Old 10-15-2001, 04:18 PM   #1
phatroksek
Member#: 7397
2014 BRZ
Default does anyone swap engines?
are there any engines to swap into a 99-00 RS?
if so, does it fit in perfectly, and how much?
phatroksek is offline   Reply With Quote
Old 10-15-2001, 04:34 PM   #2
PsychO
Member#: 5947
MY02 Impreza STi V7
EJ20t................2.0 litres TURBO (UK, Aus and Jap WRXs)
It's a bolt-on procedure. All you need is a WRX ECU or a brand-new programmable ECU. All the rest is simple bolt-on, it's the same damn car!!!
For my part, I'm going for the EJ20t next summer, depending of the $$$$$$ status, I'll go with the reg EJ20t or the STi EJ20t......but this.......is a story to follow...
PsychO is offline   Reply With Quote
Old 10-15-2001, 04:46 PM   #3
JaiMak
Top Scoob 004
Member#: 697
1999 Top Scoob #4
Satin White Pearl
You have to source an EJ20 crossmember, and the wiring is kinda tricky, but there are swaps running around all over the place, there are around 4 here in toronto alone.. until I make it 5, mwuahaahahahahahaaha....
JaiMak is offline   Reply With Quote
Old 10-15-2001, 04:49 PM   #4
phatroksek
Member#: 7397
2014 BRZ
haha nice =P
so where can one find an EJ20t? and how much can it run you?
also, jsut wondering is there a need for an engine swap? or can you jsut go after market turbo? and advantages/disadvantages?
thanks
Old 10-16-2001, 04:01 AM   #5
DarkImpreza
Member#: 3607
98 Impreza RS
black
is it cheaper to get an used JDM motor to swap or
get the 02WRX motor in canada or america?
DarkImpreza is offline   Reply With Quote
Old 10-16-2001, 04:21 AM   #6
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
At this point, the older non-North American motors (Japan and Australia, mostly) are cheaper and more easily sourced than motors from North American WRXs. I'm sure this will change with a couple years of people totalling their cars. I haven't heard anything to indicate a domestic EJ20T is any easier to swap in than a JDM or Australian one.
Ben
bsquare is offline   Reply With Quote
Old 10-16-2001, 06:21 AM   #7
DarkImpreza
Member#: 3607
98 Impreza RS
black
so if swap a JDM motor..
I heard it takes long long process just to bolt it on...
lots of hasttle...is it true? or is it just as easy as
how honda swap those type R motor?
Old 10-16-2001, 09:29 AM   #8
peepshow
Member#: 1777
2005 LGT
#92 FZippy
The worst part is splicing together the wiring harness. Actually bolting the motor in is as easy as replacing it with another EJ25 motor. As someone mentioned, you WILL need the front cross member, if you are swapping the tranny, too, you should probably try to get the rear diff, too. That way you won't have to worry about swapping out the gearing in the rear diff to get it to match. Then, if you get the rear diff, you need the rear axles from the JDM car, too. Best to get the entire rear axle assembly.
- Trent
peepshow is offline   Reply With Quote
Old 10-16-2001, 03:15 PM   #9
bsquare
Member#: 1911
2000 Impreza 2.5RS
It is a lot more hassle than swapping a B18 into a B16 car. In particular, you will not be able to use the stock ECU or the JDM ECU.
Ben
Old 10-16-2001, 11:53 PM   #10
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
fuel, electronic ignition, sensors, crossmember, swaybar, fuel delivery, comp.
it's a month ol project if you ask me. Got a liberty RS motor sitting in my garage, and let me tell you, it's gonna take forever.
WRXwannbe is offline   Reply With Quote
Old 10-17-2001, 08:32 PM   #11
Blindeye_03
Member#: 4418
2016 Focus ST
Well what I plan on doing in 3-4 years is drop a ej20turbo into my engine bay. What would I need to go with the ovbious engine and exhaust assembly (headers, up pipe, turbo, downpipe, tmic) etc...? I could use the stock my02 ecu right? Would the crossmember off the my02 fit the gc8? And finally could I keep my stock tranny and final drive/rear differential, and center differential? Thanks.
-justin
Blindeye_03 is offline   Reply With Quote
Old 10-18-2001, 11:52 AM   #12
PERRIN
NASIOC Manufacturer
Member#: 6776
As long as you have the parts ready, it can go very smooth. A day project for sure.
I would recomend buying a programable ECU and forget the stock ecu and harness. makes life easier.
Make sure you get the crossmember or have one cut and welded to strengthen it back up.
You can use the stock fuel pump. Its good for 75 psi and plenty of Gpm, unless you run 400hp
I would buy different injectors.
Clutch is a must, get a four puck racing clutch.
Pay someone to put it in and you off.
Haltech ECU $1300
Engine $1000-$4000 $1K for the old WRX engines
Crossmember $200
Injectors $350
Labor $0 if you do it.
Clutch $200 or less
PERRIN is offline   Reply With Quote
Old 11-08-2001, 10:42 AM   #13
phatroksek
Member#: 7397
2014 BRZ
perrin, so is that all you need?
just those few parts?
wut about the rear diff and axles and stuff?
also, where can you find a wrx engine? not a new north american one because it'll be harder to find and such
thanks
Old 11-08-2001, 01:19 PM   #14
PERRIN
NASIOC Manufacturer
Member#: 6776
Old 11-08-2001, 03:25 PM   #15
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
If your looking for WRX engines, www.teaguesauto.com has a used engine they are selling, but not sure of the install. You will need to buy an aftermarket ECU, and a Haltech would be your best bet so you can tune it properly.
Graham
Graham is offline   Reply With Quote
Old 11-08-2001, 05:32 PM   #16
SYMSWRX
Member#: 1386
98 imprezaL
red
Talking
haha !! I'm doing it right now...... not my self but someone else. I've the liberty RS EJ20T motor from outback motorsport in CA , you'll need new x-menber, fuel pump and a ECU if you want ( but I didn't... cos the guy who did the install say he should be able to work it out for me) all the sensor are bolt on (I had a 98 2.2L don't know about 2.5RS ) I also had new clutch , new water pump, timing belt, head, valve gasget.....etc all the stuff you need for tune up.
and I had msd timing master ( will retard timing when it see boost) apex-i afc , all the gauges I need( boost, EGT, oil pre)
greddy boost control.
the car is at the shop with the engine out , and the turbo motor is going in this weekend, hope nothing will goes wrong then I shouldbe able to pick up the car this month!!
all the cost with out the labar is :
1. engine $1300(outback motorsport in CA)
2.x-member $300(subaruparts.com)
3.fuel pump $100( off a 280hp STI impreza in hong kong)
4.all the tune up part $250 -$300 ( subaruparts.com)
5. msd timing master $170( summit racing)
6. apex-i afc $200( used off ebay)
7. greddy boost control $30 ( used off ebay)
8. clutch $300( ceco clutch)
you're looking at around $2700 for just the part only + labar.
I'll post how much my friend charge me for this whole mess when it is done.
so it isn't any cheaper than the turbo kit out there + no body know if it work or not ????? ( I hope it works) or it might run slower than before!!! who knows !!!
if I can do it again I think I'll buy a bolt on turbo kit only !! the reson why I bought this engine is when I go to outback motorsport to shop for the turbo stuff to bolt on my car only.... but it adds up to $800 for the turbo and all the accessories.... so why not just garp the whole engine for $500 more ??? then it start this whole mess !!!!!
sorry for all wrong spelling...I've try hard already... I'll post a update it there is any news comes up !!!
BTW .. my car is at the shop for two months already !!
SYMSWRX is offline   Reply With Quote
How does work the gearbox on a swap engine newbreed Transmission (AT/MT) & Driveline 1 10-18-2008 12:15 AM
Before I get greasy, does anyone know about 04-06 susp swaps? steve Vancouver Impreza Club Forum -- VIC 18 09-17-2006 08:10 PM
Does anyone know if VT Sports Car does engine swaps? xxtwowheelfiendxx New England Impreza Club Forum -- NESIC 12 02-25-2004 07:03 PM
Does anyone know the 'easiest' way to swap... wrxxxrated Mid Atlantic Impreza Club -- MAIC 7 02-11-2004 04:22 PM
does anyone swap engines? phatroksek Normally Aspirated with bolt-on Forced Induction Powertrain 1 10-15-2001 04:39 PM
