Old 06-14-2006, 11:25 PM   #1
MaLT
Visiting NASIOC Timeout
Member#: 117377
06 WRX Wagon
Steel Grey
Have a Nice Day? Car Stalling at Idle after minor Mods
Just put a TurboXS Ti Turboback, TurboXS short RAM intake, and bov-rfl on my 2006 wrx. I am having problems with an inconsistent idle. sometimes it will be fine around 600-800rpm and other times will spike up to 1500 then back down to almost stalling repeatedly until it evens out at the 600-800 mark or simply boggs out and stalls. How do i fix this? Is it strictly ECU and o2 sensors misguaging the A/F ratio? If so, how do I apprach this problem?
MaLT is offline   Reply With Quote
Old 06-14-2006, 11:30 PM   #2
wrx16
Member#: 73784
04 WRX
take off the RFL- its going to reduce your mpg alot and you will have inconsistent idle. I had mine on for about a month and shifting was very un-smooth along with almost stalling in nuetral by the rpm's just falling for no reason. When that comes off you will be fine.
wrx16 is offline   Reply With Quote
Old 06-14-2006, 11:31 PM   #3
homer227
Member#: 92883
2005 WRB WRX
Now w/ 100% More Hella :)
Sounds like something wrong with the MAF sensor.
Also, I don't believe an intake and a bov are the best mods to get. However, the turboback is a step in the right direction.
homer227 is offline   Reply With Quote
Old 06-14-2006, 11:34 PM   #4
AspenWrx25
Member#: 111738
2008 FXT Sport
Might sound dumb but u did cap off the recirculation tube from the bov right?
And BTW bov suck, sold my HKS and went back to stock!
AspenWrx25 is offline   Reply With Quote
Old 06-14-2006, 11:34 PM   #5
MaLT
Member#: 117377
06 WRX Wagon
Steel Grey
Should i put the stock BOV back on, find a recirculating BOV to replace the rfl.
Old 06-14-2006, 11:35 PM   #6
MaLT
Member#: 117377
06 WRX Wagon
Steel Grey
recirc tube is capped and clamped
Old 06-14-2006, 11:36 PM   #7
AspenWrx25
Member#: 111738
2008 FXT Sport
I dont think u should buy a recirculating bov cause ur stock one will work fine. I think it can hold up to 20 PSI
Old 06-14-2006, 11:39 PM   #8
MaLT
Member#: 117377
06 WRX Wagon
Steel Grey
So the open atmosphere bov is the issue.
I thought that may have something to do with it. Sounds kewl, but hinders performance.
Old 06-14-2006, 11:51 PM   #9
wrx16
Member#: 73784
04 WRX
yea 100% atm. That is probobly the problem. go back to stock. sounds good but reduces performance.
Old 06-15-2006, 01:12 AM   #10
seasons
Member#: 34986
2003 WRX
definitely get rid of the BoV. The negatives greatly outweigh the cool sound.
seasons is offline   Reply With Quote
Old 06-15-2006, 01:24 AM   #11
MaLT
Member#: 117377
06 WRX Wagon
Steel Grey
Just put stock BOV back on and the car is running perfect and much faster.
I put the rfl on at the same time as the turboback exhaust and intake. the exhaust and intake w/out the rfl is spooling up the turbo nice.
I feel like an idiot to be sold on that POS-BOV.
Live and Learn. Thanks for the input, all.
Old 01-09-2012, 10:01 PM   #12
jgrove15
Member#: 304184
2004 Impreza Wrx
Default Car stalling at idle
Code popped reading cylinder 4 misfire but the main issue is at idle it periodically stalls out. When it stalls out the wideband is all over the place. I had it checked for vacuum leaks but didn't find any. What could be causing this?
Going to have it retuned soon.
Thanks for any and all replys.
jgrove15 is offline   Reply With Quote
Old 01-09-2012, 10:04 PM   #13
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
wow...bumping a 6 year old thread...
drewvdw is offline   Reply With Quote
Old 01-09-2012, 10:48 PM   #14
jgrove15
Member#: 304184
2004 Impreza Wrx
Wow.... Why do you care, I could have started a new thread but why do that when there is one already out there discussing issues that I am having? Instead of worrying about when the thread was from why don't you make suggestions.
Old 01-09-2012, 11:13 PM   #15
brew02wrx
Member#: 259970
2002 wrx cobb stg2+
psm proper fitment
1: you bumped a 6 year old thread
2: you're threadjacking as it is
3: does your car have these exact mods?
just reply to #3 and we'll go from there
brew02wrx is offline   Reply With Quote
Old 01-10-2012, 12:38 AM   #16
will.s
Member#: 280503
2007 WRX
Wow.... If you want help try being polite.
will.s is offline   Reply With Quote
Old 01-10-2012, 08:32 AM   #17
jgrove15
Member#: 304184
2004 Impreza Wrx
I wasn't being impolite. The comment was made to me about bumping a thread from 6 years ago. I thought it was better to use a thread already out there instead of creating a new on.
Old 01-10-2012, 09:17 AM   #18
jayman4312
Member#: 228784
2004 wrx
black, stage 2+
well you are wrong, unless you have the exact same car with the exact same modds and exact same problem. but if that was the case, you would know how to fix the problem.
so my answer to help you is take off your rfl bov and replace with the stock one
jayman4312 is offline   Reply With Quote
Old 01-10-2012, 10:14 AM   #19
jgrove15
Member#: 304184
2004 Impreza Wrx
No not the same car or mods. I started a new thread so I am not thread jacking as someone stated earlier. I am new to modding my car/engine and everything that goes with it. I am just starting to learn and I will admit i know very little that is why I am turning to these forums for experienced owners knowledge.
Old 01-10-2012, 02:33 PM   #20
thegad
Member#: 292307
2004 Impreza WRX
OH this is too fun!! I have to throw my 15 cents in!
So in 92% of the threads i read on here there is always that one **** hole that has to say "this questions been asked a million times go read" haha now heres a dude that did go read and still had a question and instead of starting a new he posted on the old one as is still catching ****... i love it...
thegad is offline   Reply With Quote
Old 01-10-2012, 03:36 PM   #21
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
first of all, the guy had a different car and different mods and even some different symptoms. he had one symptom in common with the OP of this thread.
second of all, you obviously haven't read this: http://forums.nasioc.com/forums/show....php?t=2124899
specifically rule number 2
2. Be Wise With the Search Function.
It really is better to start a new thread about an issue or question you have than to bump a thread from 2004. If anyone tells you to "SEARCH N00B!!!!!1!" it's because your question has been asked within the past week, or because the person telling you to search has an itch they can't scratch in public, making them cranky.
...(what, that doesn't happen to you guys?)
questions dealing with car problems or issues often times require a new thread.
Old 01-10-2012, 03:58 PM   #22
jgrove15
Member#: 304184
2004 Impreza Wrx
Damn, I was just trying to get some questions answered about a car stalling at idle which was the title of the thread. Drewvdw, I will make sure I do my research next time before I ask a question. I don't want to upset you again.
Stumble at idle after mods 3XRex Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 03-28-2007 12:36 AM
new battery, now car stalls at idle 04works UTEC 7 02-16-2007 05:48 PM
Car stalling at idle joeyd02 Newbies & FAQs 3 10-16-2006 11:23 PM
Stalling at Idle after Minor Mods MaLT Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 06-17-2006 04:51 PM
Car stalling at idle... ExecNav Normally Aspirated with bolt-on Forced Induction Powertrain 6 05-21-2005 02:34 AM
