CSE 4
Cashmere Yellow
Originally Posted by moss
WRC sheetmetal(as stated)... WRC sheetmetal had larger wheel arches 22B had smaller ones...
Are you sure....
REAL 22B on the right, V5 GC8 2-Door STi on the left
It's a GC... there is no differentiating between the 2dr and 4dr on the VIN plate in the UK/Japan... a GC8 is both 2drs and 4drs
*subscribed*
Details here...
Sep.99-Aug.00
MY2000 GC8G2DD 300 WRX R STi5 2 door
GC8G2DD 300 WRX R STi5 V-Limited 2 door Special edition
GC8G27D 300 WRX RA V-Limited 2 door Special edition 2 door RA
GC8G48D 280 WRX 4 door
GC8G47D 280 WRX RA 4 door
GC8G4ED 300 WRX STi4 4 door
GC8G4DD 300 WRX RA STi5 4 door
GC8G4DD 300 WRX RA STi5 4 door V-Limited Special edition
GF8G58D 240 WRX 5 door
GF8G5ED 300 WRX STi5 5 door
GF8G58P 240 WRX 5 door AT
The 7 digit "applied model" code found on the vehicle identification plate inside the engine bay is decoded in the following way.
1 Series code G=Impreza S=Forester B=Legacy etc.
2 Body type F=Wagon C=Sedan
3 Engine type 8=2.0L Turbo
4 Year code A=MY93 B=MY94 C=MY95&96 D=MY97 (facelift) E=MY98 F=MY99 G=MY00
5 Number of doors 2=2 door coupe 4=4 door saloon 5=5 door wagon/hatch
6 Model type 8=WRX 7=RA type E=Sti D=Sti Type R & RA
7 Transmission D=5 Speed Manual AWD P=4 Speed Automatic AWD
Taken from here...
http://www.sidc.co.uk/faq.htm#1.3
Congrats on the car....awesomely well done!!!
AgeWrx is offline   Reply With Quote
Old 06-20-2006, 09:31 AM   #235
Jolly Green Monster
Member#: 30846
1996 Impreza Turbo
Green
look at the wheel arches.. not the wings.. 22B and WRC wings are both wider track but WRC has bigger wheel arches. The RCM is a 2door GC8 shell with WRC wings/arches.
Simon
Jolly Green Monster is offline   Reply With Quote
Old 06-20-2006, 10:21 AM   #236
Subaruski
Member#: 39905
and on the 7th day God created the Gobstopper
Subaruski is offline   Reply With Quote
Old 06-20-2006, 11:16 AM   #237
Blk_RS01
Member#: 107914
2001 2.5 RS
Black on GOLD
Gobstopper Specs
Body
Heated front screen
Engine
Electronics
Interior
Tranmission
Fuel System
~8 Goodrich fuel feed pipe
~6 Goodrich fuel return pipe
~6 fuel cooler with cooling fan on return
RCMS 8 injector distribuion block
Suspension
Nitrous
NX full wet system
Clutch
Brakes
~3 stainless steel goodrich pipe work and fittings
Wheels
Power=850 bhp
Weight=1120 kgs
holy crap... can the list be ANY longer??
::bows down::
Blk_RS01 is offline   Reply With Quote
Old 06-20-2006, 11:19 AM   #238
AlbaScoob
Member#: 79847
2004 WRX rally car
TIM/Alba Rallysport
Gobstopper Specs
Body
Heated front screen
Engine
Electronics
Interior
Tranmission
Fuel System
Suspension
Nitrous
NX full wet system
Clutch
Brakes
Wheels
Power=850 bhp
Weight=1120 kgs
KAACHING!!!
mucho quids...
AlbaScoob is offline   Reply With Quote
Old 06-20-2006, 11:21 AM   #239
AlbaScoob
Member#: 79847
2004 WRX rally car
TIM/Alba Rallysport
I may well just do that...
Old 06-20-2006, 02:38 PM   #240
Silver Scooby Sport
Member#: 59759
1994 Impreza Sti RA
Silver Scooby Sport is offline   Reply With Quote
Old 06-20-2006, 03:31 PM   #241
moss
Member#: 10197
Originally Posted by AgeWrx
Are you sure....
I'm surer than sure that its not a 22B or 22B sheetmetal.
It's a V6 Type R body, with WRC sheetmetal, NOT 22B sheet metal!
Hi everyone,just to try to fill you all in with a few more details,the car is based on a sti6 but has been fitted with a genuine WRC steel body kit,that is the wheel arches back and front and also the front bumper.
Originally Posted by Fms
Holy ****
Y hallo thar Si! Took the words right out of my mouth.
moss is offline   Reply With Quote
Old 06-20-2006, 05:32 PM   #242
CrazyMike13
Member#: 44615
2002 WRX Wagon
1st Guru Point EvAr!
Hmmm, let's say I wanted to build a car EXACTLY like that, and ummm, I already have the 'shell' (2000 2.5RS Coupe).
What does it look like one would PAY for a replica of the Gobstopper? Yeahhh.
-CM!3
CrazyMike13 is offline   Reply With Quote
Old 06-20-2006, 05:58 PM   #243
Evil XT
Member#: 102801
14 Rubicon
RIP "Silver Fridge"
Nice carbon fiber door panels!!!
and everything else...
Evil XT is offline   Reply With Quote
Old 06-20-2006, 06:07 PM   #244
AlbaScoob
Member#: 79847
2004 WRX rally car
TIM/Alba Rallysport
-CM!3
think 6 figures....then multiply by 1.8 for the exchange rate!
Old 06-20-2006, 07:03 PM   #245
Evil XT
Member#: 102801
14 Rubicon
RIP "Silver Fridge"
6 figures definately... forget the exchange rate...
Old 06-20-2006, 08:44 PM   #246
Big_DeWeY
Member#: 37078
95 L
Blue-ish
soooooo.... i hate to be the guy to say somthing negative but i think it could use an inch or more larger wheels. theres alot of wheel gap and i think it kinda looks funny IMO.
Big_DeWeY is offline   Reply With Quote
Old 06-20-2006, 09:00 PM   #247
ghibli99
Member#: 90761
2003 S2000
Save the Manuals!
:gives up car modding:
Wow. That's all I have to say. It's been awesome watching this from the teaser pics to the finished product. I think I'll wait a few years before I post any pics of my car.
Need some shots of Travis in the car, though!
ghibli99 is offline   Reply With Quote
Old 06-20-2006, 09:33 PM   #248
CrazyMike13
Member#: 44615
2002 WRX Wagon
If you read the specs, they say they run 19's on the street.
-CM!3
Old 06-21-2006, 03:44 AM   #249
Chris & Rosy B
Member#: 99500
2004 WR1
Ice Blue
Remember that the gobstopper will be running with M/T tyres on the drag strip so we need some clearence in the arches, Rosy will put up a pic for you to see,we will try to get all the pics up in the next few days but work keeps getting in the way,so apologies for being a bit slow.
Old 06-21-2006, 06:29 AM   #250
Chris & Rosy B
Member#: 99500
2004 WR1
Ice Blue
A few more pics to tide you over, till we can get the full story up. Apologies for making you all wait though.
This is the original sump and exhaust manifold...
... and this is the new sump designed by Matt Clark, together with the WRC short runner exhaust manifold
Sump and manifold in-situ
Throttle body
OS Giken triple plate clutch
It has to be Meguiars! ( a bit of blatant product placement )
and in answer to the queries about the size of the wheels, Chris B demonstrates that the Mickey Thompson drag tyres fit very nicely into the wheel arches.
Time Attack 2007 The RCM Gobstopper. Chris & Rosy B Member's Car Gallery 148 01-13-2009 09:30 AM
RCM Gobstopper Time Attack the Result. Chris & Rosy B Member's Car Gallery 10 10-13-2008 03:08 AM
Walk Round The Rcm Gobstopper With Olly Clark Danuleson General Community 11 06-06-2008 06:45 PM
Walk round the RCM Gobstopper with Olly Clark Chris & Rosy B Member's Car Gallery 14 06-05-2008 05:47 PM
RCM Gobstopper - The Full Story Chris & Rosy B Member's Car Gallery 61 11-30-2006 09:17 AM
