Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum > Western Canada
Old 06-12-2006, 12:15 PM   #1
thejean
Member#: 17763
Default Husky 94 vs 91/92... LOGS Pls!
Ok, I've decided to start a thread looking at logs of cars running different maps with various fuels. Before each post, please include the date, a list of engine/power mods and the map you are running along with the fuel octane, brand and location puschased.
Ok, I'll start. This was a run I did last night (June 11).
Mods: Stg 2 - 91 octane OTS map
Fuel: Husky 94 (Bought at Mohawk on 16th Ave)
Data Log:
Based on the above it looks like I was getting up to 5 degrees of knock correction. Although I clipped the data a bit, I did have up to 43 degrees of total advance at one point.
Tonight I plant to load up the 93 map on 94 fuel and see what I get. If I don't get any negative knock correction then it should be OK right? Plus, I can compare the g/s to see if I get more or less air into the engine (i.e., power).
Lastly, I plan to do a run on 91 using the 91 OTS map (once this tank of 94 is gone) to show that the car pulls timing and adds it back slowly once you go from 94 to 91. I have noticed this in the seat of my pants but want to prove it. So, if my knock correction stays at 0 or less, I will have proved my hypothesis.
Feel free to provide your input where you can.
Cheers, JC
thejean is offline   Reply With Quote
Old 06-12-2006, 01:34 PM   #2
Modifying
Member#: 83521
05 PDX Pro-tuned
Stg2 WRX
Hi,I am just curious about the ur boost.
Why is ur highest boost is at 26 psi.
I am running Stage 2 as well.....
Modifying is offline   Reply With Quote
Old 06-12-2006, 01:44 PM   #3
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
Its absolute
Atmospheric + boost
Wombat North is offline   Reply With Quote
Old 06-12-2006, 03:58 PM   #4
thejean
Member#: 17763
Yep. MAP = Manifold Absolute Pressure
Any thoughts on my datalog Mr. North?
Old 06-13-2006, 02:28 AM   #5
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
If you wanna show me how to pull a log with my AP ill throw it on my desktop and compare...
Chp_Stix is offline   Reply With Quote
Old 06-13-2006, 10:49 AM   #6
gmorris1
Member#: 76891
2010 WRX Base
You can't log with an AP. You need to either buy deltadash or similar software or download the free Tari logger or whatever it's called. You just need to use your AP cable to connect the laptop to the ecu.
gmorris1 is offline   Reply With Quote
Old 06-13-2006, 11:10 AM   #7
thejean
Member#: 17763
Yeah, just go to this site and download the software: http://www.tari.co.za/cgi-bin/yabb2/...num=1138965460
Then use your AP cable to hook to your laptop. Read the user's manual first though. Oh, and don't try to log too many parameters at once as it REALLY slows down the sampling rate.
Old 06-13-2006, 11:41 AM   #8
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
Alright second problem then..... dang laptop is a mac...... who has the softwere and a laptop...... bloody mac i love my computer but in this case it is suckin right now
Old 06-13-2006, 11:48 AM   #9
thejean
Member#: 17763
So I did a run using the 93 OTS map on 94 octane last night (June 12). And yes, the car feels faster.
Data Log:
So, in a nutshell, it looks like I was getting up to 9 degrees of knock correction and therefore far more advance. No timing was pulled and EGT's appear acceptable at around 680C or 1250F. Now the IAT got as low as 17C but still... WOT in 5th gear at 28.5psi MAP (15.5 psi of boost) at 4900 RPM and 200kph and I still had +9 degrees of knock correction! I'd say that the Husky 94 is the shizznit. For that matter, a guy in town with an EVO 8 that is supposed to require 96 octane runs Husky 94 without any issues. So there you have it.
Now my next experiment will be to run the 91 map on 94 fuel and then go to 91 gas and see what happens. My guess is a lot of pulled timing.
Old 06-13-2006, 11:51 AM   #10
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
are you at home JC??? wanna pull a log for me?
Old 06-13-2006, 11:53 AM   #11
thejean
Member#: 17763
maybe tonight Kris. I'm at work right now.
Old 06-13-2006, 02:05 PM   #12
Wombat North
Member#: 21267
STI, EWG 8cm Green
mmmmm Where do I start.
Where are you getting your A/F reading from.
Where are you getting your EGT reading from.
Looks to me you have missfire on the first map because its pig rich and its showing as knock. This is based on you reading the stock A/F from the stock 02 sensor.
Old 06-13-2006, 02:10 PM   #13
thejean
Member#: 17763
All data is from stock sensors which is why I didn't comment on A/F. I thought the stock EGT number would be good though. Am I wrong?
I'm not sure why the car shows knock on the 91 map but it doesn't show up when I run the 93 map. Seems kinda odd to me as well. It's especially odd where it showed up.
Just so I'm straight here... +knock corr means its added timing (i.e., no knock) and -knock corr means its taken away timing (i.e., knock), correct? At least thats what the ECU explorer info tool says. BEcause if I'm wrong, this means the 93 map is pulling way more timing.
Old 06-13-2006, 05:53 PM   #14
Wombat North
Member#: 21267
STI, EWG 8cm Green
You are correct on the knock.
IMHO
Your 91 map is so pig rich that your getting misfires and is showing as knock.
EGT's readings after an uppipe cat is inaccurate at best.
Without the correct tools for tuning, you and I are completely in the dark.
Wait for Jarrad to tune.
FWIW
I have no trouble tuning for power but not knowing cylinder pressures based on WHP gained thru each degree of timing led me to get Dyno tuned, not forgetting the hardest tuning is for smooth delivery of power thru the whole RPM and load range. Jarrad is the man.
Old 06-13-2006, 06:55 PM   #15
thejean
Member#: 17763
Phew! ***wipes brow with back of hand***
I have no cat in my up-pipe so I figured my EGT's should be "close" to actual.
I know there is room to play with the AFR but I don't want to be the one to do it. Especially not on the stock O2 sensor. I can't remember, which of the two sensors does the AFR reading come from again?
I am definitely getting the PDX pro-tune but part of what I am doing here is trying to learn so when it comes time for me to have to do this on my own in a few years, I will know what in the hell I am doing. Plus, now I have a baseline to compare the "after pro-tune" logs to.
This is also giving me some insights into whether the Husky 94 is worth the money or not and whether using the 93 Cobb OTS map is safe until I get pro-tuned. Also, I thought others who didn't or couldn't get into the pro-tune might benefit as well. Its all about learning and sharing info.
Cheers all, JC
Old 06-18-2006, 05:20 PM   #16
thejean
Member#: 17763
Here's a run we did on Husky 94 in a 2006 Stg 2 STi:
Travis, can you PM you email addy so I can email you the raw log files? Thx, JC
EDIT: Everyone notice the 230+ g/s of air going into that bad boy? Most I could get on my 2002 WRX with 94 octane stg2 93 Cobb OTS map was 188 g/s.
Old 06-18-2006, 09:28 PM   #17
Wombat North
Member#: 21267
STI, EWG 8cm Green
Code:
mafv	g/s	lb/min	 hp
2.00	16.81	2.22	22
2.05	18.33	2.42	24
2.10	19.93	2.64	26
2.15	21.62	2.86	29
2.20	23.41	3.10	31
2.25	25.30	3.35	33
2.30	27.29	3.61	36
2.35	29.38	3.89	39
2.40	31.58	4.18	42
2.45	33.89	4.48	45
2.50	36.31	4.80	48
2.55	38.85	5.14	51
2.60	41.50	5.49	55
2.65	44.28	5.86	59
2.70	47.17	6.24	62
2.75	50.19	6.64	66
2.80	53.34	7.06	71
2.85	56.62	7.49	75
2.90	60.04	7.94	79
2.95	63.59	8.41	84
3.00	67.27	8.90	89
3.05	71.10	9.41	94
3.10	75.08	9.93	99
3.15	79.20	10.48	105
3.20	83.47	11.04	110
3.25	87.90	11.63	116
3.30	92.47	12.23	122
3.35	97.21	12.86	129
3.40	102.11	13.51	135
3.45	107.17	14.18	142
3.50	112.39	14.87	149
3.55	117.79	15.58	156
3.60	123.35	16.32	163
3.65	129.09	17.08	171
3.70	135.01	17.86	179
3.75	141.10	18.67	187
3.80	147.38	19.50	195
3.85	153.84	20.35	204
3.90	160.49	21.23	212
3.95	167.33	22.14	221
4.00	174.36	23.07	231
4.05	181.58	24.02	240
4.10	189.01	25.01	250
4.15	196.63	26.01	260
4.20	204.46	27.05	271
4.25	212.50	28.11	281
4.30	220.74	29.20	292
4.35	229.20	30.32	303
4.40	237.87	31.47	315
4.45	246.76	32.65	326
4.50	255.86	33.85	339
4.55	265.19	35.09	351
4.60	274.75	36.35	363
4.65	284.53	37.64	376
4.70	294.54	38.97	390
4.75	304.79	40.32	403
4.80	315.27	41.71	417
4.85	325.99	43.13	431
4.90	336.95	44.58	446
4.95	348.16	46.06	461
5.00	359.61	47.58	476
5.05	371.31	49.12	491
Just over stock, 230g's about 310hp Altitude sucks eh!
Old 06-18-2006, 09:36 PM   #18
thejean
Member#: 17763
You've got to be joking... our elevation has that much of an impact?
Old 06-18-2006, 10:59 PM   #19
Wombat North
Member#: 21267
STI, EWG 8cm Green
No joke. Also remember that an NA car is even worse.
Old 06-28-2006, 12:48 PM   #20
Airboy
Member#: 72829
2006 WRX
2015 WRX
This might be of interest. I have a '06 WRX and the Accessport. I downloaded the logging sw from Tari.co.za to try it out a few days ago.
The MAF reading peaked at ~185g/s,which is close to your Stg2 WRX with the 2.0L engine.
I was running 91 gas from Esso with the 91 map. I'll post the log file tonight.
Airboy is online now   Reply With Quote
Old 06-28-2006, 12:57 PM   #21
thejean
Member#: 17763
Airboy, you running stage 1 or 2?
Old 06-28-2006, 01:59 PM   #22
Airboy
Member#: 72829
2006 WRX
2015 WRX
Oops, forgot to mention I have no mods and am running a Stg1 map.
Old 06-29-2006, 01:20 AM   #23
Airboy
Member#: 72829
2006 WRX
2015 WRX
Data from logger. Mostly 2nd gear...
Code:
RPM   Throttle MAF(g/s) Timing  KPH     KC      Boost    AFR
2198	15.3	25.3	40.0	33	1.5	-3.6	14.70
2271	25.1	35.9	36.5	33	2.0	-1.5	15.04
2355	94.5	50.9	21.5	35	1.5	1.9	13.67
2463	100.0	58.2	17.0	35	1.5	3.2	12.63
2612	100.0	68.7	15.0	37	2.0	4.6	12.63
2754	100.0	78.7	14.5	37	2.0	6.2	12.17
2878	100.0	85.5	13.5	40	2.5	8.1	11.48
3063	100.0	99.0	11.5	40	2.0	10.3	11.03
3247	100.0	110.2	10.0	44	0.5	11.8	11.03
3402	100.0	121.1	9.5	44	0.5	12.3	11.03
3637	100.0	128.6	11.5	44	3.0	12.0	11.03
3784	100.0	140.4	12.5	50	3.0	11.9	11.03
3961	100.0	145.5	13.0	50	3.0	11.8	11.03
4150	100.0	146.0	14.5	55	3.0	11.9	11.03
4368	100.0	155.8	16.0	55	4.0	11.8	11.03
4550	100.0	162.9	16.5	62	4.0	11.6	11.03
4729	100.0	167.2	17.0	62	4.0	11.6	11.03
4889	100.0	173.2	17.0	68	4.0	11.5	11.03
5029	100.0	174.5	17.5	68	4.0	11.0	11.03
5266	100.0	180.0	18.0	75	3.5	10.6	11.03
5399	100.0	181.9	19.0	75	3.5	10.0	11.03
5588	100.0	183.6	19.5	81	3.0	9.7	11.03
5728	100.0	182.7	20.5	81	3.0	9.4	11.03
5860	100.0	183.2	21.0	81	3.0	9.3	11.03
5996	100.0	184.8	21.5	87	2.5	9.1	11.03
6140	100.0	185.2	22.0	87	2.5	8.9	11.03
6378	14.9	50.0	24.0	92	0.0	-4.4	11.03
6277	12.9	22.2	24.0	92	0.0	-9.1	12.06
5707	40.0	54.5	33.0	96	0.0	-3.9	14.36
4406	100.0	110.0	17.5	96	3.0	3.9	15.96
4507	100.0	145.2	18.0	99	4.0	9.0	13.09
4509	100.0	162.1	16.5	99	4.0	11.9	11.14
4635	100.0	164.9	16.5	102	4.0	12.0	11.03
4710	100.0	166.8	16.5	102	4.0	11.9	11.03
4791	100.0	169.4	17.0	104	4.0	11.9	11.03
4866	100.0	172.1	17.0	104	4.0	11.8	11.03
4900	100.0	173.2	17.0	104	4.0	11.6	11.03
5019	100.0	175.9	17.0	108	4.0	11.6	11.03
5097	100.0	178.9	17.5	108	4.0	11.5	11.03
5143	100.0	179.3	17.5	111	4.0	11.0	11.03
5194	100.0	180.0	18.0	111	4.0	11.0	11.03
5302	100.0	182.7	18.0	116	3.5	10.7	11.03
5367	100.0	181.2	18.5	116	3.5	10.6	11.03
5430	100.0	184.1	19.0	119	3.5	10.3	11.03
5493	100.0	182.7	19.0	119	3.0	10.2	11.03
5518	100.0	181.9	19.5	122	3.0	10.0	11.03
5624	100.0	182.7	20.0	122	3.0	10.0	11.03
Old 06-29-2006, 11:48 AM   #24
thejean
Member#: 17763
I'm surprised you only got a little over 12 psi of boost. Your g/s should be even higher I would think at full boost. Those 06's are bad-ass machines.
Old 06-29-2006, 12:39 PM   #25
Airboy
Member#: 72829
2006 WRX
2015 WRX
I think ~12PSI is full boost (for stock anyway). In the issue of the SubieSport where dyno'd an '06, the boost max'd out at ~0.8 Bar, which is ~12PSI
Husky 94 in Red Deer? STI-TOM Western Canada 1 06-21-2006 06:14 PM
AP Stage2 93 octane map and Husky 94 gas... thejean Western Canada 13 04-04-2006 10:46 PM
Husky 94, A/F's, EGT oh my! long Wombat North Canada Region Forum 38 08-02-2005 02:23 AM
91, 92, 93 and 94 octane Fusionpnoy Engine Management & Tuning 1 08-16-2004 02:17 AM
Post subject: blinking CEL under WOT, can someone help me with my log pls! kschmohl Engine Management & Tuning 5 10-07-2003 08:15 PM
