Old 06-15-2006, 01:34 AM   #1
NotoriousD
Member#: 97025
98 04 RSTI
RBP
Default Need HELP: DccD Problems.. Center Diff?? Rear Diff?? Dccd Controller?
Guys!.. I have a crisis with my STI.. Heres the issue.. When I start my car, my abs light is automatically on and Dccd is set on AUTO which is suppose to be used for normal driving.. After driving for 30 seconds, the dccd light is set on RWD and it flashes on RWD.. When this happens, the car feels like the dccd is locked which makes a grinding, rubbing, horrible diff locking sound on turns.. It has gotten so bad that the car would not even move making turns.. Once the car is set from auto to RWD, I am not able to set it back to auto unless I turn off the car.. Once it turns on, it will be set on auto again and then I am able to adjust the dccd to rwd or what not but after driving again it will set back to rwd.. I brought the car to a regular mechanic and subaru dealership mechanic... The regular mechanic says the rear diff is no good.. the subaru dealership says center diff is no good.. Did anybody get this problem before with their 04 sti or 05 sti??? Please I need help.. I got a suggestion to change my dccd controller and see how that goes.. any others?I apologize for the long boring story but I need help.. thanks
NotoriousD is offline   Reply With Quote
Old 06-15-2006, 08:56 PM   #2
NotoriousD
Member#: 97025
98 04 RSTI
RBP
anybody?
Old 06-16-2006, 12:04 PM   #3
NotoriousD
Member#: 97025
98 04 RSTI
RBP
nobody?
Old 06-16-2006, 12:28 PM   #4
corey_dyck
Member#: 98427
2006 STI
Are you the same person that posted on iwsti.com?
It sounds electrical, like the DCCD controller is screwed up. I'd unplug the connector on the tranny (wires leading to rear passenger side of tranny) if you have to drive the car. If that fixes the issue, you know it's electrical. If not, you know it's mechanical.
corey_dyck is offline   Reply With Quote
Old 06-16-2006, 04:26 PM   #5
NotoriousD
Member#: 97025
98 04 RSTI
RBP
yeah im the same person who posted this on IWSTI.com. what color is the wire by the way ?
Center or Rear Diff? TheStig22B Transmission (AT/MT) & Driveline 10 06-30-2009 11:09 PM
STI binding center and rear diff in Auto mode. Fluid questions. Gami004pilot Transmission (AT/MT) & Driveline 4 11-02-2007 07:51 PM
NEED HELP: WTF ALUMINUM CENTERING RING halting new wheel install. stewgod Tire & Wheel 18 07-07-2007 11:58 AM
Center & Rear Diff -'99 outback sport ac30treb Private 'Wanted' Classifieds 4 08-11-2006 09:33 PM
front, center, and rear diff oil change? awdguy Transmission (AT/MT) & Driveline 4 04-28-2005 10:44 PM
