Welcome to the North American Subaru Impreza Owners Club Wednesday October 1, 2014
Old 06-14-2006, 09:53 PM   #1
chibich
Member#: 79134
2004 STI
Default How far can you travel untuned?
This might be a stupid question, but I am just going to ask anyways. I live in virginia and the nearest ecutek dealer is about 4-5 hours away. I am putting a 20g turbo on my sti in the next month or so, and was wondering if it is safe to drive that far untuned? I plan on getting my stock injectors modified and as long as I have them flow tested, and they are fine, I don't really see the problem. I am looking at either going with ecutek or accessport(protuned). I know accessport has a couple of base maps for 18g turbos, but I am not sure about 20g. I thought maybe if they did I could throw on that map and then go get a protune for the accessport(I do realize this is a ecutek thread). plus the portune is only 1.5-2 hours away.
chibich is offline   Reply With Quote
Old 06-15-2006, 07:20 AM   #2
cellobro
RIP 3/18/1965 to 1/10/2008
Member#: 91500
hmmm sr-30+640cc=?
I has teh Endless BBK.
Lightbulb
following the lead (and the flames ) of those before me, I found this after searching (2.5l turbo tech) with '20g engine management':
http://forums.nasioc.com/forums/sear...archid=4939301
No, it isn't a 'spot-on' answer, but as Unabomber tells us, there's opinions (eleventy kabillion if I recall ) but few informatives. Coupla shops here seem like they could answer yer question directly.
Also, trusted tuner in Illinois:
www.pandlmotorsports.com
Jorge or one of his henchmen should be able to give you an idea.
...OR, call the people yer about to entrust yer car to?
cellobro is offline   Reply With Quote
Old 06-15-2006, 06:58 PM   #3
chibich
Member#: 79134
2004 STI
thanks, but the link to the forum doesn't work
Old 06-21-2006, 04:54 PM   #4
hondaeater69
Member#: 60324
driving on the stock tune with moded injectors is not a good idea. You'll be spraying tons more fuel and you could wash the cyclinder walls. If you can, drive it to the tuning shop and install the injectors there. you'll be fine with the turbo running WG boost, but stay out of boost as much as humanly possible.
Either that or get an AP with a base map scaled to those injectors and run WG boost to the tuner.
Old 06-25-2006, 09:40 PM   #5
omaha03wrx
Member#: 73483
02 Silver Z06
ZzyzxMotorsports.com
If you go the EcuTek route then you can overnight your ECU to the tuner and he can flash a map on to your ECU to get you to where you need to be. I had to do the exact same thing when I recently got tuned except my drive was 7 hours.
If you go with an AP then they should be able to get you a map to download to your AP kind of like PDX Tuning does.
What ever you do donít drive with those larger injectors you have a very good chance of fouling out your plugs before you get there along with the other problems mentioned.
Good luck!
omaha03wrx is offline   Reply With Quote
How far did you travel to get to B4D? DrDRum Off-Topic 15 05-06-2008 07:36 AM
How far did you travel to get your car? Teh Legacy Off-Topic 52 08-14-2005 04:00 PM
How far can you go with NA EJ25? Cusco Normally Aspirated Powertrain 14 02-18-2002 03:02 PM
How far can you take Impreza on N/A basis? IBO Normally Aspirated Powertrain 26 06-30-2001 11:40 AM
