Old 06-14-2006, 02:26 AM   #1
scoooby03
Member#: 110654
Default Anybody have problems with Perrin Pulley?
I am thinking of getting a Perrin lightweight pulley. I would like to know the benefits and drawbacks. How many miles have you had it? Any info is greatly apreciated. thanks Dewey
scoooby03 is offline   Reply With Quote
Old 06-14-2006, 05:48 AM   #2
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
I'll go ahead and tell you to put on your flame suit. Search feature is yor friend. And also unabomers manifesto that is in the FAQ's at the top of this forum. There are so many threads about this you'll find all the info you need.
I personally do not have one. I know it will throw a cell if you try and run one with a lightend flywheel.
breathinez is offline   Reply With Quote
Old 06-14-2006, 10:04 AM   #3
PolarisSnT
Member#: 85905
2004 WRX
Now its testimony like that which give this mod a bad name. I have a Perrin Pulley and Exedy 13.9lb flywheel and have no CELs. The car revs great and is really easy to drive.
You are not going to gain a ton of performance or might not even gain any HP from it but the ease in which the engine revs and the throttle response it gives are well worth it.
PolarisSnT is offline   Reply With Quote
Old 06-14-2006, 10:50 AM   #4
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
Maybe I shouldn't have said "I know it will throw a cell" since I have no experience with either. But from what I've read on numerous threads is that it will. And I'm talking about running both. Flywheels are not all the same(some much more lighter than others) so maybe one is better than the other. But the pulley itself alot of people seem to like. Money could be spent somewhere else, but thats preference. And my 2 cents. Sorry kinda got off subject and thats all I have to say about that.
Old 06-14-2006, 11:45 AM   #5
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Honestly, I had the older Perrin version of this and at high rpm I'd get a CEL for the crank angle sensor. I swapped it out for a Worx Tuning version (that supposedly is designed to prevent this) and I haven't seen the CEL again. Perrin has changed their design since then and probably isn't an issue. Just wanted to throw that out there.
djerickd is offline   Reply With Quote
Old 06-14-2006, 12:39 PM   #6
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
jblaine is offline   Reply With Quote
Old 06-14-2006, 01:31 PM   #7
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
anybody else have problems with their vizio flat screens? wrxej205 Off-Topic 39 04-06-2010 08:40 AM
anybody have problems with the txs cat back adaptor awdguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 10-25-2004 03:45 PM
Anybody else having problems with scooby mods? STiTuner Off-Topic 17 04-01-2004 08:06 AM
Anybody have a stock underdrive pulley 2000vfr800 Mid West Subaru Owners Club Forum -- MWSOC 9 06-26-2003 11:18 AM
Anybody have problems with oil leaking in older subies? redobs Technical Forum Archive 14 09-15-2000 09:25 AM
