Old 06-16-2006, 05:15 AM   #1
stumblinryan
Member#: 112945
Default camshaft question
Gonna put a few goodies in my RS here soon: cobb CAI, cobb stage 2 headers, pulley system, and was also thinking about putting in the cobb "spicy" cams, and had a quick question. Will the camshafts require any sort of engine management, or should I be ok with the stock ECU? Any input would be greatly appreciated, thanks all.
stumblinryan is offline   Reply With Quote
Old 06-16-2006, 08:48 AM   #2
Rally_wgn
Member#: 62629
1996 OBS in Green
2.5 N/A w/ full exhaust
To clarify, are you installing Stage 2 heads or Cobb Equal Length Headers.
With headers the car should run fine without EM but the EM allows optimum operation.
With Stage 2 heads and cams EM I would think would be recommended.
Rally_wgn is offline   Reply With Quote
Old 06-16-2006, 11:58 AM   #3
Boost-Free Subee
Member#: 61052
1999 2.5 RS
not sure about cobb's setup (search for anything that Matt Monson has said....he's a technical god) but my TWE stage 2 heads and cams (along with EL header and Hi-flow cat has had NO EM issues whatsoever.
Boost-Free Subee is offline   Reply With Quote
Old 06-16-2006, 02:53 PM   #4
stumblinryan
Member#: 112945
Sorry, cobb EL headers, not stage 2 heads. Sorry for the confusion, but thank you for the reply
Old 06-16-2006, 03:10 PM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
The headers will throw an 0420 cat inefficiency code, but the cams should not. And I personally don't run any EM on my car. The code doesn't effect driveability and the stock ECU does a very good job of compensating for the mods...
Timing Belt/Camshaft Question gryph Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-02-2005 04:46 PM
Camshaft questions John*G Normally Aspirated Powertrain 2 04-29-2004 07:50 AM
I have a camshaft question. Intake vs. exhaust lift Eric SS Normally Aspirated Powertrain 15 05-22-2002 05:14 AM
camshaft question Jayson_K Normally Aspirated Powertrain 18 01-16-2002 11:27 AM
COBB Tuning's Performance Camshaft question iceman Normally Aspirated Powertrain 1 11-20-2000 05:33 PM
