#1 |
Member#: 249
Vehicle:05 FXT psm 06 E55 |
What setting are you using on the Whiteline 20mm rear bar for a 2K Wagon?
#2 |
Member#: 2629
Depends what you want. The stiffer you make the bar (inner holes) the more trailing throttle oversteer you will get, and the sharper turn in you will get.
I started out in the middle hole back in November. I loved it. I switched back to the outer hole (softest) when I put the snow tires on because I got tired of the rear swinging out on me when I tried to pull into traffic. The softer the rear bar, the earlier you can put the power down without going sideways. With all of the snow we have been having, I have no problem getting full throttle oversteer even with the sway bar disconnected. |
| Thread Tools | |
| Display Modes | |
| What should my RPMs be at 55mph? | 1997OBS | Newbies & FAQs | 10 | 06-02-2010 11:14 AM |
| Tell me what happened to my A/C...I'll tell you what I ate for breakfast | -=C=- | Off-Topic | 15 | 06-01-2010 03:18 PM |
| Adjusting rear swaybar Now! What hole is the stiffest setting?? | mrtrex | Brakes, Steering & Suspension | 6 | 09-07-2007 06:00 PM |
| What is this hole on my frontend, and what kind of lights can i get for it? | wonderbud | North West Impreza Club Forum -- NWIC | 8 | 03-08-2007 01:20 PM |
| what did you plug the uppipe (stock or otherwise) EGT hole with? what thread is it? | rex n effect | Factory 2.0L Turbo Powertrain | 6 | 05-22-2003 06:48 PM |
