06-12-2006, 09:12 PM | #1 |
Member#: 105753
True or False: Early EJ18's had JDM STI cranks and rods
I seem to remember reading somewhere that the 1993 Ej18's (1.8L) came from the factory with STI cranks and con rods. Is there any merit to this? If so, did it continue past '93? IIRC, it was either Subachad, Matt Monson or Storm that said this.
If i have a '93 crank and a '95 crank sitting side by side, how do I tell if one is forged (STI)?
06-12-2006, 09:22 PM | #2 |
Member#: 72798
Vehicle:2000 2.5 RS Sedan Blue Ridge Pearl |
I have never heard of this, but it would be cool if it were true, I have a 93 1.8 sitting in my garage.
06-12-2006, 11:00 PM | #3 |
Member#: 8488
Vehicle:1993 Impreza GCStyle Teal |
I heard the same thing. I think this actually comes from Mike Shields SPD site.
P.S. www.uniquemotorsports.com is coming back online, I'm uploading the site now. |
06-13-2006, 03:52 AM | #4 |
Member#: 105753
I'd like to find out the true story to this. Anyone have any ideas where to find out?
06-13-2006, 10:25 AM | #5 |
Member#: 2289
Vehicle:1998 11.87@112mph Subaru L Ver 6 STi Type R |
Yes its true. ALL early blocks had the same internals. JDM and USDM EJ18, early EJ20, EJ22 na and EJ22t all the same goodies. All cranks are forged.
06-13-2006, 10:48 AM | #6 | |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
06-13-2006, 11:02 AM | #7 |
Member#: 5030
Vehicle:1999 Legacy 2.5GT 19 Audi RS3, 13 Armada |
Mike is good for old school random facts like that.
06-13-2006, 12:34 PM | #8 |
Member#: 33782
Vehicle:96 3MI Racing search FIRST, then PM!!! |
from what I've been told and seen pics of the old EJ18's 93-94 had STi cranks and rods as well as upper ("dogbone") engine mount...
I know mine had the dogbone and guess I need to crack open the old block and find out what's really inside... what Matt said I know to be true with the old STi RA internals... |
06-13-2006, 01:59 PM | #9 |
Member#: 832
RMIC
Well,
wouldn't it still be more correct to say that STi's used a standard production crank than to say that Ej18's got STi cranks? I know it's just a question of terminology, but if we want to be correct about it that's what happened... |
06-13-2006, 02:00 PM | #10 | |
Member#: 33782
anyone have an old school STi (not RA) crank that they can take pics of to compare?...weight would be a good factor too... |
06-13-2006, 02:15 PM | #11 |
Member#: 832
RMIC
I do have an STI crank at home. It's from an RS-RA Legacy, but it's still an STi crank. This crank has been massaged for sure, and like I said, it's signed in Japanese. I compared it to my standard Ej20G crank and there were differences. I'll see what I can do for pictures...
06-13-2006, 03:06 PM | #12 |
Member#: 33782
RS-RA...was that not the RA of the legacy's when they were used for rally...?...
that would make it massaged like any other sti RA...we know those were balanced by hand... was your EJ20G from a baseline turbo or sti ? |
06-13-2006, 03:18 PM | #13 |
Member#: 832
RMIC
I guess we need to do some more digging. I was always under the impression that both STi and STi-RA engines were massaged, and only the standard WRX and WRX-RA's were not. My Ej20G was a standard auto engine from a '93 Legacy GT. The RS-RA was the only STi variant back in '90-93 before the WRX's came out.
I have also been trying to figure out when they stopped numbering the heads. The catch is that the numbers are behind the exhaust cam gears, and unless someone pops their engine, they don't ever go into the engine that deep. Even for a timing belt change, they aren't going to take off that gear where they could see the numbers... |
06-13-2006, 04:46 PM | #14 | |
Member#: 4498
NWIC
Vehicle:WRX H6-3.0 Turbo www.surgelinetuning.com |
Take a look at the EJ18 rods and crank: Crank Rods There are a couple of things you can tell from these sheets: As far as the crank goes, the AA031 was superceded by the AA080, then the AA081. Given the break out, it looks like AA081 is a very new update, as up to the 97MY came with the 080. Also notice that for the very first set of production for MY93 (June 92-Jan 93), the AA080 is the final superceding part number. Usually if there is a new crank , it would be usable in all of the previous configs. It is possible this is a data error, as I have seen this mistake before (meaning you could only order the AA081 now). I will look in the JDM catalog and see what the STI crank number is. It is also interesting to note that the crank is the same one used in the 94,95 and 96 EJ22. As for the rods, the AA041 is superceded by the AA042 and AA051. However in mid MY 97, the rods went to a new part, the AA140. Given that this is not listed as a supercede, I suspect there was a change in the piston as well. Again, I will check the Japanese catalog and see what the 93 STI had. Cheers, Jeff Sponaugle PDXTuning.com |
06-13-2006, 05:01 PM | #15 |
Member#: 33782
funny the aa031 isn't showing superceded by the aa081 now...still shows aa080...
06-13-2006, 05:34 PM | #16 |
Member#: 832
RMIC
sponaugle to the rescue...
06-13-2006, 05:40 PM | #17 |
Member#: 105753
so, will those numbers be on the crank?
The dilemna I'm having is this: I have my old '93 EJ18. I also have two "newer" '95 EJ18's. I'm building a 1.8 for boost. Is it advantageous to take the '93 crank and rods and dump them into the '95? Either way, the motor is getting a full rebuild (bearings, seals, valves, etc. etc.) The '93 is not in the best condition. I had a hard time getting the motor and tranny apart when i did the 2.5 swap. I wasn't at all gentle with the B.F.H., and the block is pretty much toast (on the outside, anyway) The '95 is in decent shape on the outside, so I wanted to use the '95 block, '93 internals, if that gives me any added durability. |
06-13-2006, 05:58 PM | #18 | |
Member#: 4498
NWIC
It was used on the Version 4 and 5 EJ20K, the Version 3-Version 6 STI and STI RA, as well as the S201 and 22B. It is possible however that an early 93 1.8 would have the older AA031, not the newer AA080/81. As for the rods: The 41/42/51 rod was used in the version 2 STI, but was superceded by the AA150 very quickly. All of the Version 3 and Version 4 has the AA150. Version 5,6, and 7 had 210/240, which is the current 'JDM STI' rod as well as the same rod used in the USDM STI. So, it looks like the rods you have from the 93 or 95 are not the same as the JDM STI ones. Jeff |
06-13-2006, 06:06 PM | #19 |
Member#: 832
RMIC
So this begs the question, how could they use that crank on the v5-v6 engines if they were phase II with an end thrust bearing?
06-13-2006, 06:23 PM | #20 | |
Member#: 105753
06-13-2006, 07:25 PM | #21 |
Member#: 57784
Vehicle:1994 Impreza L Sedan Aspen White |
so my MY94 1.8 shows AA080...
does that mean its thesame as the forged JDM? |
06-13-2006, 08:11 PM | #22 | |
Member#: 2289
06-13-2006, 08:48 PM | #23 |
Member#: 105753
pulled some numbers off of the '93 crank and rods. Don't know if they mean anything....
Crank: CBBCC IIII below that, it reads: 822552 L Rods: one reads: AGD GD44 another reads: AGI GI44 mean anything? Tomorrow I'll have the '95 block pulled apart, and I'll see what that has to say...... |
06-14-2006, 12:42 PM | #24 |
Member#: 33782
I hope to be able to pull apart my my94 (will check production date) EJ18 and see what she says...
06-14-2006, 02:12 PM | #25 |
Member#: 51282
SCIC
Vehicle:98 RS black & blue from parking |
Very interesting thread...
Spec C 2.0 build. Stroked with STI crank and rods. Pictures | reddevil | Built Motor Discussion | 61 | 08-17-2010 05:07 PM |
2007 sti crank and rods | PIECEOFTHEPIE | Engine/Power/Exhaust | 11 | 02-15-2009 10:18 AM |
F.S. 04 STI Crank And Rods | efrain_n7 | Engine/Power/Exhaust | 11 | 06-12-2008 08:24 PM |
FS Houston: STI Crank and Rods | Rancid | TXIC Private Classifieds | 2 | 08-15-2007 12:17 PM |
STi Crank and rods in wrx | SQB SNX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 11-14-2005 04:53 PM |
