Old 06-13-2006, 10:37 PM   #1
shipjumper
Member#: 6307
what I has no car...
am carless
Default junkyard motor build (used parts budget build!!!)
ok... heres my plan... 1996 impreza L with greddy emanage, MBC, EJ22T injectors to be installed
engine build
plan 1:
used EJ22 block
used EJ22T pistons
used EJ22T heads
used turbo manifold or el-cheapo ebay headers
used turbo
used IC
used exhaust
used JDM x-member + swaybar
I plan on doing a parallel fuel rail setup with both, have not figured out intake plumbing (under the bridge or over) because of the IAC and other bits and piece being in the way...
plan #2:
same deal but with an EJ25 (phase I) block with THICK HG
obviously stock pistons
rest the same
any comments or ideas?
shipjumper is offline   Reply With Quote
Old 06-13-2006, 11:03 PM   #2
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Use the 22 block and pistons but with better heads
Old 06-13-2006, 11:12 PM   #3
shipjumper
Member#: 6307
am carless
I wanna stay sohc cause of the oem ecm.... and the factory oil and water pitots on them
Old 06-14-2006, 10:22 AM   #4
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Please don't tell me you are even considering a Phase I block over the EJ22t for a turbo build.
Trust me the extra boost you will be able to sustain from using the 2.2 will be much more appreciated when compared to the 2.5.
MY99 2.5GT is offline   Reply With Quote
Old 06-14-2006, 10:31 AM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
You can use SOHC Ej25 heads on that build with the stock ECU.
OR, a '98 DOHC Ej25 ECU is practically a direct plug in replacement for your stock ECU. Do a search for info from Storm. He's done it. IIRC, 3-4 wires need repinning on your stock connectors, and viola, you have the DOHC and a 6500rpm redline to boot. And since the E-manage won't move your redline, that's a worthwhile change...
Old 06-14-2006, 12:00 PM   #6
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
I would never use used pistons/rings, especially if they came out of different bores. They are so cheap, you can't really justify the sheer laziness.
TypeC is offline   Reply With Quote
Old 06-14-2006, 01:18 PM   #7
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Just a small correction... the EJ22T block actually was a phase 1 block. They didn't put phase 2 into production until sometime in 1998 (for the 98-99 model years).
Old 06-14-2006, 01:25 PM   #8
NicFunkadelic
Member#: 35330
1999 RSTi + 4.44 = )
Silverthorn... for now
That's correct, 99 I believe.
Nick
NicFunkadelic is offline   Reply With Quote
Old 06-14-2006, 01:25 PM   #9
shipjumper
Member#: 6307
am carless
I am using the pistons. the rings will be new, and the walls will be rehoned.
good idea on the DOHC ECM, we have assloads of those lying around, so it should be an easy find.
ok, i will go with the EJ22E block, I will stick with the turbo heads (cheap, just won em on ebay) so I wont have to tap and pitot the 2.5 SOHC heads and those hit the up pipe anyways...
remember, BUDGET build...
Old 06-14-2006, 01:26 PM   #10
shipjumper
Member#: 6307
am carless
what about the whole EGR issue?
Old 06-14-2006, 02:06 PM   #11
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Ditch it. You're in VT.
jamesfacts is offline   Reply With Quote
Old 06-14-2006, 06:10 PM   #12
shipjumper
Member#: 6307
am carless
still gotta pass OBDII....
even though I work for a shop... would be nice to have it right...
oh and BTW we just got in a TOTALLED spec B....looks like the drivers door hugged a tree...
Old 06-14-2006, 07:57 PM   #13
Scoobie Steve
Member#: 2289
1998 [email protected]
Subaru L Ver 6 STi Type R
EJ22t injectors are smallish and the rail is funky. I would do USDM STi side feeds in a dohc rail.
Scoobie Steve is offline   Reply With Quote
Old 06-14-2006, 08:11 PM   #14
shipjumper
Member#: 6307
am carless
I heard somewheres that the EJ22E rail will take larger nissan injectors....
anyone hear of this?
Old 06-14-2006, 09:27 PM   #15
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
1992-94 NA legacy rails will accept SRD20 (or whatever they are called) Nisson injectors. They are commonly available in 370, 440 550 and larger.
I am running 370 cc injectors right now and making about 160 whp with some room to spare, I think.
Old 06-15-2006, 12:25 AM   #16
shipjumper
Member#: 6307
am carless
just nissan injectors? im pretty sure I see them all over EBAY....
they clip right into the subaru harness?
Old 06-15-2006, 01:14 AM   #17
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Its the SRDET20 injectors. The clip is close but not quite, so you have to grind some plastic down. But they work. I will find some pictures eventually.....
Old 06-15-2006, 06:35 AM   #18
shipjumper
Member#: 6307
am carless
Ah I know those injectors!
Parting out build Plus, + Accessport V1.5 $400 used twice Subaru WRX04 Engine/Power/Exhaust 9 06-24-2007 06:17 PM
Price of junkyard motors are out of control! GenX'r Normally Aspirated Powertrain 8 08-14-2006 01:15 AM
A budget build.... 2000wrx General Community 11 07-28-2006 02:28 PM
Stuff for sale, come get some stuff...budget build? motorswapsleeper Private 'For Sale' Classifieds 12 08-10-2005 08:34 AM
SW Ohio - junkyards/used parts --HELP soso3 Mid West Subaru Owners Club Forum -- MWSOC 10 08-02-2004 07:36 PM
