Old 06-16-2006, 02:15 AM   #1
lbc92svx
Member#: 117671
Default 1992 SVX AWD, FWD light is on, please help. 4EAT AWD SYS
Hi, I'm looking at buying a 92 SVX. I test drove it and it passed all the usual SVX flaw-tests. However, the whole time a red light stating FWD was on. Apparently it turns off the rear differential and is generally only used by Subaru dealers during service. Is restoring the AWD as easy as replacing the 10amp fuse that typically is removed to make the FWD light come on?
Is there anything else besides that fuse being out that would shut off the rear differential? How do I turn it back on?
I have to make my decision to buy/not buy for sure tomorrow,
Thanks very much,
92SVXAWD
lbc92svx is offline   Reply With Quote
Old 06-16-2006, 12:05 PM   #2
Acostafan
Member#: 67398
2002 Now with 100%
RDA of 2.5l Goodness!!!
That's what I was going to tell you to do. Check the fuse to see if it's blown. Replace as necessary and see if that doesn't cure it.
Acostafan is offline   Reply With Quote
Old 06-16-2006, 12:26 PM   #3
lbc92svx
Member#: 117671
hm, any idea where I would find the fusebox, and does it use mini or standard blade fuses? partsamerica-dot-com was no help.
Old 06-16-2006, 12:40 PM   #4
Acostafan
Member#: 67398
2002 Now with 100%
IIRC, a lot of the auto tranny Subies had the fuse box under the hood and was clearly labeled. It should be easy to find. If all else fails, a dealer should be able to tell you where to locate it.
Old 06-16-2006, 01:01 PM   #5
ned4spd04wrx
Member#: 67033
2005 WRX
FWD Fuse in my 97, and 99 outback, its at the back of the enigne bay on the left... might be same spot.
ned4spd04wrx is offline   Reply With Quote
Old 06-17-2006, 06:16 PM   #6
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
You need to REMOVE the fuse in order to ENABLE the AWD.
Check behind the front strut tower on the passenger side in the engine bay.
Legacy777 is offline   Reply With Quote
Old 06-17-2006, 09:56 PM   #7
wrxsubaru
Member#: 65133
And because of that i would be worried that if some one went and put a fuse in, the car may have a AWD problem.
wrxsubaru is offline   Reply With Quote
Old 06-17-2006, 11:22 PM   #8
gest24
Member#: 117213
92 SVX
Pearl w/Black Roof
To put the SVX into FWD mode you have to put in a fuse. The light only comes on when the fuse is in. The factory put some sort of sealent in the hole to prevent a fuse from going in there. I'd say take out the fuse before you fry your front diff.
gest24 is offline   Reply With Quote
subaru battery & brake light stuck on please help AFAP_Nor_CA Newbies & FAQs 4 09-19-2010 02:14 AM
Did a seat swap now air bag light is on please help! 06-wrx-tr Electrical & Lighting 5 03-05-2009 06:09 PM
HELP! DCCD light flashing and ABS light is ON. Diff in FULL LOCK. 04 STi. ProdriveRex Transmission (AT/MT) & Driveline 12 02-28-2007 10:03 AM
Brake light is on please help tf2t Brakes, Steering & Suspension 4 02-09-2003 08:42 PM
How to get running lights with the foglights on? Please Help 2.5rsMI General Forum Archive 0 03-18-2001 02:17 PM
