Old 06-15-2006, 02:05 PM   #1
subywrx
Member#: 81858
Default Access port question
How much or safe is getting a cobb access port for MY04 WRX? I have a gutted downpipes, MBC (not installed) and sti cat-back. Will it be worth it to get the access port and can the stock ecu be program back to stock spec without a problem? I just want to keep it as stock as I can without the wife knowning.
subywrx is offline   Reply With Quote
Old 06-15-2006, 02:18 PM   #2
johsti
Member#: 36049
2014 FXT Premium
Do it! Gut your uppipe if you haven't already. Get the AP and go see Mike @ Gruppe-s for a pro-tune. It is very safe, especially with a custom tune. The MBC is very unsafe; sell it.
I just got protuned a few days ago, and put down 209.5 WHP and 205 lbs./Tq on the Gruppe-s Mustang dyno. Stock WRX's put down around 155WHP on this dyno. Only mods were sti uppipe, stromung shorty DWG DP, IC Hose and STI axleback. I still have my factory 3rd cat and resonator pipe.
johsti is offline   Reply With Quote
Old 06-15-2006, 02:20 PM   #3
johsti
Member#: 36049
2014 FXT Premium
Yes you can revert your car back to stock when needed with the AP.
Old 06-15-2006, 02:37 PM   #4
subywrx
Member#: 81858
Do I have to gut the up-pipe? I replaced it back to stock and its way too much work to take it back out again. Do you think keeping the uppipe be fine?
Old 06-15-2006, 02:45 PM   #5
johsti
Member#: 36049
2014 FXT Premium
You had a catless uppipe in there previously and you took it out to put the catted stocker back in???
why???
It is a lot of work, but that cat needs to be out of there. It's not mandatory, but you do run the risk of having the catalyst material breaking up and getting sucked through your turbo, especially if you're running higher boost, etc. Also it helps your turbo to spool a little quicker. Subaru isn't even putting cats pre turbo anymore.
Also, since you have an 04, and gutted cats, you're taking a big risk by not having some sort of EM. I would get some EM ASAP before you break something. Look into the open/closed loop fueling issue that Subaru implemented in 04.
Old 06-15-2006, 03:05 PM   #6
subywrx
Member#: 81858
I replaced back because I wanted to go back to stock but months down the line I got a gutted down+mid pipes and sti cat-back. So what you're saying is with my catless tbe it's not safe for my WRX? I mean how?
Old 06-15-2006, 03:35 PM   #7
johsti
Member#: 36049
2014 FXT Premium
http://forums.nasioc.com/forums/show...en+loop+closed
There are many more threads that discuss it, but here's one. Do a search for "open loop closed loop" and you should find more info.
I was running a shorty catless DP with no EM when I first got my car, and it was bucking under acceleration at around 3.5-4k rpms under WOT. EM solved the problem.
Old 06-15-2006, 05:05 PM   #8
subywrx
Member#: 81858
If I was to get a gutted up-pipe, do people usually plug the EGT hole and unplug the EGT? Do you think I can pass smog with catless up-pipe but with catted down+mid pipes? I'm really interested in getting the ap but I'm worry when smog comes around. How fast/faster you think your car performed? I heard with a setup like yours you can keep up with EVOs.
Old 06-15-2006, 08:00 PM   #9
johsti
Member#: 36049
2014 FXT Premium
You don't have to smog your car for 6 years unless you sell it.
You should pass smog without your uppipe cat since it is only for cold sart emissions. Just put the other 2 back in and make sure your car is warmed up. A gutted uppipe looks stock, so it would pass visual (not that you can really see it anyways).
The AP will take care of codes, but you can also use a resistor, and you need to plug the EGT hole with a bolt. I've never gutted an UP, so I can't tell you all the specifics.
As far as keeping up with an EVO, I doubt it. I think a stock Evo puts down about 210-215WHP on Gruppe-S dyno, but with better gearing, brakes, suspension, etc. It is fun though, and makes for a great daily driver.
It put down 202WHP and 195lb/tq with the cobb CA stage 2 map. My car was running a bit lean though. Mike made a safer and more powerful tune compared to the OTS Cobb map.
Old 06-15-2006, 08:05 PM   #10
subywrx
Member#: 81858
Thanks a lot johsti.
02 4EAT Access Port Question... semipro Engine Management & Tuning 5 09-28-2005 06:14 PM
Need help on access port question? titanium wrx Engine Management & Tuning 3 11-29-2004 02:14 AM
Access Port Questions JLOWRX Texas Impreza Club Forum -- TXIC 3 08-16-2004 03:50 PM
Access Port Questions JLOWRX Texas Impreza Club Forum -- TXIC 13 07-23-2004 04:49 PM
Cobb access port questions SoonToBeRexed Newbies & FAQs 12 07-05-2004 11:03 PM
