Old 10-15-2001, 02:29 PM   #1
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Default Can I mount my MBC in the cabin?
Can I put my MBC in the cabin so I can adjust boost from inside? I have a Turbo XS high performance Boost Controller. Can I use it inside or is the tubing too long to keep it accurate?
STiShawn is offline   Reply With Quote
Old 10-15-2001, 05:56 PM   #2
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
yeppers, most people do mount them in the cabin, that's the beauty of an MBC. You'll just need some vacum line.
Chad
93 1.8T
subachad is offline   Reply With Quote
Old 10-15-2001, 06:00 PM   #3
kaos200
Member#: 2692
if you do go ahead with it, get some thick walled silicone line to keep it as accurate as possible.
kaos200 is offline   Reply With Quote
Old 10-16-2001, 01:22 AM   #4
Avenger
Member#: 1234
I think last issue of SCC talked about why the MBC was installed under the hood instead of inside.
Avenger is offline   Reply With Quote
Old 10-16-2001, 09:21 AM   #5
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
cool, now I can turn my boost WAY down if i have to valet the car, or let my Mom drive it...she is scared of it already.
Old 10-16-2001, 10:27 AM   #6
Thug
Choke Artist
Member#: 603
I would recommend installing it in the engine bay. Running all that extra vacuum hose can cause the pressure to vary quite a bit from hot to cold weather.
Thug is offline   Reply With Quote
Old 10-16-2001, 10:42 AM   #7
GGrahnVI
Member#: 7190
You can put the controller in the trunk if you want. Just be warned though, the longer the lines on the MBC the less control you have. You will have spikes. You will have a hard time keep it consistent. Word to the wise, keep the lines on your boost controller of any sort as short as possible.
GGrahnVI is offline   Reply With Quote
Old 10-16-2001, 12:48 PM   #8
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
will do, I will mount it to the firewall right by the turbo's wastegate....thank god its small..thanks guys.
Can i wash my floormats in the washing machine? stage2?? Car Care & Detailing 26 01-08-2010 12:03 PM
How can i get my car in the sema show STEALTH-WRX Southern California Impreza Club Forum -- SCIC 20 09-27-2003 03:36 AM
Gas Smell in the Cabin Scoobie Newbie Canada Region Forum 4 01-20-2002 03:52 AM
I want to control my suspension from the cabin...What do I need? wrx182 Brakes, Steering & Suspension 10 01-12-2002 05:08 PM
