Old 10-30-2000, 02:20 PM   #1
etam
Member#: 439
www
Question sway bar/bushing question
Hi all,
Now I know that I can't use the Impreza sway bar. Can I use the 91 Turbo 19mm rear sway bar on my 97 GT? (actually I think someone is using it already, just want to confirm that) The part number is 20450AA052. Can I use the same bushing (21047GA671) for Impreza 18/20mm on the Legacy 19mm bar?
Please tell me that they do fit. I want to upgrade the sway bar cheap (19mm sway bar from dealer C$109.75 and bushing for around C$10)
etam
97 GT
[This message has been edited by etam (edited October 30, 2000).]
etam is offline   Reply With Quote
Old 10-30-2000, 02:30 PM   #2
slide
Member#: 1130
2013 STI Hatch
Post
How come you don't use the whiteline legacy bar? its adjustable???
Its not $110 though...
slide is offline   Reply With Quote
Old 10-30-2000, 02:57 PM   #3
etam
Member#: 439
www
Post
slide, PDM racing give me a quote of C$200 (vs C$110 for 19mm) for the whiteline adjustable. If 19mm bar works in my car, I would be really happy. I know adjustable is good but I would probably won't change the setting (20mm) for street use only (I don't do autoX or rally).
etam
Old 10-30-2000, 03:53 PM   #4
pleiades
Member#: 2491
06 Miata
81 Fiat Spider
Arrow
The 19mm bar from the old turbo legacy's will work on your GT. I had the same bar on my 98GT until recently when I sold it to go stiffer for autocross. However it was an excellent bar for street driving. As far as the bushings go I would try to get 19mm poly bushings. I got mine from Dale Teague of Teague's Auto. I don't know if he stocks that particular bushing but he got it pretty quickly for me. Check him out: www.boxer4racing.com
pleiades is offline   Reply With Quote
Old 10-30-2000, 07:07 PM   #5
slide
Member#: 1130
2013 STI Hatch
Post
etam- isr performance has them for about 180. And by the way, you'll have more fun in the snow with a 20,mm but more stability with a lessor bar.
Old 10-31-2000, 07:13 AM   #6
etam
Member#: 439
www
Post
slide, I am Canadian and all my price quotes are in Canadian too. PDM racing is selling for US$135 or C$200.
BTW, I got the bushing number from Sugar 21047GA821.
etam
Old 11-08-2000, 10:47 AM   #7
new2roo
Member#: 2841
Post
Can someone offer advice/experiences with a larger bar on the Legacy GT wagon? I measured the stock bar at something like 16mm. How much difference would a larger bar make? How much larger makes sense? Where to find?
Thanks,
Dave
new2roo is offline   Reply With Quote
Old 11-08-2000, 03:06 PM   #8
Radio Flyer
Member#: 374
'98 2.5 GT Wagon
Rio Red
Exclamation
Actually, the adjustable bar changes the length of the mounting arm. It makes the bar feel as stiff as an 18, 20, or 22mm bar.
HTH,
  - Eric
&nbsp;&nbsp;&nbsp;&nbsp;'98 2.5 GT Wagon - <a href="http://208.9.184.110/MembersList/ViewMemberPics.cfm?MemberID=143" target="_blank">Pics</a> - <a href="http://www.jeneric.ws/eric/radioflyer.htm" target="_blank">Page</a> -
Radio Flyer is offline   Reply With Quote
Old 11-09-2000, 12:21 AM   #9
gtguy
Member#: 2184
2005 Legacy GT wagon
Platinum Silver Metallic
Post
etam and New2Roo, I have answers for the both of you, and they are good. I bought the 19mm turbo Legacy bar from Pleiades, and am quite thrilled with it. It makes the car dead nuts neutral, and in conjunction with the Eibach/KYB AGX combo, makes for a car that a racing buddy friend of mine deemed "fantastic."
And if I haven't yet said it yet, Pleiades, thanks a million. I've also (I think) figured out a way to eke out that inch of ride height that I need to make it all perfect.
Kevin
gtguy is offline   Reply With Quote
Old 11-09-2000, 12:23 AM   #10
gtguy
Member#: 2184
Post
Oh, New2Roo, I have a '98 GT wagon, and the difference the bar makes is stunning. Even though I installed it at the same time as the suspension bits, you can still tell when a car is absolutely neutral. The 19mm bar is neutral, and ready to turn.
Kevin
Old 11-09-2000, 12:37 AM   #11
etam
Member#: 439
www
Post
new2roo, I ordered the sway bar and bushing from dealer last week and will receive them soon. I can let you know how much of the difference with 19mm (upgrade from 16mm) sway bar alone.
etam
Old 11-09-2000, 12:51 AM   #12
new2roo
Member#: 2841
Question
My ignorance is showing, but I'm beginning to get the idea that the 18, 19, 20, etc., mm doesn't refer to the diameter of the bar, but rather to an offset or position change from the standard location?
Clearly one can't buy an adjustable bar and change its diameter, right?
Dave
front sway bar bushings question cadillacklos Brakes, Steering & Suspension 5 04-20-2007 03:37 PM
WRX Camber Bolts, Steering Rack bushings + Energy sway bar bush. CA sekretskwirl Suspension/Brakes/Handling 1 10-29-2006 11:44 PM
20mm poly sway bar bushings & Poly end link bushings pleiades Private 'For Sale' Classifieds 0 11-08-2004 10:25 AM
OEM sway bar bushings question Alfa Brakes, Steering & Suspension 1 05-17-2003 11:24 PM
Quick question about sway-bar bushings speedracer47 Brakes, Steering & Suspension 2 08-23-2001 01:40 AM
