Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 06-12-2006, 07:02 PM   #1
westy66
Member#: 4329
2005 LGT Wagon 5MT
Default ECU reset with a UTEC?
i installed a new battery yesterday after my original finally died.... almost 5 years to the day after i got it. heres my question... does an ecu reset do anything if you have a dyno tuned map being used?
im asking because after the battery install my car feels slower than it was i havnt done a reset in a loooong time, and i cant ermember if ive ever experienced this.
btw, UTEC, VF-30, TBE, pinks and pump.
thanks,
Bob
westy66 is offline   Reply With Quote
Old 06-13-2006, 01:31 PM   #2
fzturbo
Member#: 43482
2004 JDM 2 litre STI
You'll have to wait till the stock ecu adjust the fuel trims, this takes about 200 KM of driving.
fzturbo is offline   Reply With Quote
Old 06-13-2006, 05:11 PM   #3
knucklesplitter
Member#: 64246
If you are using open-loop fueling on the UTEC, a reset makes no difference above 25% throttle. The ECU's recalibration has no effect on the UTEC in open loop.
If yours is an older UTEC using closed-loop fueling, then yes, the ECU's learning will affect the UTEC's performance.
Either way, idle and part throttle will perhaps change a little as the ECU learns after reset.
knucklesplitter is offline   Reply With Quote
Old 06-23-2006, 03:42 PM   #4
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
Check out this link
LINK
Smoby is offline   Reply With Quote
whos had there ecu reflashed with a utec? Smoke Show Canada Region Forum 6 05-28-2006 03:13 PM
ECU reset messing with UTEC settings? Big Turkey Engine Management & Tuning 4 06-14-2004 11:57 AM
ECU reset with a new muffler? scooby-stu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-17-2004 12:45 AM
Can you do an ecu reset with the utec still plugged in? waitandbleed92 Engine Management & Tuning 4 03-31-2003 03:49 PM
ECU reset with new cat back exhaust? jay25RS Normally Aspirated Powertrain 1 06-27-2001 12:42 PM
