Old 11-05-2000, 06:25 PM   #1
jkyes
Member#: 707
99 Legacy GT
Quick silver
Question 99 legacy MAF
i have heard there is problems with the MAF in 99 legacy's when putting high flow intakes. does anyone have experience with this, could you give me some info. solutions, ideas, or is this not a problem. thanks...
jkyes is offline   Reply With Quote
Old 11-05-2000, 07:00 PM   #2
nuburu2
Member#: 2609
98 BK-GT White
'97 SVX Ebony Pearl
Post
Try Larry's just completed intake at ImprezaRS.com. Won't be a problem!
Glenn
nuburu2 is offline   Reply With Quote
Old 11-05-2000, 08:55 PM   #3
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
Post
I've been using the JC Sports Intake on my '98 Legacy L w/ no probs what so ever w/ my MAF sensor.
GTBGUY is offline   Reply With Quote
Old 11-05-2000, 09:33 PM   #4
jkyes
Member#: 707
99 Legacy GT
Quick silver
Post
i have heard there is a specific problem with the 99 legacy MAF. anyone heard anything?
Old 11-05-2000, 11:49 PM   #5
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Post
The MY99 MAF on the Imprezas is very prone to dying with aftermarket intakes. I'm not sure if the RS and Legacy share the same part for 99.
The 00-01 have a MAS.
DLC is offline   Reply With Quote
Old 11-06-2000, 12:34 AM   #6
BG5
Member#: 695
Post
the 99 GT's have the same hot-wire MAF sensor
as the 98 RS' so whatever problems the 98 Impreza's have the 99 GT's will have too.
that said, the GT's generally don't have problems with their MAF's unless you over-oil a filter or something.
BG5 is offline   Reply With Quote
Old 11-06-2000, 08:50 AM   #7
2.5GT
Member#: 2697
2000 Celica GT-S
Spectra Blue
Post
I have a 97 GT which also uses a hot wire filament instead of the foil element MAF. It didn't matter, though. I blew my MAF after installing a high flow intake. Not much to say, except that it cost me $300 to replace. Oh well, looking for a dependable intake (God I miss the scream of that intake!!!).
2.5GT is offline   Reply With Quote
Old 11-06-2000, 09:39 AM   #8
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Wink
99 Impreza's are the ones with issues...
99GT's??? never heard about issues with the MAF...
i've had my intake (Weapon R) since August of 99 and i have NEVER had an issue with the MAF
j.
Old 11-06-2000, 11:46 AM   #9
Mx5racer
Member#: 2629
Post
The issue probably came from Sports Compact Car, who went through several MAF's on their project impreza after changing the intake (which lost the isolation from vibration). As I recall, this was specific to the 99 car. (other's will know better if it applies to the Legacy also).
Mx5racer is offline   Reply With Quote
Old 11-06-2000, 11:50 AM   #10
silverSurfer
Member#: 1361
1999 Legacy GT Ltd.
2006 Rav4 Sport Silvarrr
Post
so in other words, no real problem to the MY99 Legacy GT? I wasn't too sure of this myself and am kinda hesitant on replacing the intake. I just removed extra snorkus & installed drop in K&N Panel filter. Works fine for me, except that annoying whine..
-chrisC
silverSurfer is offline   Reply With Quote
Old 11-06-2000, 11:54 AM   #11
CRAZY KEN
Member#: 1176
2012 MB E550 4M
2015 P85D
Exclamation
I have a Weapon-R F1 intake system for MY99 Legacy 2.5 GT and so far it hasn't been giving me any problems...but if there was a problem, what would be a typical symptom!!! I installed my intake a year ago by the way!!! Oh, and does anyone one know the proper thing to do with the two pvc valve tubing...do I put a breather on it...adapt it to the intake plumming???
CRAZY KEN
CRAZY KEN is offline   Reply With Quote
Old 11-06-2000, 12:12 PM   #12
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Post
here's a pic of mine...
i ran both into the intake system
<IMG SRC=http://www.subiegal.com/images/My%20Car/engine1-00.jpg>
Old 11-06-2000, 03:33 PM   #13
Force[FED]
Member#: 292
2011 BMW 535i
Havana Metallic
Post
The MY99 2.5GT uses the same MAF that was used in the MY98 2.5RS. I have the EXACT same MAF that my brother has in his 98 2.5RS, which is the MAF with the flat top on it(the hot wire setup). The MAF that was failing all the time is a cylindrical shaped MAF, with no flat area (film type MAF). The later type MAFs are much more sensitive to failure, but I have yet to hear of ANY of the hot wire types failing.
My brother has been sucking 8-10psi of pressure over his MAF for 25K miles, and it's fine. Us MY99 GT owners have nothing to worry about.
Enjoy!
Kev
Notice the top on the MAF on my car...this is the hot wire type! The film type MAF has a plug right into the cylindrical part.
www.lagging.com
[This message has been edited by Force[FED] (edited November 06, 2000).]
[This message has been edited by Force[FED] (edited November 07, 2000).]
Force[FED] is offline   Reply With Quote
Old 11-07-2000, 10:26 AM   #14
jkyes
Member#: 707
99 Legacy GT
Quick silver
Thumbs up
cool that was the info i was looking for, it sounds like the things i have heard were about the 99 impreza and not the 99 legacy. that will expidite my search for a new intake. i currently have removed the silencer, and have added a amsoil filter. love it, but i think a new high flow type with a good muffler will be very nice. ah ah ah... more power
Old 11-07-2000, 06:21 PM   #15
silverSurfer
Member#: 1361
1999 Legacy GT Ltd.
Post
Reposted e-mail from Trey Cobb:
<<Subaru has used a MAF sensor up until
the MAP sensors were used in some MY99 and the MY00 models. The big change
was that the MY99 MAF sensors were of a FILM type, instead of wire. This
means they are very fragile. Even the WRX/STI MY99-MY00 models are like
this. Vibration, heat, and oil/dirt will make these units fail very
quickly.
As for the MY99 Legacy using the film sensor, this I'm not 100% certain of.
I think it depends on the build date. I'd recommend being safe before being
sorry.
Thanks,
Trey>>
so hmmmmmmmmmmmmmmmmmmm???????
-chrisC
Old 11-07-2000, 07:57 PM   #16
Force[FED]
Member#: 292
2011 BMW 535i
Havana Metallic
Post
Again, it's fairly simple to tell what you have. If you get SCC mag, look at some of Shiv's write-ups, and in his pics you will see that his MAF (the hot FILM type) is a cylinder only, no flat surface. Then look at the picture of my car above, and you can see that the MAF has a large flat surface that the connector plugs into. This is the hotwire type. Then you can see what you have for yourself on your car!
Kev
Old 11-08-2000, 09:35 AM   #17
Radio Flyer
Member#: 374
'98 2.5 GT Wagon
Rio Red
Exclamation
Putting in my 2&cent;,
The GT continued with the same DOHC engine until the 2000 model year when the body style changed as well.
We have the same engine used in the MY98 RS. Then, for the 2000 MY, the engines were made the same between the two cars. The GT was never saddled with the hot-film MAF.
Now, quit worrying and go have some fun!
&nbsp;&nbsp;- Eric
&nbsp;&nbsp;&nbsp;&nbsp;'98 2.5 GT Wagon - <a href="http://208.9.184.110/MembersList/ViewMemberPics.cfm?MemberID=143" target="_blank">Pics</a> - <a href="http://www.jeneric.ws/eric/radioflyer.htm" target="_blank">Page</a> -
Radio Flyer is offline   Reply With Quote
Old 11-09-2000, 05:44 PM   #18
jkyes
Member#: 707
99 Legacy GT
Quick silver
Post
ok i am done worrying. now lets drive!!!
will a 99 2.5rs engine bolt into a 99 legacy outback? IllNastyImpreza Subaru Conversions 18 06-27-2007 11:26 PM
MAF Voltage Threshold - 99 Legacy GT MY99 2.5GT Normally Aspirated with bolt-on Forced Induction Powertrain 0 12-19-2006 02:09 PM
WTB 99-01 2.5RS or 99 legacy GT trans rally 763 Mid Atlantic Impreza Club -- MAIC 0 01-25-2005 03:03 PM
Looking for 97-99 Legacy GT / 99-01 RS Sedan / 97-01 O.B.S. for a friend BrysImpreza New England Impreza Club Forum -- NESIC 2 05-12-2002 08:43 PM
99 Legacy wheel on a 96 Legacy? nuburu2 Legacy Forum 23 12-30-2000 10:27 AM
