Closed Thread
Old 06-15-2006, 12:06 AM   #1
JonR
Member#: 22753
2002 PSM WRX +PPG
OBXT
Default Timing belt, etc. service price quote...high?
Trying to get an idea of whether I am getting reamed...I was quoted $1030 for replacement of the following including parts and labor:
1)Timing belt (STI version)
2)Tensioner
3)Water Pump
4)Idler pulleys
Using subaruparts lookup, I figured the cost of all the parts (belt, tensioner, pump, 3 pulleys) to be less than $600. My understanding is that this is a 3-4 hour job maximum...am I missing something or is the shop trying to charge me $100/hour for labor?
Thanks for your feedback!
JonR is offline
Old 06-15-2006, 12:32 AM   #2
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
there are probably waste disposal fees, etc. in there as well. Also - they charge whatever the book tells them to charge (which is probably 5 hours) - lots of places charge in the neighborhood of 80-100/hr.
DrD is offline
Old 06-15-2006, 12:42 AM   #3
JonR
Member#: 22753
2002 PSM WRX +PPG
OBXT
Huh..well that is useful information. I would have thought $60-70 would have been more the norm. Thanks for the reply
JonR is offline
Old 06-15-2006, 03:32 AM   #4
wirolla
Member#: 109725
2001 GM6
SRP
nah, actually 80-100 is the norm. do it yourself, save your $$$, and learn something.
wirolla is offline
Old 06-15-2006, 10:36 AM   #5
Hayes
Member#: 11808
Wink
As dealers are franchased they can charge ANYTHING they think you will pay regardless of what the "book" says. I am not a mechanic and did my TB, WP, drive belts, stat change, coolant flush & refill in less than 2&1.2 hours with two short coffee/smoke breaks. This on a SOHC engine. A good Suby mechanic with all the garage tools should easly do this job on your DOHC engine in 2 hours. Yes! you are being over charged but what other options? Call other dealers or Suby speciality shops or DIY. Ed Hayes
Hayes is offline
Old 06-15-2006, 01:11 PM   #6
Samurai Jack
Member#: 21145
2002 Enemy of Aku
^^^ As true as that may be, DrD is correct.
Dealers charge a "book rate", which is based on how long it takes, per the FSM I would presume, to perform the work on a given part. I'm not a mechanic either but I know those who are and that os how they explained it to me as to how it works.
I really liked this description as to how it all works:
On this particular car we were discussing (not a Subaru), the book says 6 hours to change a head gasket, so that is what the customer gets charged. Took the mechanic 45 minutes to do the job. Did this by taking shortcuts learned on the job. So, 45 minutes = 6 hours pay.
Even if he screws up and has to re-do it and take an hour next time, he's still ahead.
There are places that charge by the hour, but typically dealers charge a book rate. It's the "Law of the Dealers".
But, as others have said, DIY if you can, save money and learn something along the way.
Samurai Jack is offline
Old 06-15-2006, 02:56 PM   #7
wirolla
Member#: 109725
2001 GM6
SRP
exactly. if the job takes 3 hours, and the mechanic gets it done in one, you still get charged the 3 hours labor, and the mechanic makes money off of the 3 hours that he was given to do the job. good mechanics can make decent money. its all about being efficient with their time.
wirolla is offline
Old 06-15-2006, 04:36 PM   #8
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Just make sure they are not double-charging you on the labor (e.g. to change timing belt you have already done a lot of the disassembly needed for the water pump, so labor hours for both is less than just adding the two together).
armand1 is offline
Old 06-16-2006, 12:31 AM   #9
eb1888
Member#: 115226
2005 wrx wagon
The OE replacement belt has alignment marks(white lines) on it. This helps to make it easier than most to position correctly. It"s fun besides saving money. Do it once and you'll always do it yourself.
eb1888 is offline
Old 06-16-2006, 07:43 AM   #10
Mighty Subie
Member#: 97289
2004 WRX
I'm only going to agree with the rest of the posts... I do all of my Maint myself and along with saving precious money, I enjoy getting out there and knowing that it is done right. If something goes wrong later on, I will know where to look, and how to fix it once I have already worked on that part of the car.
Also, I'm sure that if you asked, there is a lot of people on here who have the tools/area and would be more than willing to help you do it!!!
-Matt-
Mighty Subie is offline
Old 06-16-2006, 11:31 AM   #11
JonR
Member#: 22753
2002 PSM WRX +PPG
OBXT
Yeah I have done ALL of my other maintenance including a clutch (sucked hard), but this was the one thing I was most worried about since I have never done it on any car. I'll have to ask around and see if anyone local can help out and consider that route.
JonR is offline
Old 06-16-2006, 12:35 PM   #12
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Unabomber is offline
Closed Thread
Changing Timing Belt etc. What about Oil Pump? notjustforshow Newbies & FAQs 8 03-10-2010 05:24 PM
Misc Engine Access fs Madison, WI timing belt, tensioner, IC, Oil cooler etc etc meisen Engine/Power/Exhaust 11 03-01-2010 11:16 PM
NC: sti engine mounts, timing belt, etc realove Engine/Power/Exhaust 11 02-14-2008 08:54 PM
Timing belt, etc. charges? (Urgent) SubieFL Service & Maintenance 5 01-26-2005 12:27 AM
Where to get a good deal for Timing Belt service? STi066 North West Impreza Club Forum -- NWIC 10 09-05-2002 11:38 PM
