Old 01-13-2001, 01:31 PM   #1
gtguy
Member#: 2184
2005 Legacy GT wagon
Platinum Silver Metallic
Post Kevin's suspension adventures, continued....
For those who don't get over to the Suspension board, here's the dope...
The Tein coilovers went in beautifully. Height adjustments are another matter, since the spanners didn't find their way into the box.
I'm still fooling around with stiffness, etc., but right now the setting of 4F/6R feels like stock, though the spring is a bit stiff for that soft a strut setting. 6/8 feels better, and 10/12 better still in the performance parameters.
Once I get the spanners, I can fool with ride height in front/rear balance, and other stuff. I'd also like to figure out some way to calm the rather noisy pillow mounts. You don't hear them at all on normal roads, but when the going gets bumpy...
Oh, the job was super easy. The Teins are made to a very high standard, and except for my strut mounting bolts which had been tightened with an impact wrench, things went quite well. As I fiddle more with them, I'll let folks know.
I might have to return to the stock mounts, since I won't be doing a danged thing with camber anyhow, near as I can tell right now...
Kevin
gtguy is offline   Reply With Quote
Old 01-13-2001, 04:54 PM   #2
SYMS GT
Member#: 427
'91 SS Legacy EJ257
DOHC/18g/FMIC/V.8 6spd
Talking
That mean you may want to part with them? Let me know...
Congrats BTW
-Matt
SYMS GT is offline   Reply With Quote
Old 01-13-2001, 11:36 PM   #3
gtguy
Member#: 2184
Post
I will let you know indeed, SYMS GT. I'm thinking that there has to be some way to quiet that faint clunking. But when the road is smooth (not even billiard table) they're dead quiet. I'm very impressed, especially considered that they aren't optimized yet.
Kevin
Old 01-14-2001, 09:42 PM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Post
How are the Teins adjusted? And which Tein setup is this? I know there are different variants (HA and NA or something like that), but I don't know which is which.
Do you know what the spring rates are?
Can you describe the noise the pillow ball mounts make? I've heard they're noisy, and the fact you said they're noisy when the road is bumpy leads me to believe they're not for me - too many bumpy roads here in New England.
Do you really need the spanner for ride height changes? I have coil-overs on the front of my Mustang and all you have to do to adjust the height is jack up that corner, dial the spring seat by hand, drop the corner back on the ground and see where it rests. No spanner required, unless one were to try to adjust ride height with the full weight on that corner (and I don't think I could even get in there with a spanner on the Mustang if it were resting on the ground). Anyway, just babbling...
Thanks for the feedback - keep us informed!
Pat Olsen
'97 Legacy 2.5GT sedan
Old 01-14-2001, 10:16 PM   #5
gtguy
Member#: 2184
Post
They're the Tein HA, which is the coilover kit. The rates are 6 and 8kg/mm. I forget the math, but pretty stiff, although they feel good. I've pretty much settled on 5/5 or 6/6 as something that feels very close to stock.
The noise is something like a very gentle clunking. It seems to be lessened with the caps, padding, and strut tower covers in. You can barely make it out. I have everything open though, since I'm still fooling with settings. The wife didn't think it was all that objectionable, since you only hear it on roads that are a pain the butt anyhow.
The Teins have a pair of collars on the lower perch. The bottom one locks everything down, so when you snug it down, yeah, you need the spanners. We're pretty sure that I can get at the fronts with the wheels on, just by turning them to extreme right or left, dependent upon which side is being tweaked.
Right now, I'm at -3/4" from stock, and it looks great. Close to stock, but low enough to handle. It'll probably go to an inch down in the summer, though we'll fool with that, too.
Having all these adjustments, unfortunately, mean that you make 'em. Dios mio!
We'll see about the noise. I have an email in to Tein about it, and I might return to the stock mounts in the rear, since they don't have camber anyhow and the effects of the pillow ball in the rear isn't as important as the fronts.
Kevin
Old 01-15-2001, 04:15 PM   #6
rao
Member#: 52
2005 Legacy GT
98 BMW 540i LS2/T56
Cool
"Oh, the job was super easy. The Teins are made to a very high standard, and except for my strut mounting bolts which had been tightened with an impact wrench, things went quite well."
AHEM???? Just how easy was that job????
"Height adjustments are another matter, since the spanners didn't find their way into the box."
OH REALLY?? I hope you were able to make do with another tool
Thanks for the tapes, they are really great.
[This message has been edited by rao (edited January 15, 2001).]
rao is offline   Reply With Quote
Suspension that will ride more comfortable than stock! GoneSingle Brakes, Steering & Suspension 10 06-02-2010 12:28 PM
Broke Guy Daily Driver Mutant Suspension Setup Review Turbineguy Car Part Reviews 1 06-01-2010 07:58 PM
FS : (IL)07 STI LOW MILES STRUT,SPRING suspension eng4280 MWSOC Private Classifieds 0 06-01-2010 02:09 PM
suspension noises continue to make me unhappy bWRX Brakes, Steering & Suspension 18 10-26-2006 12:36 PM
Kevin's Suspension Install at Rob's House rao Mid West Subaru Owners Club Forum -- MWSOC 8 01-11-2001 12:43 AM
