Welcome to the North American Subaru Impreza Owners Club Saturday August 29, 2015
Old 06-12-2006, 02:52 PM   #1
smackedownz
Member#: 84841
2010 WRX
Default vf30 cobb 2.5 boost
OK, i have a VF30 and am running the stage 2.5 VF30 map from cobb on my 05 rex. The most boost I can ever hit is .09 on the stock gauge, I dont know what the problem is, I dont think im just imagining things because I could swear at stage 2 a few months ago i boosted significantly over .1 . Also, this did not start when I installed the VF30, it was happening with the stage 2 map as well. If this helps, I notice a sort of blowing/whoosh sound coming from somewhere at all rpms, whether it is idling or accelerating or what. I also hear a ticking/clicking coming from the downpipe area of the engine. Any ideas?
smackedownz is offline   Reply With Quote
Old 06-12-2006, 10:03 PM   #2
jebjkey
Member#: 73884
2005 STi
2006 Evolution MR
Since you had to pull the intercooler and many connections off when you did the turbo swap, the possibility of a leak before and after is possible. A leak prior to the swap might have gotten fixed only to have a different one show up when you put everything back together. Have you gone back and checked the tightness of all the bolts? If there is a leak before the turbo, you should be able to see some blackening around the area of the leak. If there is a leak after the turbo on the exhaust side, it will not give low boost. If there is a leak after the turbo on the compressor side, you will have a situation like what you are experiencing. Check the Y-pipe to the intercooler and the throttle body coupler. Also, if your wastegate solenoid has a problem with the hoses, your boost will be off. Did you use the stock turbo wastegate hoses? The hose with the brass restrictor goes on the compressor outlet side of the T to the wastegate and solenoid. If that brass restrictor is placed on the wastegate side of the T, you will have low boost.
The vf30 wastegate hoses are not compatable with AP mapping. I know this for two reasons. First, when I went stage 2.5 I tried it with the vf30 hoses first and things were horrible. Second, I have ST now and have since sold the stock turbo with the stock hoses. I put the vf30 hoses back on and began retuning my turbo maps for the vf30 hoses. Wastegate solenoid duty cycle was dramatically different with the vf30 hoses. The stock turbo hoses needed about 80-90% duty cycle to hit 18.5#, the vf30 hoses used about 40-45% duty cycle to hit 18.5#.
jebjkey is offline   Reply With Quote
Old 06-15-2006, 03:03 AM   #3
clamdip
Member#: 18709
i would say check the wastegate hoses. also, check the brass restrictor pill. that's the only thing i can think of at this point.
clamdip is offline   Reply With Quote
VF30 cobb 2.5 not hitting target boost smackedownz AccessPort 12 06-26-2006 09:52 PM
vf30 cobb 2.5 boost smackedownz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-12-2006 05:11 PM
cobb 2.5 boost WV_guy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 11-11-2004 02:30 PM
VF30 + Cobb 2.5 reflash review cre Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 85 11-08-2004 09:12 AM
Cobb 2.5 VF30 times (13.16 @ 105.27) cre Proven Power Bragging 16 02-18-2004 09:19 PM
