Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 06-14-2006, 11:47 AM   #1
jmott
Member#: 6713
2007 Prius
brown
Default When is subaru going to add direct injection to its motors?
VW/Audi were able to bump the compression ratio on their turbo-4 motors from 9.5 to 10.3 thanks to direct injection. And power went up from 180 to over 200. Gas mileage improves a lot as well.
jmott is offline   Reply With Quote
Old 06-14-2006, 11:49 AM   #2
prototypeWRX
Member#: 78739
2015 WRX
Aren't those low boost setups though? I always thought you wanted lower compression for high boost setups. So maybe that's really only better for stock setups.
prototypeWRX is offline   Reply With Quote
Old 06-14-2006, 11:52 AM   #3
jmott
Member#: 6713
2007 Prius
brown
Whatever boost you are running, direct injection will let you run a higher compression ratio at that boost, which will add power, reduce lag, and improve gas mileage.
Or, you could keep the compression ratio the same and add boost. woot
and, the stock 2.0T boost on the vws is 15psi, aftermarket chips bump it up to 18psi
Old 06-14-2006, 11:53 AM   #4
forced4
Member#: 13304
2002 WRX WRB
De Re Metallica
Just buy the A3 and get it over with Jack =)
forced4 is offline   Reply With Quote
Old 06-14-2006, 11:55 AM   #5
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
Didn't they go from 1.8 to 2.0T? Also didn't they change the turbo size? And iirc, the head changed.
TypeC is offline   Reply With Quote
Old 06-14-2006, 11:56 AM   #6
KevinHeist
Member#: 50667
2000 Impreza Coupe
Enginuity Tuned
good call.
KevinHeist is offline   Reply With Quote
Old 06-14-2006, 12:05 PM   #7
jmott
Member#: 6713
2007 Prius
brown
The turbo is either smaller, or the same size. Still trying to get clarification on that. But yeah the engine got a little bigger.
Also, they are dynoing at 197 to the wheels, so seems more like 220hp. I don't know fi the 1.8t was similar under-rated or not.
Old 06-14-2006, 12:05 PM   #8
jmott
Member#: 6713
2007 Prius
brown
meh, dunno yet.
Old 06-14-2006, 12:43 PM   #9
OneArmedScissor
Member#: 18958
08 STi
Black as my heart
get the GTi with DSG
OneArmedScissor is offline   Reply With Quote
Old 06-14-2006, 01:00 PM   #10
samagon
Member#: 26859
of TXIC
I also like (oYo)!!!!
DI is the way to go, if subaru is going to do it anytime soon, it will debut with the reworked impreza, and the engine (which is pretty much the same across the brand) will filter down (or up in this case).
just my guess.
Old 06-14-2006, 01:53 PM   #11
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
meh, dunno yet.
Never stopped you before
afpdl is offline   Reply With Quote
Old 06-14-2006, 02:18 PM   #12
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
BMW also just revealed a sequential (read:2) turbo direct injection motor going in their 335 next year.
They have also introduced a 2 or 3 working hydrogen powered cars that should go into production soon.
scoobdude is offline   Reply With Quote
How to add LED light to factory security system OR when car is off? virjose Interior & Exterior Modification 11 05-20-2008 10:33 AM
2008 Porsche 911 to get Direct Injection & Optional DSG Transmission NYCshopper Non-Subaru News & Rumors 26 12-28-2006 10:42 AM
Solstice GXP to have direct injection scott_gunn Non-Subaru News & Rumors 28 03-18-2006 12:03 AM
So when is Subaru going to wake up and make a 6 speed DSG auto tranny? 3DF News & Rumors 66 08-31-2005 04:28 PM
When is Subaru going to authorize crash bolts? gotsol Motorsports 15 08-26-2004 04:26 PM
