Old 10-23-2001, 04:33 AM   #1
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Arrow Pleasae help. What's wrong with my math?
This is Subaru related because I'm trying ot figure out how Subaru came up with their calculations for the EJ25 motor. The reason I'm doing this is to decide how much overbore I should go (not going into the details here )and for some reason, my math just isn;t working out with theirs.
According to Subaru, the bore on the EJ25 is 99.5mm, The Stroke is 79.0mm, and the displacment is 2,457cc's which is 2.457 Litres.
So, this is how my math comes out. please let me know what I am doing wrong:
99.500mm=3.917"
79.000mm=3.110"
To get the engines displacement, I do the equation Bore x stroke x Pi x # of cylinders. With this I get:
3.917" x 3.110" x 3.141 x 4 = 153.053 cubic inches
1 cubic inch = 16.387cc's
Therefor:
153.053 ci's x 16.387 cc's = 2508.079 cc's
And: 2508.079 Litres = 2.508 litres!
Where is my math wrong? Thank you.
Eric
Eric SS is offline   Reply With Quote
Old 10-23-2001, 06:18 AM   #2
Mark Avery
Member#: 10313
2002 WRX wagon
Converting from metric to inches then back to metric is not necessary.
The bore measurement is the diameter the cylinder, but to get the volume we need the area. So, take half of the bore measurement, that's the radius, square it, then multiply by Pi. Also, since the answer you want is in cubic centimeters, let's convert the bore and stroke measurements to centimeters at the start.
9.95 / 2 = 4.975 x 4.975 = 24.750625 x 3.14159 = 77.756315994
That's the area in square centimeters of one cylinder bore. Now for the displacement of a cylinder, multiply that by the stroke. Then for the total displacement, multiply by the number of cylinders.
77.756315994 x 7.9 = 614.27489635 X 4 = 2457.0995854
or 2.457 litres.
-Mark
Mark Avery is offline   Reply With Quote
Old 10-24-2001, 01:56 AM   #3
Daveish
Member#: 8935
2001 Impreza 2.5RS
Jes for reference, look @ your units... you have:
inches/cylinders x inches x (no unit) x cylinders...
that gives you inches squared -- which isn't the cubic inches you're using in your conversion back to cc's.
Daveish is offline   Reply With Quote
Old 10-24-2001, 02:09 AM   #4
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
Using Pi gived me my cubic inches
The actual way to measure Displacment is:
CID = Number of cylinders x 0.7854" x bore" x bore" x stroke
THAT gives you your cubic inches, However, the firstway I did it is a simplified way of doing it and nets the same result
Old 10-24-2001, 08:17 AM   #5
red
Member#: 2293
2002 GOLF TDI
An easy way of douing it is Bore x Bore x .7854 x stroke x # of cylinders. All units should be in cm.
(i.e. 9.95 x 9.95 x .7854 x 7.9 x 4 = 2457.1074066cc or 2.4571074066L)
I do this all the time. The same technique is also used for english.
( i.e. 3.917 x 3.917 x .7854 x 3.11 x 4 = 149.905794456264 cu.in.)
red is offline   Reply With Quote
Old 10-24-2001, 01:54 PM   #6
mhj
Member#: 3057
Yup, too many roundoff errors.
Staying in metric, using:
Pi=3.14159
Bore=9.95 cm
Stroke= 7.90 cm
and the formulas:
Area = Pi*(Bore/2)^2
Volume= Area*Stroke
Displacement=Volume*4
I get Displacement=2457.0995854025 which rounds to 2457.1cc
mhj is offline   Reply With Quote
Old 10-24-2001, 02:17 PM   #7
ChrisW
Member#: 4181
2003 Lancer Evo 8
It's Blue, ok?
[rant] even more proof that metric is better....
ChrisW is offline   Reply With Quote
Old 10-24-2001, 02:20 PM   #8
Imprezer
Dynamic Uno
Member#: 1
2011 Impreza WRX STi
Of course metric is better. There is a reason only 2 countries in the World refuse to adopt it as a primary system.
Imprezer is offline   Reply With Quote
Old 10-24-2001, 02:22 PM   #9
scoobagenie
Member#: 5283
02 wrx wagon
black
thanks, i have a headache now.
scoobagenie is offline   Reply With Quote
Old 10-24-2001, 05:31 PM   #10
H1
Member#: 3083
1997 Miata M-Edition
Green
Wink
Bunch of squares
H1 is offline   Reply With Quote
Old 10-24-2001, 06:00 PM   #11
driggity
Member#: 7453
2014 Scion FR-S
Hot Lava
Uhm the firstway you did it is not a simplified version of this. The first thing you did was
The only reason this came out somewhat close is because .7854 * bore happens to be somewhat close to pi: 3.08 vs 3.141 (in the case of the 2.5 L engine). I'll agree that metric is better but you can convert back and forth with no problems if you use good conversions and don't go rounding off willy-nilly. Oh, and since pi doesn't have units it can't convert from in^2 to in^3
Drakos
driggity is offline   Reply With Quote
What's Wrong With My Tranny???? Help Pinz0311 Transmission (AT/MT) & Driveline 12 03-23-2008 05:25 PM
Help - What's wrong with my rotors? alfcanada Brakes, Steering & Suspension 3 01-01-2007 04:01 AM
What's wrong with my computer?!?! Help! Guru Imakuni Off-Topic 13 08-29-2004 10:33 PM
Help! What's wrong with my car gnildronde Normally Aspirated Powertrain 6 08-02-2002 07:47 PM
Help! What's wrong with my subframe? chandy Brakes, Steering & Suspension 5 02-09-2002 01:17 AM
