Welcome to the North American Subaru Impreza Owners Club Monday October 24, 2016
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 06-14-2006, 11:13 PM   #1
Member#: 90396
2005 Legacy 2.5i
Brilliant Silver Metallic
Default Hydra - 2.5RS Boost Control???
Ok, so I know the hydra has the ability to control boost, but normally through the stock boost control solonoid, right?
Since I'm in an RS, the car was NA to begin with and never had such a device, is there a way I can control boost with the hydra, or am I SOL? It would really be annoying to have to spend another 500-600 on a nice boost controller with solonoid to use for the sole purpose of controlling boost, and I'd probably stick with an MBC if that were the case.
But is there any way to setup my RS to have the Hydra control a boost solonoid so I dont boost 15psi in 2nd, and 17 in 3rd, and 19-21 in 4th and 5th?
Sko is offline   Reply With Quote
Old 06-15-2006, 08:55 AM   #2
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
When you receive your Element Hydra EMS for the RS we have the system wired to so you can run a boost control solenoid via the Hydra. The new 2.5 Element Hydras have gear based boost control also so you can reduce the boost differences between gears.
Element Tuning is offline   Reply With Quote
Hydra 2.6 Launch Control anubis328 Other Engine Management 3 10-01-2008 08:19 PM
Hydra 2.6. + boost controller ? DemiSlayer Other Engine Management 3 07-28-2008 05:56 PM
How good is the Hydra built-in boost controller? garagedefeat Other Engine Management 17 06-04-2007 11:19 AM
2000 2.5RS Fuel Control problem spectre099 Newbies & FAQs 0 01-20-2007 01:40 PM
2002 2.5RS + Boost Akarui Normally Aspirated with bolt-on Forced Induction Powertrain 10 06-04-2004 11:19 AM
