Old 01-13-2001, 09:11 PM   #1
gimpless
Member#: 3488
1997 Legacy GT
Forest Green
Post lowering springs
what lowering springs do all you 97-99 legacy GT sedan owners have on your ride? Ive been looking at the eibach pro-kit. is it any good?
gimpless is offline   Reply With Quote
Old 01-13-2001, 10:13 PM   #2
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
Exclamation
My recommedations are the following :
TEIN soft
H&R's
KG/MM
Either go w/ AGX's or the V5 struts... I've tried the AGX's w/ TEIN's as well as the H&R's w/ V5's Both are great.. depends if you want adjustablity
GTBGUY is offline   Reply With Quote
Old 01-13-2001, 11:39 PM   #3
gtguy
Member#: 2184
2005 Legacy GT wagon
Platinum Silver Metallic
Post
Depends on the drop you want. Do a search on Eibach within the Legacy forum, but there have been some rather precipitous plummets with the Eibachs, me included.
Dale at Teague's has springs that offer the mildest drop I know of if that's your fancy, between 3/4-1", from Whiteline. He has a set on his project Legacy and is quite fond of them.
I have heard really good things about H&Rs, but the drop is over an inch, and ditto for the Teins, I believe.
Kevin
gtguy is offline   Reply With Quote
Old 01-14-2001, 09:53 AM   #4
motorob
Member#: 2878
06 Evo IX MR
Post
I've heard that some struts can help to correct for drop too. A guy at a meet told me that the KYBs hae their spring perches mounted a little higher, so that a lowering spring will not be quite as low when mounted with these struts. Does anyone know if there's any truth to this? Thanks.
motorob is offline   Reply With Quote
Old 01-14-2001, 09:58 AM   #5
gtguy
Member#: 2184
Post
Dunno about that. I had AGXs when I got the big slam from the Eibachs. On the other hand, the AGXs sat higher than stock with the stock GT springs.
How's that for confusing information?
I do recall hearing that their gas charged nature makes them sit a tad higher than stock struts, which was borne out by my experience with them.
Kevin
Old 01-14-2001, 01:14 PM   #6
gimpless
Member#: 3488
1997 Legacy GT
Forest Green
Post
i just want something that gives me over an inch drop and i want to keep my stock struts. what should i get? the eibachs?
Old 01-14-2001, 01:32 PM   #7
GTBGUY
Member#: 2003
'99 BGP Legacy GT
Post
If you're going to keep your stock struts, I wouldn't recommed on getting lowering springs at all... b/c your stock struts cannot keep up, they will be underdampened, and you'll have to swap out your stock struts really soon. I think that ForceFed had H&R's on stock struts for awhile though.... don't know how long they lasted.
Old 01-14-2001, 01:49 PM   #8
gimpless
Member#: 3488
1997 Legacy GT
Forest Green
Post
how much would the eibach springs and new good struts cost me?
Old 01-14-2001, 02:09 PM   #9
gtguy
Member#: 2184
Post
I'd go H&R before I go Eibach, especially if you want more than an inch down. SPO Motorsports was trying to blow out H&Rs last time I talked to Scott. Then check out the V.5 strut GB over in the Vendor classifieds. You can probably get out for under $500.
And I'm with GTBGUY...don't lower with the stock struts. You won't like it. If anything, you're better off with uprated struts and stock springs.
Kevin
Old 01-14-2001, 02:53 PM   #10
gimpless
Member#: 3488
1997 Legacy GT
Forest Green
Post
so i would need those struts and the h&r springs? not the v5 springs, but just the v5 struts and h&r springs, right?
Old 01-14-2001, 04:31 PM   #11
GTBGUY
Member#: 2003
'99 BGP Legacy GT
Post
gimpless - yes that's right... H&R's w/ V5 struts... not a bad combo, but if you want adjustability, go w/ AGX's.
If you want to slam your car even more, go with TEIN's. There's a GB going on for AGX's and TEIN's. I've set-up one for us Canadian guys through Chris @ TRi Tuning. keep in mind this combo will be more $, but you'll have adjustability for dampining, as well as a lower stance than the H&R's.
White rear wing spoiler for 2000 2.5rs /lowering springs masters324 SCIC Private Classifieds 5 06-01-2010 08:26 PM
Quick Q: 2.5RS Rear Strut lower spring perch lower than WRX rear strut spring perch? bwco Brakes, Steering & Suspension 0 06-29-2004 06:24 PM
2004 STi pink lowering springs are how much lower? NORCAL STI Brakes, Steering & Suspension 0 11-28-2003 04:49 PM
lowering troubles, are lowering springs enough? scoobs_wrx Brakes, Steering & Suspension 7 02-20-2002 04:12 PM
What r the least lowering lowering springs? GooseMan Brakes, Steering & Suspension 11 06-25-2001 01:15 AM
