Old 06-12-2006, 12:48 PM   #1
i0nic
Member#: 88605
2014 WRX STI
Plasma Blue Pearl
Default reccomend a wideband o2
I've decided to purchase the streettunner software from cobb. What wideband o2 sensor would you reccomend getting?? Also, where is this sensor typically installed?
Thanks!!
i0nic is offline   Reply With Quote
Old 06-12-2006, 12:55 PM   #2
jays05
Member#: 78165
05 STI 35r + e85
I am using the Innovate LC-1 wideband o2. Works fine with streettuner and lets me log AFR's and all that.
However if I could do it over again I'd go with the zietronix zt-2. It does what the LC-1 does, but it also lets you datalog boost and egt, and integrates all of it into your streettuner logs.
The wideband o2 sensor should be placed in the downpipe.
jays05 is offline   Reply With Quote
Old 06-12-2006, 01:02 PM   #3
Zumble
Member#: 34860
2005 Forester CGM
ZT-2 is nice. Also, the PLX M-300 USB was specifically made for use with Street Tuner.
Zumble is offline   Reply With Quote
Old 06-12-2006, 01:08 PM   #4
i0nic
Member#: 88605
2014 WRX STI
Plasma Blue Pearl
aah. well there is my first problem. I have a stromung DWG downpipe that did not have a bung on it. Is this something a shop could put on? or would i need a new downpipe??
Old 06-12-2006, 10:06 PM   #5
jebjkey
Member#: 73884
Chapter/Region: HIIC
16 HyperBlue STi
16 Crystal White STI
A shop can weld a bung in the for you. Make sure it is on the top (preferably) or at least on the top half of the pipe. This will prevent problems with the O2 sensor.
jebjkey is offline   Reply With Quote
Old 06-13-2006, 12:50 AM   #6
Christian.
Member#: 87604
The PLX Devices R300 & R500 work super well. I especially like the additional features of the R500, knock sensor tapping, EGT input, etc.
The ZT-2 is nice as well.
Christian.
Christian. is offline   Reply With Quote
Old 06-13-2006, 11:36 AM   #7
jdgrimm
Member#: 74386
02- 2.5 Hybrid
GrimmSpeed
wb02 noob here...
i'm a little confused on what exactly you need. do you really need a controller? Can i just get an 02 sensor that goes to a gauge? If so, could someone refer a sensor/gauge package.
jdgrimm is offline   Reply With Quote
Old 06-13-2006, 11:47 AM   #8
Bayley
Member#: 49763
2004 WRX
Jetzt mit 25% mehr Motor!
Originally Posted by jdgrimm
wb02 noob here...
A wideband O^2 sensor needs a "heat pump" to control the sensor temperature. This is where the microcontroller is needed as the module needs to read the sensor temperature and adjust the heater suplpy signal (PWM signal) to the sensor.
Bayley is offline   Reply With Quote
Old 06-22-2006, 10:06 AM   #9
mokujin22
Member#: 112450
2002 Silver Bug-eye
30 mpg 2000 Neon...Hi!
Christian.
The R500 is well... over $500. Is it worth the extra features? (Sorry for the dumb question) I'm about to swap in a built 2.5 into my '02 and will get a pro-tune locally. If I'm not going to be doing any tuning myself, do I really need the stand-alone data-logging feature? When I go to my tuner, won't he have this capability on his computer?
I'm already dropping about $6K on this build, if the R500 is that much better, what's the extra $250? But if it's a feature I'll never use, the I'll get the 300.
Again, sorry for the dumb question. I understand nuts and bolts and some suspension, but when it comes to electronics, I'm a bit ignorant.
Tony
mokujin22 is offline   Reply With Quote
Converting Stock narrowband o2 to wideband o2? n1c3tr1 Engine Management & Tuning 11 02-04-2010 12:07 PM
can i zip tie second o2 sensor and put wideband o2 in that spot? sidwin AccessPort 2 02-11-2008 06:18 PM
Wideband o2...can it replace my stock o2? IllNastyImpreza Normally Aspirated with bolt-on Forced Induction Powertrain 18 12-21-2006 11:13 AM
Wideband o2 systems. A few choices. AZScoobie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 44 08-24-2002 06:26 PM
measuring wideband O2 V's? RidinLow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 06-23-2001 12:09 AM
