Old 10-15-2001, 09:15 AM   #1
HRE | giulio
Member#: 481
Default Is the ECU closing the injectors?
When the ECU sees fuel pressure skyrocket, will it compensate by shortening the injector's open time?
And if so, what gadget is there to trick it into seeing 'normal' pressures?
Thanks,
g
HRE | giulio is offline   Reply With Quote
Old 10-15-2001, 10:08 AM   #2
efoo
Member#: 80
the ECU has no fuel pressure sensor to read -- it "senses" something is up when the regular injector pulse widths start making the car run super rich (O2 sensor reading), so it starts closing down the pulse widths to make the car run stoich again.
however, this is only done during closed-loop operation. during WOT, the ECU reverts back to static injector pulse widths in some tables someplace. perhaps what you want to do is fool the ECU into thinking you're at WOT most of the time except at normal cruise. You don't want to be at WOT all of the time though; your idle and low end will probably suffer greatly.
efoo is offline   Reply With Quote
Old 10-15-2001, 02:35 PM   #3
HRE | giulio
Member#: 481
Thanks for the reply efoo.
So why would it go lean with high fuel pressure... or how can i 'fix' that?
When i start a run from idle, and WOT the whole time A/F is perfect.
But if i'm cruising in 4th/5th and WOT, it's lean.
I just dont get it.
Setup: 255 pump, 6:1 FPR, stock injectors, SAFC, 4~6psi on EJ25.
Thanks,
giulio
Old 10-15-2001, 02:56 PM   #4
efoo
Member#: 80
It isn't ECU-related, IMHO. That's simply due to the fact that your engine is under higher load to begin with when you go WOT in 4th/5th instead of from a stop in 1st. I do my TEC-II tuning runs in 4th gear for this reason -- what's safe for 4th gear is a little rich for 1st gear, but safer.
Try easing into the gas and then going WOT slowly in 4th/5th -- I bet you won't run lean. If that happens, it means your RRFPR isn't reacting quickly enough and you're getting a transient lean condition on throttle tip-in. On the TEC-II, I can set a parameter that dumps in 10% more fuel for a brief period when I really nail the gas hard, so that's how I get rid of that problem.
If you go lean even when getting on the gas slowly, you just need more fuel across the board under boost, that's it.
-Edwin
Which wire to the ECU id the MAP wire? renhoek Pre-2002 Factory Turbo Powertrain 2 12-08-2008 01:10 AM
how the ecu works...closed loop...open loop? IllNastyImpreza Engine Management & Tuning 13 11-26-2005 05:06 PM
does reseting the ECU clear the boost numbers stored in there? dijay Warranty Issues & SOA Problems 3 09-03-2002 09:41 AM
Where is the ECU in the WRX? Ginseng Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-28-2001 06:21 PM
Does it needed to reset the ECU for the following changes? V6 Normally Aspirated Powertrain 5 10-27-2000 09:32 AM
