Old 06-15-2006, 11:26 PM   #1
jdbewl01
Member#: 80541
2004 WRX
Default will i spool too quickly?
i am installing a deadbolt monster td04 along with a perrin turbo inlet hose and port/polish stock monifold. will the cobb stg 2 base map handle the extra flow safely, or will i have to get a protune or a map from pdxtuning first? also, will the gutted stocker be ok with this setup, or should i try to port match the stocker, or should i sacrifice the money and just buy an aftermarket uppipe as well? thanks,
-jeremy
jdbewl01 is offline   Reply With Quote
Old 06-16-2006, 12:43 AM   #2
jdgrimm
Member#: 74386
02- 2.5 Hybrid
GrimmSpeed
i'm running the same setup. you'll be fine, but i'd either get a protune or a pdx map soon to really get the most out of your setup.
jdgrimm is offline   Reply With Quote
Old 06-16-2006, 12:55 AM   #3
jdbewl01
Member#: 80541
2004 WRX
appreciate the reply; what kind of difference did you notice? dyno it yet? any suggestions on what i should do with the uppipe? thanks again,
-jeremy
Old 06-16-2006, 12:55 AM   #4
hondaeater69
Member#: 60324
i agree you should be fine, the new base maps go into open loop fueling pretty fast. like /\ said, in order to get the most out of the mods, DEF get a protune.
Edit: to asnwer the other Q, the stock UP should be fine, port matched would obviously be best for flow
Old 06-16-2006, 01:05 AM   #5
jdgrimm
Member#: 74386
02- 2.5 Hybrid
GrimmSpeed
-jeremy
DEFINITELY ~300 quicker spool right when you slap it on. remeber to enlarge the opening of the up pipe as well. havent had a chance to dyno yet but there was a new thread started recently in the proven power bragging thread that has dyno numbers from a ported td04. i think he hit 249whp and his torque curve is straight up.
Old 06-16-2006, 01:19 AM   #6
jdbewl01
Member#: 80541
2004 WRX
good to hear; i definitely plan on getting protuned, but i want to get an axleback and a bigger tmic first so i don't have to get tuned twice. another question: should i get bigger injectors (like deatschewerks modded stockers) and a walbro now, or wait until i end up with a bigger turbo? i keep reading that some tuners say that stock injectors are pretty much tapped out with a protune.
Old 06-16-2006, 01:23 AM   #7
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
You might as well do the bigger injectors and pump now if you can. I'm running a TD04 on my 2.5L swappeed WRX but I have 660cc injectors and a Walbro already in there awaiting my VF39 that's sitting on my floor.
wrxfactor is offline   Reply With Quote
Old 06-16-2006, 01:41 AM   #8
jdbewl01
Member#: 80541
2004 WRX
sounds good, but is that something that requires a tune other than the cobb ots maps? i really want to keep safe here....thanks for the replies everybody!
-jeremy
Old 06-16-2006, 10:42 AM   #9
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Now that this is in the RIGHT FORUM, read the sticky that someone smart wrote at the top of this forum for your answer.
V-Mount plus rotated intake, how much will the spool time improve? roybfr Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 05-23-2007 12:16 PM
How Fast Will It Spool Gt 35 On A 2.0l? hectowrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 43 05-09-2007 10:12 PM
free music to spool too.... clawdnb Off-Topic 10 02-22-2006 01:24 PM
List mods that will increase spool time topgrinder Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 01-13-2003 02:20 AM
('93-'01) sulfur smell with high revs? (going too fast too quick?) nkodemus82 Impreza Forum 5 04-18-2001 06:44 PM
