Old 06-16-2006, 04:00 PM   #1
STIGuy116
Member#: 87257
2005 STI
Default check engine light question - 05 STi
I have an 05 sti with an 1820 turbo on it, APS inlet hose, power enterprise 850 cc injectors, walbro fuel pump, a utec and a tune from turboxs. My car dyno at 350lbs of torque and 327 whp. the check engine light is on from some type of slight misfires, i was told thats nothing to worry about. But my question is when im on the parkway getting on the car the check engine light tends to flash on then off???? What could that be, and how can i fix it!?!?!?!
STIGuy116 is offline   Reply With Quote
Old 06-16-2006, 04:09 PM   #2
drfrink24
Member#: 36369
2004 WRX STi
Java Black
Doesn't UTEC flash the CEL on knock events?
drfrink24 is offline   Reply With Quote
Old 06-16-2006, 04:48 PM   #3
STIGuy116
Member#: 87257
2005 STI
i would assume it is a knock but how can i fix that? I've changed everything i was supposed to... occasionally it gets boost creep as well. when it doesn't creep i get the knock!
Old 06-16-2006, 04:51 PM   #4
STimo
Member#: 110273
450 whp 30R STI
[email protected]
I would stop getting on it until you have it figured out. It's not worth blowing the motor IMO.
STimo is offline   Reply With Quote
Old 06-16-2006, 10:25 PM   #5
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
I would take it back to TXS and have them look at it.
dexterous is offline   Reply With Quote
check engine light question jlam86 Vancouver Impreza Club Forum -- VIC 7 11-28-2006 06:06 PM
2005 STi check engine light question STIGuy116 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 02-27-2006 07:40 PM
Check engine light question.... just one blunt Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-26-2004 08:04 PM
[B]Check Engine Light question regarding uppipe/downpipe[/B] Moshpit552 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-21-2004 02:36 AM
Check engine Light Question P1443 speedrkj Tri-State Area Forum 8 02-26-2003 07:39 PM
