Welcome to the North American Subaru Impreza Owners Club Monday October 5, 2015
Old 06-14-2006, 05:14 PM   #1
Member#: 96448
02 WRX VF34
Default Stage 4 hitting just 12psi in 4th gear...
My friend recently upgraded his stage 2 WRX to stage 4.
AP VF34 map
VF34 ported
Perrin turbo inlet
Borla header
catless TBE
Stock intake
Stock T-hose and "pill" from TD04
Now, problem is that he's only able to hit 12psi at max... that's what's read on AP live meter and defi boost gauge. Can someone point to where he should look as far as fixing the boost problem? He doesn't hear any whining or high pitch sounds which would point to potential leak problem...
Your help is appreciated.
gopsu is offline   Reply With Quote
Old 06-14-2006, 05:18 PM   #2
Member#: 46241
I'd point him to a protuner to have a custom map made for those extra parts he's running. Unless he wants to take them off and get back to Cobb's spec.
He'll make more power with a tune, way more.
parker/slc/gc8fan is offline   Reply With Quote
Old 06-15-2006, 03:40 AM   #3
Member#: 84188
05 legacy
caravan full of kids now
over ported turbo, pre turbo exhaust leak, or weak wastegate. try a helper spring and check for leaks
dvang is offline   Reply With Quote
Old 06-16-2006, 01:47 AM   #4
Member#: 103320
2005 wingless
aspen white
data log. see if your ECU is hanging the WG open at 100%. I'd bet on a boost leak somewhere. See the EM forum sticky's for the DIY leak finder.
benw is offline   Reply With Quote
WTB: gear set or just 3rd and 4th gear of 02 wrx AFBeefcake Private 'Wanted' Classifieds 12 10-16-2006 10:20 PM
Access Port Stage 2 only hitting 13.3psi in 3rd gear Airboy Western Canada 2 07-17-2006 11:30 PM
Those of u with td06-20g or 18g on sti-in 4th gear at what rpm do u hit full boost? odin1 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 38 11-22-2005 12:43 AM
Stock (?) MY04 WRX pulling 12psi+ in 1st gear.. that's not good, right? woody77 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 10-22-2005 08:42 AM
TurboXS Stage 2 loss of power in 4th gear camdoc Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 09-04-2002 10:48 AM
