Old 06-14-2006, 12:05 PM   #1
twrx2002
Member#: 106880
2002 WrX
BlAcK PeArL
Angry ap problem?
alright here it is so i just bought a new ap because i didnt like how utec was set up. i married the ap to my ecu and flashed the stg2 93 oct. map to it, i had a manual boost controller inside i didnt realize to later on in the night so i put the factory restrictor T back in place and hooked up the solonoid again. i did it because cobb uses the factory one to control boost so the mbc was useless. so i took it for a ride and the boost level was at 9 psi at peak. so i thought maybe i oput the restrictor in wrong so i flipped it then the boost just spiked. =/ i ended up just leaving the mbc in any idea why this happened?
twrx2002 is offline   Reply With Quote
Old 06-14-2006, 12:09 PM   #2
blindstuff
Member#: 100767
2005 Impreza WRX CGM
Enginuity Tuned Stg 2
Probably because you have to be careful when you install things and do it the right way...
blindstuff is offline   Reply With Quote
Old 06-14-2006, 12:14 PM   #3
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
It would probably be a good idea to reset the ECU when you change stuff like that.
Also, are you sure the boost control was in the proper configuration?
parker/slc/gc8fan is offline   Reply With Quote
Old 06-14-2006, 12:23 PM   #4
twrx2002
Member#: 106880
2002 WrX
BlAcK PeArL
yes it was all set up right, my frend said it might be that the ecu doesnt know what to boost because i had the controller in when it was flashed
Old 06-14-2006, 12:48 PM   #5
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
This isnt an AP problem BTW, It's mechanical setup problem.
You need to get your car closer to what Cobb made the maps for.
Old 06-14-2006, 01:06 PM   #6
twrx2002
Member#: 106880
2002 WrX
BlAcK PeArL
the only diffrence is the mbc or stock everything else is what the set up is for...
Tbe, stock bypass valve, stock airbox, uppipe. isnt that the setup?
Old 06-14-2006, 02:00 PM   #7
Quack
Member#: 57264
2004 18g Wagon - WRB
PDX Tuned - 329whp/315wtq
try resetting the ECU (dis-connect the battery)
check to see if there is any damage to the hoses.
reseat the electrical connection to the FBC
Quack is offline   Reply With Quote
Old 06-14-2006, 02:11 PM   #8
twrx2002
Member#: 106880
2002 WrX
BlAcK PeArL
alright ill give that a tri tonight and ill get back to it. thankx bro
Old 06-14-2006, 03:14 PM   #9
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
Sending a pm.
Old 06-16-2006, 08:39 PM   #10
twrx2002
Member#: 106880
2002 WrX
BlAcK PeArL
if i reset the ecu by just disconnecting the battery would i have to plug ap and reload the stg2 map?
Old 06-16-2006, 10:00 PM   #11
pclement
Member#: 92332
2002 Impreza WRX
Plug in your AP and select the "Show Current Map" option. ;-)
pclement is offline   Reply With Quote
Old 06-17-2006, 11:53 AM   #12
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
No, base maps flash to the ECU, realtime maps are lost when disconnecting the battery.
Actually, the Show Current Map option, you could plug into your computer and hit that option and it'll show what you last flashed. It doesn't read what is actually flashed into the ecu, it keeps an internal memory of the last base map flash you did. If that makes sense...
Old 06-17-2006, 01:05 PM   #13
twrx2002
Member#: 106880
2002 WrX
BlAcK PeArL
alright so im still flashed to stg2 i think i have an idea what it may be.
Old 06-17-2006, 04:39 PM   #14
pclement
Member#: 92332
2002 Impreza WRX
Yeah my bad. Says so right in the manual. Thanks for the clarification.
Old 06-17-2006, 09:29 PM   #15
loudaccord
Member#: 99489
The Black Pearl
Yarr!!
did you get the problem fixed? I have the same dumb problem on my 06 sti. My stage 1 was fine, and just put in my downpipe today(still on stage 1) and was seeing 16psi. I got home and flashed to stg2 and can only get 10 psi now.
loudaccord is offline   Reply With Quote
Old 06-18-2006, 05:33 PM   #16
loudaccord
Member#: 99489
The Black Pearl
Yarr!!
I reverted the AP back to stock and reset the ecu. Now I am hitting 14 psi now, so I know mine has something to do with the AP. Before reverting it back to stock, I tried the HWG stg 2 map and that didn't do anything, I was still at 10psi.
Old 06-19-2006, 12:02 PM   #17
twrx2002
Member#: 106880
2002 WrX
BlAcK PeArL
i think my prob is a restrictor ball in line with the turbo housing line but didt get the hose yet so ill let you know
Old 07-25-2006, 12:12 AM   #18
brokenarrow
Member#: 119767
2006 wrx
DID you ever fix your boosting problem..cuz i am haveing the same problem I am only hitting 9 pis ..
brokenarrow is offline   Reply With Quote
Old 07-25-2006, 12:23 PM   #19
twrx2002
Member#: 106880
2002 WrX
BlAcK PeArL
yea man mine was that there must be a lil restrictor copper ball inline with the turbo housing
Old 07-25-2006, 12:42 PM   #20
NoCalSubie
Member#: 94301
Is that restrictor T clean? Make sure there nothing in there when stored away.
NoCalSubie is offline   Reply With Quote
Another AP problem 04AspenWhiteWRX Engine Management & Tuning 16 06-10-2005 05:09 PM
Cobb AP problem scooby_wooby Engine Management & Tuning 10 03-01-2005 11:02 AM
AP Problem Flexx999 Engine Management & Tuning 6 02-08-2005 06:02 PM
lets hear about your AP problems,,, mistaare Engine Management & Tuning 61 02-03-2005 10:41 PM
AP problem for FXT speedypete Engine Management & Tuning 3 08-19-2004 02:21 PM
