Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 06-13-2006, 05:28 PM   #1
ScoobyTodd
Member#: 19186
2005 STi
Default WRX trunk & wing--STU legal?
After reading the SCCA SoloII rules I can't make out if this rule means a WRX wing with 3rd brake light is a suitable replacement for an STi trunk with wing and third brake light. Anyone want to shed light on their thoughts? I'm mainly looking for weight reduction.
Ideally, I'd go with an RS trunk and no spoiler and install the RS 3rd brake light, but correct me if I'm wrong, that doesn't comply with STU rules...correct?
Standard parts may not be
removed except for the substitution of spoilers, rear wings,
bumper covers and valances. Rear wings must attach only aft of
the rear wheel centerline. Total surface area of all spoilers, splitters
and rear wing may not exceed 8 square feet as seen from
above (see 12.9). Substitution of rear spoilers or wings must
retain any original third brake light functionality unless otherwise
equipped.
ScoobyTodd is offline   Reply With Quote
Old 06-13-2006, 05:32 PM   #2
10th Warrior
Member#: 2230
2000 2.5RS
Silverthorn, PGT #671
you've got it right. you can swap to the WRX wing but you can't go wingless.
10th Warrior is offline   Reply With Quote
Old 06-13-2006, 05:37 PM   #3
ScoobyTodd
Member#: 19186
2005 STi
So wingless is reserved for BSP then, correct?
Old 06-13-2006, 06:02 PM   #4
AtomicRacer
Member#: 84586
1995 Frankenpreza
2012 Tundra DC 5.7L
In STU, specifically for the STi, you can not go to a spoiler either, it must be a wing with a third brake light in the wing similiar to factory. This was told to me by someone who is extremely familiar with this ruleset and has given this particuliar issue much thought. He has also survived a protest on the very subject.
In light of that, yes, the WRX wing is perfectly legal in STU.
-Paul
AtomicRacer is offline   Reply With Quote
Old 06-13-2006, 09:30 PM   #5
Chiketkd
Member#: 71634
In hibernation...
-Paul
So using that same logic, the STi wing would be legal on a WRX in STU?
Chiketkd is offline   Reply With Quote
Old 06-13-2006, 09:34 PM   #6
alltracin
Member#: 100265
1999 powered '90
Miata
No chike, don't do it! lol
alltracin is offline   Reply With Quote
Old 06-13-2006, 11:58 PM   #7
ULLLOSE
Member#: 117505
2005 RX8
05-08 SCCA BS Natl Champ
In BSP the STI has to run the OE wing as the WRX is in ESP so they can not share parts. The only change will come when/if the special edition STI goes on the same line with the regular STI then they could share parts in BSP.
ULLLOSE is offline   Reply With Quote
Old 06-14-2006, 01:03 AM   #8
dowroa
Member#: 17498
No More Subarus :(
Only a truck, for now. ;)
So, if you put a piece of tape labeled "wing" with an led connected to the brakes on a bare trunk, it would pass the rule.
- dow
dowroa is offline   Reply With Quote
Old 06-14-2006, 02:30 AM   #9
AtomicRacer
Member#: 84586
1995 Frankenpreza
2012 Tundra DC 5.7L
- dow
Not saying I would do it, but it has been done before.
-Paul
Old 06-14-2006, 02:35 AM   #10
Uber Wagon
Member#: 39600
2008 STi
Dark Grey Metallic
I assume you would have to retain the STi trunk springs though correct? Can anyone say how bad of a "catapult effect" you get?
Uber Wagon is offline   Reply With Quote
Old 06-14-2006, 10:24 AM   #11
ScoobyTodd
Member#: 19186
2005 STi
- dow
I doubt I'd ever be that desperate, but I suppose that should be "legal."
Old 06-20-2006, 03:09 PM   #12
Chiketkd
Member#: 71634
In hibernation...
Don't worry Mr. 'No Wing'! I'll be keeping my factory WRX spoiler as I want to complete a full season on r-comps in D-Stock next year. Then I plan on deciding whether I want to get coilovers & street tires and move to STU or stay in D-Stock.
Old 06-20-2006, 03:54 PM   #13
sciolist
Member#: 50200
2004 STi
I'll put it this way: Don't use the remote release unless you have someone back there holding the lid down... or unless you actually are trying to hurl a projectile over the car.
sciolist is offline   Reply With Quote
Old 06-20-2006, 06:01 PM   #14
rankink
Member#: 12901
2005 STi/95 VX
Pastelito Racing / SFSOC
It just went on the same line as the regular STi, so it looks like people can get rid of the STi wing in favor of the limited wing.
rankink is offline   Reply With Quote
Old 06-20-2006, 08:02 PM   #15
ScoobyTodd
Member#: 19186
2005 STi
This would only be legal in BSP though, right? I'm really looking for a STU option here besides keeping the wing and/or ghetto-rigging up a "legal" wing.
Old 06-20-2006, 09:04 PM   #16
jcroy66
Member#: 42675
2003 WRX #177 STX
www.TeamSoloRacer.com
Anyone know if the trunk itself is the same part number between the WRX and the STi? I just noticed that this thread mentioned switching the trunk too.
jcroy66 is offline   Reply With Quote
Old 06-20-2006, 09:44 PM   #17
KC
Member#: 442
13 Crosstrek XV
00 S2000
Correct... only in BSP. The only way to run the limited trunk in STU is if you owned an '07 STi, and converted everything on it to the same stuff that's in the limited.
--kC
KC is offline   Reply With Quote
Old 06-20-2006, 10:23 PM   #18
ScoobyTodd
Member#: 19186
2005 STi
Thanks KC. Perhaps BSP might be the next playground in a couple years when the weight of the STI trunk and wing would really matter.
Old 06-20-2006, 11:30 PM   #19
wm07
Member#: 26529
04 STi
I think if you add a brake light on the limited spoiler, it would be legal for STU.
wm07 is offline   Reply With Quote
Old 06-21-2006, 10:37 AM   #20
jcroy66
Member#: 42675
2003 WRX #177 STX
No, it wouldn't be. Because you can't replace a wing with a spoiler.
Old 06-21-2006, 01:23 PM   #21
ScoobyTodd
Member#: 19186
2005 STi
So the SCCA actually defines wing vs. spoiler?
Old 06-21-2006, 01:48 PM   #22
KC
Member#: 442
13 Crosstrek XV
00 S2000
Posted this in another thread...
A wing allows air to go over and under its surface.
A spoiler allows air to pass over (ie: trunk mounted) or under (bumper under-spoiler) the portions that are not affixed to the car. But not both at the same time.
SCCA doesn't need to define it.
Look at this pic...
It's a spoiler on a wing (the part that is up). Notice that air cannot go under the spoiler itself from the top surface of the wing:
Here's the proper usage of the term 'spoiler':
--kC
Old 06-22-2006, 08:00 AM   #23
RacerMike
Member#: 106193
1995 BMW M3
If the trunk part numbers are different (likely) you could not swap out the whole trunk lid.
Mike
RacerMike is offline   Reply With Quote
Old 06-22-2006, 08:53 AM   #24
ScoobyTodd
Member#: 19186
2005 STi
Thanks KC...that makes sense.
Old 06-22-2006, 10:23 AM   #25
austinpike
Member#: 11279
2o11 wrx dgm
2oo8 tribeca swp
Pretty sure they are different part numbers based on the number of pre-drilled holes they come with. Considering you would have to fill holes anyway, or make new ones depending which way you were going, that is splitting some pretty fine hairs.
austinpike is offline   Reply With Quote
WTT: wrb trunk with prodrive V8 wing for Stock wrb wrx trunk & wing Stover954rr Tri-State Area Private Classifieds 0 03-31-2006 01:44 PM
WTT: WRX Trunk & Wing for Trunk w/o Wing! Silver 2004 mikebike357 Mid Atlantic Impreza Club -- MAIC 5 04-25-2005 09:59 AM
WTT: '05 Aspen White STi Trunk & Wing for '05 WRX Trunk & Wing... STIcky WRX AWD Private 'For Sale' Classifieds 2 11-21-2004 10:58 AM
WTT: '05 Aspen White STi Trunk & Wing for '05 WRX Trunk & Wing... STIcky WRX AWD Private 'Wanted' Classifieds 2 11-21-2004 10:57 AM
WTT: '05 Aspen White STi Trunk & Wing for '05 WRX Trunk & Wing... STIcky WRX AWD Private 'Wanted' Classifieds 11 10-21-2004 11:36 AM
