Welcome to the North American Subaru Impreza Owners Club Saturday August 1, 2015
Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum > Western Canada
Old 06-15-2006, 01:15 AM   #1
TIRVINE
Member#: 115711
2004 STI
JAVA BLACK
Default How much oil should a guy burn with the adds you have
My car has stock turbo fmic cobb stage 2 full header equall lenght exhaust turbo back and a blow off valve (that I am not sure how to set propperly ..car runs rich on the fuel side and doesnt seem to hit anywhere near max boost 13.4psi (what a joke ) on another note I down shifted last week to consider passing some one and pulled second rpm gauge hit 8800 to 9ooo rpm any thoughts on what to check I have no codes showing on car and runs smooth except the odd back fire hence the running rich issue car ran 13.2 105mph 1/4 mile in fort st john bc on two passes
TIRVINE is offline   Reply With Quote
Old 06-15-2006, 09:11 AM   #2
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
Why you titled your thread about oil use is beyond me. Been partying?
Anyway
Subaru's can take alot of over revs like your car did going back to 2nd. Done it myself. Should be fine. Now over rev under boost is a different animal but the factory takes care of that.
Throw the BOV in the garbage. Use the stocker
As for boost you don't mention what gear. Its normal in first and second but not in 5th.
Wombat North is offline   Reply With Quote
Old 06-15-2006, 10:14 AM   #3
Jitenshakun
Member#: 61586
2005 STi
WI and all the goodies
If you're concerned about oil consumption I'd suggest switching away from the Subaru OEM oil filter. I consistently lost 1L /3000km with the OEM filters (both types). The dealership finally did a full diagnostic (leak down, compression, etc) and they couldn't find anything.
I switched to Fram filters and I haven't lost a drop since.
-J
Jitenshakun is offline   Reply With Quote
Old 06-15-2006, 01:33 PM   #4
benyl
Member#: 48833
'05 Dirty STi
'08 E92 335,'03 E46 M3C
-J
Um, where does the oil go?
benyl is offline   Reply With Quote
Old 06-15-2006, 01:42 PM   #5
Jitenshakun
Member#: 61586
2005 STi
It went dribble-dribble-stream-dribble out the top of the oil filter onto the road. However, it only managed to escape when driving, especially under boost.
It wasn't in the IC, it wasn't in the exhaust, it wasn't in the turbo, it wasn't on the park plugs, it wasn't in the coolant, etc, etc.
-J
Old 06-15-2006, 04:29 PM   #6
SPIDEYWrX
Member#: 36109
-J
Sounds like MAGIC
SPIDEYWrX is offline   Reply With Quote
Old 06-16-2006, 10:53 AM   #7
benyl
Member#: 48833
'05 Dirty STi
my oil is going somewhere... but I haven't really tried all that hard looking for it... haha
Old 06-16-2006, 11:17 AM   #8
thejean
Member#: 17763
Mine too. I might try these fram filters you speak of.
thejean is offline   Reply With Quote
Old 06-17-2006, 02:56 PM   #9
aclaz
Member#: 56452
2002 WRX Wagon
Same here. For the last 3 oil changes, I've been losing about a quart per 5K miles (using M1 synthetic). I'll try a non-OEM filter at the next oil change to see if this solves the problem.
aclaz is offline   Reply With Quote
Old 06-17-2006, 03:00 PM   #10
Leadfoot77
Member#: 74268
2013 STi
wow i think this might be the first time i've ever heard something good said about fram and heard hundreds of bad things....
Leadfoot77 is offline   Reply With Quote
Old 06-20-2006, 10:48 PM   #11
T_WREX
Member#: 90961
04 STi
Please tell me you're not serious. FRAM ?! Do a search on 'fram filters suck' here or Google if you don't believe me.
T_WREX is offline   Reply With Quote
Old 06-20-2006, 11:03 PM   #12
Jitenshakun
Member#: 61586
2005 STi
Let me see, the OEM Subaru filter has a paper bit in the end which degrads and allows bits to flow past the filter. Moreover, it leaks, meaning I'm at risk of running my engine dry.
I'll take oil in my engine at the sacrifice of a few more particles.
As soon as I can find another brand I'll use it.
I will NOT go back to the Subaru OEM filter.
-J
Old 06-21-2006, 12:48 AM   #13
CRXguy
Member#: 25370
2003 WRX wagon
Played Out Blue
-J
Wow, I'm gonna have to get under my car tomorrow and take a look.
CRXguy is offline   Reply With Quote
Old 06-21-2006, 09:37 AM   #14
Jitenshakun
Member#: 61586
2005 STi
I've been logging oil loss for close to 30,000km so I'm confident of my findings.
-J
Old 06-22-2006, 12:24 AM   #15
T_WREX
Member#: 90961
04 STi
I believe you, it's just I don't think Fram is the right brand to go with.
Old 06-23-2006, 07:20 PM   #16
02WHITEDUB
Member#: 96793
02 ProTuned TD04
Now with more clunks!
I've had my WRX for a little over 2 years. It's at about 87,000km and I've never lost a drop. I check my oil probably 3 times between changes and it's always the same level. I use OEM filters, but with a Greddy sandwich adapter that makes it even MORE likely to leak...
To the OP, I'm thinking your car needs a ProTune to run those mods effectively. Headers, FMIC, and BOV are all outside of Cobb's map parameters. You are leaving tons of power on the table. Heck, your car might be faster if you reinstalled the stock TMIC and stock headers using Cobb's stage 2 map. The BOV isn't helping either...
02WHITEDUB is offline   Reply With Quote
Exactly how much oil is supposed to be in the intercooler? lo0pback Normally Aspirated with bolt-on Forced Induction Powertrain 16 10-26-2014 08:25 AM
How much oil should register? LakeOSTI Service & Maintenance 56 01-21-2006 10:56 PM
How much oil should i put legacyace Service & Maintenance 2 04-26-2005 06:00 PM
how much oil is normal to burn in 2500 miles? blackie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 11-04-2004 08:11 PM
